Jan 4, 2009, 02:34 AM
#736
Personal Sales Rating: ( 0)
Drives: 91 Eagle Talon TSi
Awesome! Should be real interesting results on race gas.
Offline
Jan 5, 2009, 08:45 AM
#737
Silver Sponsor
Personal Sales Rating: ( 28)
Drives: 05 EVO & 91 Stealth TT
I didn't get around to doing the race gas tune, the local shop that keeps it in stock was closed when I went by there.
I did some playing on the street this weekend and had some lockout issue...I was experiencing this before the transmission let loose and hoped that the fresh tranny would clear that up but it didn't. My transmission guy thought the clutch looked like new so I didn't have it freshened up while it was out. I haven't upgraded the stock shifter bushings so maybe that's a possibility. I'll probably call David Buschur and see what he suggests.
I did wire up a remote switch to my greddy profec b spec II so that I can flip from low to high boost with the press of a button on my steering wheel. I did a test launch at low boost (20psi) and it was much much more manageable than the normal boost that causes ridiculous wheel spin (30psi) and when I shift to 2nd I flip the switch to unleash hell
Offline
Jan 5, 2009, 09:30 AM
#738
Personal Sales Rating: ( 2)
Drives: 2003 Mitsubishi Lancer Evolution
Sorry to hear about your lockout issues. Being a long-term victim, I'll love to hear what fixes it. I don't live close enough to Dave's shop, unfortunately, so I'm going to get up to AMS to have them make the thing shift like butter. I've ached through this with multiple clutches and even multiple transmissions.
Keep us posted and try that race gas!
__________________
Apex Silver '03 VIII
Buschur Racing Intake, Deluxe FMIC, IC piping, TB & IM, 880s, ported exhaust, SS O2
FP's WR8 Turbo, 10.5 Hotside, HKS 264i/272e, DLI II Ignition Amp
RnR Racing 3"TBE, Works HF Cat, APS BOV, Hallman Pro RX MBC
Shep Trans; TRE Rear Diff, Stage 4 TC
ROBISPEC ///
Mellon Tuned
... she likes bein' forced ...
Offline
Jan 5, 2009, 09:51 AM
#739
Silver Sponsor
yep, I went through it before with the exedy twin hd, but only when it was near the end of it's life and the pedal was out of adjustment. I spoke to Dan at Buschur and he and I both feel like it's probably the tilton being worn down. I'll check the adjustment again and make sure I'm pushing it in far enough to release it fully before I do anything else. he was really helpful.
Offline
Jan 6, 2009, 10:58 PM
#740
Personal Sales Rating: ( 7)
Drives: TB Evo 8
Wow. Last time I read this thread in one sitting back in Sept. I believe. Your evo has always been awsome, now it is just nasty.
__________________
Swift-R springs, DBA Discs, Fujita U, L, and intake pipes, FP White(waiting to put in Red), AMS FMIC, HKS 272 I&E, ported ex. mani, Invidia DP, TP, Greddy CB, walbro, synapse BOV, Buschur MBC.
Parts waiting to be installed:
ported, coated Red W/ 80mm
Speed density setup
1200cc injectors
Manley TT rods
Wiseco Pistons
Supertech dual springs/retainers
etc....
For sale: FP white rabbit ~10k, no play, broke stud.
Offline
Jan 7, 2009, 09:02 AM
#741
Silver Sponsor
thanks ^^
I put the EVO on my steep driveway and in 1st gear, pressed the clutch pedal in to find out where it's releasing and it's about half way down the clutch pedal throw which is higher than I expected and this is after I adjusted it out about as far as it will go. So I'm pretty sure the clutch is just worn down and I wasn't going down far enough to cleanly disengage while racing previously.
I have a road trip and race coming up on the 24th so I just need it to make it through that and I'll be pulling it back out.
Offline
Jan 10, 2009, 02:24 PM
#742
Silver Sponsor
Offline
Jan 12, 2009, 07:46 AM
#743
Silver Sponsor
I had a race setup last night and it fell through but I did do a single g-tech pull on the drag radials.
