I posted this on
www.*************** to see people's thoughts, so I figured I'd do the same and post it here...
Ok, so if you're like me, you want an MR, but are hesitant to get it due to the fact that it has the SST rather than the 5MT.
I figured we could start a thread and list our worries about the SST transmission, and if any of us heard anything that should put a given fear to rest, we could quote the person and post the reply.
Now, as I understand it, there is a normal mode, sport mode, and supersport mode. Fee free to correct me if I'm wrong here.
The normal mode is sufficient for putting around town, and it automatically shifts for you.
The sport mode is more aggressive, shifts faster, and at a higher RPM. I think in this mode will allow you to do the shifting, unless you hit redline or so, in which case it will shift for you.
The supersport mode is like sport mode, except it won't ever shift for you, with the exception of the case where you go WOT at a low RPM, it will auto downshift for you.
So without further ado, my fears, worries, and questions:
-I'd honestly like the car to start off in sport mode by default. It will just help me feed connected to the car. If I wanted it to shift for me, I'd like to specify that, not have it be that way by default. Can I change this?
-In supersport mode, I think it's cute how it will auto downshift for you, but really, I'm fine. I'd rather not have that happen. After all, for tuning purposes and dyno pulls alone, I wouldn't be able to do what needs to be done if it was constantly downshifting for me. I'd want to change this. Would I need a TCU hack? some kind of piggyback? Would it be possible at all?
-I know how to fix a 5MT. I do it more often than I'd care to. I know jack**** about how the SST works internally. Will they be harder to work on than a traditional 5MT?
-The trans weighs ~50lbs more than the manual. Sure, we can't fix that, but I'd just like to complain about that.
-Will the TCU (transmission Control Unit) be a thorn in my side? Will it be another obstacle while modifying the car?
-How robust is the transmission itself? Will it be a limiting factor in terms of power? How about the clutches? Ultimately will this transmission be more limited in terms of power than a manual?
-Upgrades - will this transmission be more or less upgradeable than the 5MT?
-If it gets totally destroyed, will I have trouble finding one used? Will it cost me an arm and a leg?
-This is a first gen trans for mitsubishi, vs the 5MT that's a more robust version of its predecessor. Since it's first gen, will it have glitches and issues? If so, will the 2nd gen bolt up to the engine and work as a drop-in replacement?
That should be a good start. Post any that I may have missed, and feel free to answer any if you have good info.
