Mar 3, 2008, 04:16 PM
#421
Personal Sales Rating: ( 0)
Drives: 05 Evo8
Really though, it makes me nervous too, the close proximity to the new tubular manifold, but at the same time you gotta give it up for doing just what Chris is doing... only what is necessary for performance.... I think by now he would have found out if it was going to cause a problem, I expect coolant temps to slightly rise with more power produced, so it might be hard to tell if that is heating up the coolant b/c of that, or just from the hose being close.
Have you noticed any raise in coolant temps since installing the kit?
__________________
FP HTA Green-ProEfi ECU-Switzer Performance
517awhp/491tq E85
Offline
Mar 3, 2008, 06:09 PM
#422
Personal Sales Rating: ( 8)
Drives: 05 electric Blue Evo, 04 Blue R1, 95 Nissan pickup lowrider
Hey Chris I noticed you dont have T-clamps. Have you pressure tested your system for leaks? With that much psi I would think so. I have that same upper I/C pipe from Buschur and found it leaking with worm style clamps like you have. I recently changed them over to the t-clamp style and fixed my leaks. Im only boosting to 22psi max also. This might  you.
__________________
3" turbo back exhaust , Forge MBC, Walbro 255 fuel pump ,Helix lower I/C piping, Exhaust Manifold with o2 housing, Synapse BOV , huge I/C, 272 HKS cams, Head studs, Buschur Upper i/c pipe, Braille mini battery, Buschur intake pipe with cone filter, ported and polished intake manifold, 65MM Throttle body, Meth with 50/50 mix, 30psi custom tune by Chris Black at AMS
380WHP
392WTQ
JDM rear bumper
Offline
Mar 4, 2008, 08:00 AM
#423
Silver Sponsor
Personal Sales Rating: ( 28)
Drives: 05 EVO & 91 Stealth TT
as for the coolant hose, if it hasn't burned by now it's not going to, I've had the car way past 160mph in some 5th gear pulls, no issues whatsoever. It does have header wrap on it just in case.
I have pressure tested the system but not up to 30psi..maybe 20psi max. I don't like that tester fitting shooting out like a cannon. I don't like using t-bolt clamps unless I have a hose that keeps blowing off.
Offline
Mar 4, 2008, 10:04 AM
#424
Drives: 2005 Mitsubishi Evolution VIII
Man that engine bay is like pure sex.
How did your Evo do the other day?
Offline
Mar 4, 2008, 10:05 AM
#425
^ Oh, hardcore pure sex... btw.
Offline
Mar 4, 2008, 11:11 AM
#426
Drives: 05 Evo8
Quote:
Yea, I noticed in your other forum
+1 on the flying tester, almost got owned by one of them myself last summer...
__________________
517awhp/491tq E85
Offline
Mar 4, 2008, 11:50 AM
#427
Silver Sponsor
terrible, just before the race I noticed the clutch was dragging (notchy shifting and grinding going into reverse)  I managed to adjust it out and thought I was good to go but the engagement was so close to the floor board that I bogged the launch twice losing both races I had setup
Offline
Mar 4, 2008, 12:29 PM
#428
In the immortal words Homer Simpson, "D'oh!"
That sucks to hear about your clutch.
Offline
Mar 4, 2008, 04:30 PM
#429
Drives: 05 Evo8
lol, its ok... just give them a false sense of security.... they won't know what hit 'em next time
__________________
517awhp/491tq E85
Offline
Mar 4, 2008, 05:45 PM
#430
So is your clutch done? Time for a rebuild?
__________________
380WHP
392WTQ
JDM rear bumper
Offline
Mar 4, 2008, 06:11 PM
#431
Personal Sales Rating: ( 61)
Drives: Evo 8
If its your clutch...you can convert that it to triple.
Offline
Mar 5, 2008, 06:55 AM
#432
Silver Sponsor
I don't think the clutch is done, it's doing fine now that I've adjusted it...in hind sight I think I was letting the clutch out too quick for the adjustment point and it was bogging. I need to slip the clutch and get the car rolling before going wot
Offline
Mar 5, 2008, 04:48 PM
#433
Drives: 08 Lancer GTS CVT WW
That sucks Chris. But anything else new?
__________________
-Chris
2008 Wicked White Lancer GTS CVT
| Tein S-Techs Springs | Injen Exhaust | 6k HIDs | ARC Knob | JDM Antenna | Flat Black Volk CE28N's 18x8.5 +30 | Injen CAI | RalliArt Taillights | Vinyled Matte black roof |
illest
Offline
Mar 6, 2008, 07:01 AM
#434
Silver Sponsor
not much, picked up some vacuum hose for the EBC, hope to get some time to play with it this weekend. I hit a snag with the Stealth rebuild, found the front exhaust cam had two bad lobes and rockers, I'm not sure if the rocker came loose or what. I have Dynamic Racing making a replacement cam for me so that's a 2 week delay.
Offline
Mar 7, 2008, 07:22 AM
#435
Silver Sponsor
I ditched my home depot MBC for a Greddy Profec B Spec II last night and dialed it in for a peak of ~ 30.8psi but snow is coming so I'm not sure when I'll get g-tech/dll/track times yet. Hopefully this weekend.
Offline
Tags
05, 16g, 35r, 40, begun, big, build, ecu, evo, flash, iii, mellon, psi, rom, stock, tuning, turbo, turbos, twin, v8  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
