What dyno numbers should i expect with my setup??
Old May 16, 2011, 06:35 PM
Nelson999's Avatar
im not trying to go all out on building this car right now so im just doing some bolt ons before i tune it and im wondering what numbers i should expect.
My car is a 05 MR
Mods so far:
TBE
intake
MBC
before i tune im getting:
intercooler pipes, walbro fuel pump
it will be tuned on 91 gas because thats all i can get in cali.
with this setup, if i have them turn the boost up to like 23-25 psi, what numbers do you think i can put down, hoping for like 320 maybe?
also im wondering if i need to get bigger injectors before i do this or if the stock ones would be fine??
thanks guys i dont really know anyone with evo's so any help i can get from people who have experience with building/tuning evo's is much appreciated
Old May 16, 2011, 06:42 PM
BLK_EvIL's Avatar
if its on a mustang dyno your looking around 280ish id say
Old May 16, 2011, 07:03 PM
Nelson999's Avatar
what setup do you have that got you 339 on 91oct?
Old May 16, 2011, 09:11 PM
BLK_EvIL's Avatar
that was vd dynojet numbers comes to around 300 mustang dyno
mods were 9turbo,ets 3.5fmic,TBE,V7 with ecu boost,LICP,buddyclub 272's,and open filter
Old May 16, 2011, 09:12 PM
BLK_EvIL's Avatar
oh ya 23psi peak about 21 redline
Old May 16, 2011, 09:13 PM
BLK_EvIL's Avatar
whos doing the tuning?
Old May 16, 2011, 11:52 PM
Nelson999's Avatar
im not sure yet but theres a nice place right by my house called Driving Ambition, they are known for their work on NSX's, but they do tuning on anything, they built a crazy 700HP turbo NSX track car.
Old May 17, 2011, 12:17 AM
evosam726's Avatar
ur mods on VIII turbo you'd get maybe 300 whp on mustang...
Old May 17, 2011, 08:08 AM
Nelson999's Avatar
Oh ok nice. Well isn't the 05 MR turbo the same as a 9 turbo
Old May 17, 2011, 08:53 AM
YogSaahoth's Avatar
No. It's still the smaller turbo with a 10.5 turb housing. Don't worry about what numbers you make...they dont mean anything...worry about finding someone who knows our cars well. If you can't find a good shop that tunes Evos often, you should go with distance tuning with Mellon or VRSF.
You are somewhat close to GST in Hayward...they would be a trustworthy place to bring ur car to get tuned. They have a mustang so be prepared for lower #s, but thats not really important. You wont need bigger injectors for those mods either
Old May 17, 2011, 08:59 AM
BLK_EvIL's Avatar
Nope 8 have diffrent comp covers. Id hit up a evo known shop FFTEC,GST, Boosted Tuning does my tuning (road tune) and always does a great job and very good pricing also your going to whant to convert to the tephra V7 rom lots of good features.
Old May 17, 2011, 09:52 AM
Nelson999's Avatar
Ok thanks guys how much do they generally charge for what I want?
Old May 17, 2011, 12:11 PM
BLK_EvIL's Avatar
dyno tune with boost leak test probly around $500 if they install fuel pump and ic pipes add maby 150-200 more
Old May 17, 2011, 05:43 PM
Nelson999's Avatar
oh ok not bad. i cant wait for some power
Old May 17, 2011, 05:49 PM
fugiwara's Avatar
Exclamation
I had about the same setup as you when I first got tuned (05mr).
I strongly suggest you get cams then a tune. Cams makes so much difference on our evo8 engine, because evo 8 has weaker intake cams compare to evo 9.
In the future if you want more, then do the turbo.
Listen to my advice and you won't regret it.
Quick Reply: What dyno numbers should i expect with my setup??
