Quote:
Originally Posted by gunzo
Everything you found on the Airtrek forums are just speculations .. heck even the engines and gearbox are different .. and yet everyone think its the same because it has the same names (ie 4G63 and W5A51)
The ECUs are the same .. but there's like 3 or more pinouts that's different ..and those 3 pinouts are the ones burning up things .. I'm probably only 100.5% sure  since I've only burnt one before .. sorry ..
I have had a stripped back GTA and my Airtrek Turbo side by side for several days comparing the two. There are SO many similarities its actually easier to list what not in common
Turbo and Intercooler - TD05HR-15 vs TD04HL-16T
Brembos - Airtrek got stuck with the brakes from an Evo4
AYC - AYC was available as an OPTION on 2005 Airtreks
Center Diff - Active vs Viscous (off the RS)
Interior - The GTA is bloody awfull like the EVOs
Upper Body - Ones a sedan and ones a wagon
Lack of front strut brace
Injector and fuel pump size - 510cc vs 450cc and 175lph vs 145lph
Intake manifold - Evo one vs the NA one on the Airtrek!!
Intercooler Sprayer - All the wiring is there on the Airtrek just no bottle etc
Rear suspension arms - Forged on GTA -standard on Airtrek(can be replaced though with Evo7 RS ones)
Headgasket - Thinnier one on Airtrek giving 8.8 comp ratio Vs 8.5
Extra Trans cooler - Compared to 2002-2004. Mine came with two
Things that standout as the same
Gearbox is the same - Im looking at a GTA one as I write this, as I have one as a spare
Floorplan - Chassis is identical
Shocks - The measurements of the shocks are identical there is just more gap made in fender of the Airtrek
Steering and Steering rack - Both Evo 7
Radiator
Steering wheel
Exhaust
Carpet
Cams
Pistons-block-water pump-valves etc etc
The whole wiring loom for engine
MAF and intake
Bypass valve
Just remeber that our cars are watered down evos and for very little money Ive been able undo the damage
that had been done.
Some of which GTA owners do, like getting the larger size turbo and 10.5cm exhaust housing. Everyone replaces their Injectors and Fuel pump when they start to give their cars heaps.
Cams follow petty soon
and so on and so on.
Major things that were pretty cheaply done on my car for handling
Evo9 RS rear mechanical LSD
Evo9 RS front mechanical LSD
Evo 8 Front strut brace
RSR Titanium springs (for an evo7)
Evo7 RS Forged arms etc
Brembo Brakes and Discs
I prefer the viscous center diff which is inherited from early evos. Not a great fan of ACD.
The GTA is an obvious thing for Misti to do, but they must have been on drugs when they thought of the Airtrek.
Its such a mixture of parts from old and new Evos- but in a SUV crossover body.
But I like mine- Its as quick an Evo (well quicker than a standard one at mid 12sec 1/4 with current tune)
Handles 95% the same but with a little less rigidity in the rear (will be fixed with rear strut brace and Cusco lower brace)
Much nicer interior
AND ITS NOT A COP MAGNET
