Oct 17, 2007, 01:02 PM
Personal Sales Rating: ( 0)
Drives: 03' EVO8, 92' MR2 Turbo
EVO X turbo Info
All:
I thought I'd start this thread and hopefully over time we'll get more information about this turbo. Anyone have any real specs on it? Flow charts? Maximum boost pressure? Comparison to the EVO VIII/EVO IX turbos?
-M
__________________
03' EVOVIII - exhaust+meth+boost@25psi
92' MR2 TURBO - exhaust+boost@17psi
Offline
Oct 17, 2007, 01:20 PM
Drives: 08 Graphite Gray Pearl X
Hmm maybe, some people in Japan can get more info since there selling there allready!
Jeez if I lived in Japan I'd have a whole gallery of pics and info to post..
You know.. not just the same TYPES OF PICTURES
-ACTUAL DEALER COST, INCLUDING MARKUP
-VIDEOS
-BETTER PICTURES OF THE BROCHURE
-TRANSLATE THE BROCHURE
-GO ON A TEST DRIVE
Offline
Oct 17, 2007, 01:28 PM
Personal Sales Rating: ( 4)
Drives: 2006 Evolution IX (Traded) 2008 Apex Silver EvoX GSR
It's Japan what do you expect???
__________________
1995 Mazda RX7 GT35R
2008 Chevy Duramax Sleeper
2006 Cadillac CTS-V
72' K5 Blazer
72' Camaro - 9 second street car.
06' Wicked White Evo IX GSR - Gone but not forgotten.
10' Graphite Grey Evo X GSR.
Quote:
Originally Posted by btownsoccer22
I just got my evo last week and I'm wondering is it common to hear a beeping sound from your car? Its not like a beeping sound where it beeps then stops then beeps again its just continuous
Quote:
Originally Posted by boobcakes
it's your ejection seat.
exactly what is that? can i fix it by myself?
Offline
Oct 17, 2007, 01:32 PM
Personal Sales Rating: ( 1)
Drives: 05 Evo VIII
Is it really a 15G turbo? I heard that it's 15 and the markings on the turbo did say 15.
Offline
Oct 17, 2007, 02:01 PM
Personal Sales Rating: ( 2)
Drives: 1960 MGA roadster
Offline
Oct 17, 2007, 02:10 PM
Quote:
No. It's not a Mitsu turbo. It's a Warner IHI turbo. Same make on the Mazdas.
-M
__________________
Offline
Oct 17, 2007, 03:02 PM
Drives: evolution viii
somebody had post the type of the turbo which is TD05H-152G6-12T ...
this is a mitsubishi turbo not an ihi...
Offline
Oct 17, 2007, 03:08 PM
"We looked, and there's plenty of space in there for larger turbos once the stock TD05H-152G6-12T is maxed out."
source: http://www.edmunds.com/insideline/do...leId=122744#21
It doesnt say who makes it, but it confirms the post above regarding the model/part number for the turbo.
Offline
Oct 17, 2007, 03:14 PM
Drives: no more Evo
Quote:
-M
Warner and IHI are 2 different companies. Borg Warner bought out KKK, and is based in Europe. IHI is based in Japan.
Offline
Oct 17, 2007, 04:05 PM
Quote:
You are partially correct - they did merge..
"IHI Turbo America (ITA) was founded in 1980 as Warner-Ishi Corporation a 50/50 joint venture between IHI and Borg Warner Automotive and a licensee of IHI turbocharger technology."
http://www.ihi-turbo.com/companyinfo.htm
__________________
Offline
Oct 17, 2007, 04:11 PM
Hmm.. this is interesting.
I'll change the title of the thread then. A 15G is certainly not going to put out more power than the stock 16G-type turbo that came with the last generation.
-M
__________________
Offline
Oct 17, 2007, 07:37 PM
Drives: 92 Talon AWD, 01 BMW M Roadster
-M
If you knew what the 15g stood for, you would know that it very well may flow more and be smaller diameter. The exhaust side is bigger.
Offline
Oct 20, 2007, 12:17 AM
Quote:
Flowing more on the exhasut is only half of the equation. There's no use in having a larger hot side and a smaller compressor wheel. Airflow will still be restricted.
-M
__________________
Offline
Oct 20, 2007, 10:13 PM
-M
If you read what I said you would see I was talking about the compressor side. Just because the compressor wheel is slightly smaller diameter, that doesn't mean it will flow less. We are only talking about a 5% diameter change, but if the wheel is wider or has better blades, it may still flow more. Only time will tell, but this should be another great stock turbo. The Japanese literature said it flowed 14% more than the IX turbo did.
Offline
Oct 20, 2007, 10:47 PM
Personal Sales Rating: ( 6)
Drives: 07 Fit Sport
what does it matter who makes it? a TD05 blah blah blah turbo is different if IHI or Mitsu makes it?
i think the X will run a slightly larger turbo, but less boost than the 8's and 9's
Offline
Tags
08, 12t, 152g6, 16g, borg, change, evo, gsr, ihi, japan, specs, td05h, turbo, turbos, warner  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