I let up early in 4th and shifted to 5th to coast to the finish line.
It still went:
60 1.77
1/8 6.9 @ 105 IIRC
1/4 10.8 @ 128
this was lifting to shift and blazing the tires through first gear on low boost (20psi) then going to 32psi once I shifted to second gear.
Offline
Jan 12, 2009, 10:24 AM
#744
Personal Sales Rating: ( 23)
Drives: 03 Evo VIII, 96 Beretta
awesomeness! how does the tranny feel now that it is bushwhacked?
dan just called me about an hour ago, he has to replace 2nd thru 5th because everything is worn so bad  oops!
his first words, "how much power was that car making"
__________________
Buschur Racing Powered / HTA86
576 whp / 432 trq (DLL Dyno) Stock Block/Head/ECU/Tom Klemann tuned
http://www.buschurracing.com
Offline
Jan 12, 2009, 10:30 AM
#745
Silver Sponsor
daily driving it's been great but I was getting locked out some. I've re-adjusted the clutch pedal and it's worlds better. I think the tilton is starting to show it's age. I did some quick shifts last night and no lockouts, but am hesitant to power shift it until I really need it. I have a big meet coming up on the 24th and I just need it to last through that then I'm probably going to send it off to be freshened up.
2-5 eh, nice job!
Offline
Jan 16, 2009, 01:30 PM
#746
Drives: Evo 9 GSR SE
Offline
Jan 16, 2009, 01:33 PM
#747
Silver Sponsor
yeah I bought one during my previous frustrations with the exedy twin when it wore out....It's sitting in a box.
Offline
Jan 16, 2009, 09:21 PM
#748
Silver Sponsor
ok, I finally gave up on the MT slicks and 17" stock rims...mounted multiple times and it just isn't working for me and I'm tired of spending money on it.
so, in the last 24 hours I ordered:
Motegi Traklite 15" rims which weigh about 10lbs each
MH 15" DOT radial which will give me way more sidewall for launches
Small brake kit for the front which includes rotor, caliper and pads so the 15" rims will clear.
Hopefully this will drastically improve my traction on the street/strip over the current stock 17" rims and BFG Drag Radials which are considerably heavier.
Offline
Jan 17, 2009, 07:39 AM
#749
Personal Sales Rating: ( 11)
Drives: mitsubishi evo 8
good luck with that set up!
__________________
05 GSR
Mellon DLL 400whp 382wtq 93 pump only ~29PSI
VDR 5.71 (Dynojet Mode)=417WHP 405wtq 93 pump only ~29psi
Tuned by Mellon
|Built 2.0 liter short block (stock compression), stock head|
|FP Green turbo|Ebay 3" TBE with resonator|Buschur SS ported o2 housing|
|Buschur Jet Coated Stock NON ported Exhaust Manifold|
|Buschur Cone Filter|HKS 272 cams| PTE 680's|
|Walbro 255lph |ETS 3" FMIC| ETS LICP Stock UICP|Samco I/C Hoses|
|ACT clutch|ACT flywheel|APS DV|Joe P MBC|
Offline
Jan 17, 2009, 10:04 AM
#750
Silver Sponsor
I went out this morning on c16 and eased the boost up to 40psi...some pretty nice gains after 8 or so tuning pulls. I haven't touched the timing yet so there may be more in it. The EBC solenoid died on the last pull, it isn't reading boost and only gives me wastegate boost (20psi) now. I have a spare solenoid and will be changing it out later, I hope that works.
the first chart is the new one and the second is c16 @ 40psi vs 93 @ 33psi. Keep in mind I went 10.41 @ 135 when I had 600awhp in DLL with a 1.68 60' on the 17" BFG drag radials
Offline
Tags
05, 16g, 35r, 40, begun, big, build, ecu, evo, flash, iii, mellon, psi, rom, stock, tuning, turbo, turbos, twin, v8  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
