Feb 20, 2009, 12:01 PM
Silver Sponsor
Personal Sales Rating: ( 20)
Drives: 2004 STi
KW V3 - Custom rates available from suspension people!!! Ohlins Cobb Swift too!!!!1!!
KW Variant 3 Coilovers for EVO X
$2229 shipped
KW got it right this time. These are awesome out of the box, but custom rates are available to match your needs.
Standard spring rates 9k/10k
Stainless steel corrosion free construction.
Tons of damper travel.
2 way valving adjustment - seperate compression and rebound.
These are performance coilovers, not show car, dump to the ground, bounce down the street coilovers.
Great handling, wide range of damping adjustment, good spring rates, lots of travel.
$2229 shipped
CALL to order. Custom rates available for all applications.
410-579-1501
Offline
Silver Sponsor
Drives: 2004 STi
[center] Ohlins DFV Sportlines for EVO X
$3495 + shipping.
These are rebound adjustable, threaded body dampers. Height is adjustable at the spring perch and the lower mount for separate preload and ride height adjustment. Front camber plates and rear pillowball mounts are included. Everything you need to put on one of the best handling and riding suspensions for you EVO X.
We've worked extensively with the Ohlins DFV Sportline for EVO 8 and 9 kits with DaWorstPlaya, who tracks, autocrosses, and daily drives his car. We can provide real, experienced suspension feedback, guidance, and after sale support. We are suspension people who work with this stuff everyday and understand the theory and real world application of these parts.
If you have any questions, feel free to give us a call or PM us.
- Andrew
Offline
Feb 20, 2009, 12:02 PM
Silver Sponsor
Drives: 2004 STi
Cobb swaybars discontinued. buy whiteline.
Offline
Silver Sponsor
Drives: 2004 STi
I'm gonna keep this short and simple.
Swift Sport Springs for EVO X - $315 shipped
1 inch drop front
.6 inch drop rear
4.3 kg/mm front
4.4 kg/mm rear
410-579-1501
Offline
Feb 20, 2009, 12:03 PM
Silver Sponsor
Drives: 2004 STi
Cobb Springs for EVO X
$250 shipped
Direct replacement for the factory springs, and designed to work with the factory struts and shocks, the COBB Sports Springs reduce the front ride height by 1 5/16" and 1 3/8” in the rear. Spring rates are approximately 10% stiffer for both the front and rear, which results in a sporty feel without being unnecessarily harsh or bouncy.
Offline
Feb 23, 2009, 11:50 AM
Silver Sponsor
Drives: 2004 STi
bump! we know what we're talking about when it comes to suspension! just don't expect us to build you any 600 whp turbo setups!
- drew
Offline
Feb 25, 2009, 01:20 PM
Silver Sponsor
Drives: 2004 STi
bump!
Offline
Feb 27, 2009, 01:54 PM
Silver Sponsor
Drives: 2004 STi
bump...when you have suspension questions we will have suspension answers.
Offline
Mar 3, 2009, 09:35 AM
Silver Sponsor
Drives: 2004 STi
2229 shipped for KW's.
includes free suspension knowledge.
Offline
Mar 6, 2009, 08:51 AM
Silver Sponsor
Drives: 2004 STi
bump!
Offline
Mar 9, 2009, 10:40 AM
Silver Sponsor
Drives: 2004 STi
tops! hard to beat ohlins and KW....and if you want the JRZs to do it, we can help you there too.
Offline
Mar 10, 2009, 12:49 PM
Silver Sponsor
Drives: 2004 STi
bump!
Offline
Mar 10, 2009, 02:54 PM
Personal Sales Rating: ( 2)
does the KW use the stock top hat? is there an extention knob for adjusting the rear damping?
Offline
Mar 11, 2009, 12:00 PM
Silver Sponsor
Drives: 2004 STi
No extension knob for the rear....it's a bit of a pain but doable.
You can use the stock top hat. If you auto-x or track the car frequently we can do camber plates too.
- Andrew
Offline
Mar 17, 2009, 08:37 AM
Silver Sponsor
Drives: 2004 STi
tops!
Offline
Tags
adjusting, custom, dfv, evo, increase, kw, ohlins, people, rate, rates, rebound, spring, suspension, v3, variant  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
