Enhance the cornering performance of your EVO X with a set of Hotchkis Sport Suspension sport sway bars. Our sport sway bar package increases front/rear roll stiffness giving the car crisp, quick turn-in response and balanced handling. As delivered the EVO X has slight under steer and limited roll control. Sport sway bars give the driver the ability to rotate the car on corner entry and steer with the throttle when necessary. The dreaded under steer is eliminated and the handling becomes comfortably neutral with added traction during cornering. Hotchkis Sport Suspension sway bars feature a durable powder coat finish, greasable bushings, and brackets.
Features:
• Lightweight, Durable 1 1/4" (32mm) Tubular Front Bar 2 Way Adjustable, +50%, 70%
• Lightweight, Durable 1 1/4" (32mm) Tubular Rear Bar 3 Way Adjustable +155%, 195%, 245%
• Premium mounting hardware including, greasable polyurethane bushings and heavy duty brackets.
• Finished in durable anthracite powder coat.
Benefits:
• Brings handling excitement to your Evo X
• Dramatically improves steering and chassis response
• Increases stability, improves traction, reduces body roll by increasing front/rear roll stiffness
• Easy bolt-on installation.
$$375 + Shipping!!!!
ONLY 2 Sets in stock!!!
