Feb 11, 2008, 11:19 PM
Personal Sales Rating: ( 1)
How much does mivec on the evo help with spool up of a big turbo compared to a evo 8?
How much does mivec on the evo9 help with spool in rpms of a big turbo compared to a evo 8 that has no mivec?
Offline
Feb 12, 2008, 11:21 AM
Personal Sales Rating: ( 0)
Drives: evo 9, 4g Eclipse
huh? the 8 does not have mivec,
but I think you mean cams right, your talking about lift not timing overlap correct?
Offline
Feb 12, 2008, 05:10 PM
I didnt say the evo 8 had mivec
Offline
Feb 12, 2008, 05:25 PM
oh I read that wrong, sorry.
well it helps spool a little bit maybe 200rpm, but the big thing about it is it provides more torque. more air during the low RPM helps "push out" the combustion exhaust, increasing VM which is a good thing.
Offline
Feb 12, 2008, 10:16 PM
Like how much more than a evo 8, what do you mean?
Offline
Feb 13, 2008, 11:27 AM
well say about 15 or so, you get more area under the curve. I guess do a search for dyno graphs so you can see.
Offline
Tags
4g, big, cost, disable, eclipse, evo, evos, lemmon, mivec, spool, spooling, spools, technologies, timing, turbo, viii  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
