You can also do a load test on your clutch by e.g. finding a hill on a freeway, put it in 6th gear, then stand on the throttle aggressively, and see if the clutch grabs immediately or the clutch slips a little under load. My clutch has just started to slip ... on the freeway, at 3k rpm, if I stand on the throttle for a second or two, the clutch slips and the revs go up to about 4k rpm, before coming back down 3.5k rpm without getting off the throttle (i.e. it seems to slip about 500 rpm initially on throttle tip in under load). Incidentally, my clutch has also started to chatter some of the time when I pull away from a stop slowly.
Since I need to replace my clutch as well, I have down a fair amount of research on Evo clutches over the last week or two. Based on my research, for my intended use (daily driver, planned 400+ wtq upgrade path, w/ planned 10 HPDE/track events / year), I have decided to go for:
- ACT XT 3200 lb. extreme pressure plate
- ACT SD solid hub organic disc (not advertised on ACT's web site)
- Road///Race Engineeering (RRE) flywheel
- OEM throw out bearing
- clutch line
Read this:
http://www.socalevo.net/index.php?op...776#msg7482776
And the bottom of this post from Mike W @ RRE for his recommendation for a streetable clutch that can take some abuse and hold a decent amount of power:
http://www.socalevo.net/index.php?op...990#msg7490990
Also I believe Mauricio at Massimo Power now recommends ACT XT pressure plate + ACT SD solid hub organic disc for many customers too.
