how to log IAT's on evoscan?
I decided i want to check and see how my IC is doing before I drop some loot on a better one.
I assume the easiest way off the top of my head is to log the IAT's in Evoscan.
I see two options though that can possibly do this?
Air Temp and MAF Air temp scaled.
which would I use?
Also do I need the external unit to log this or is there a sensor in the stock IM to log this to give me an idea if my car is heat soaking horribly?
from what I understand this gets read in the MAF on a stock setup?
__________________
AKA: PM-Performance
APAT Tuned
05 EB VIII
345WHP/322TQ on 23PSi on the "HeartBreaker" Mustang Dyno (old numbers)
