Artisan performance is proud to announce it release of the Street Assassin 50 for the new EVO X. This is the world’s first bolt on turbo upgrade for the new Evolution X. The SA50 is a 100% direct replacement for you stock EVO X turbo providing a 35% increase in overall volume. The SA50 has been dyno proven to put down over 450whp on pump gas and propel a full weight EVO X to high 11 sec time slips at the track.
Specs:
* Housing: MHI 12cm
* Compressor Wheel: 50mm
* Turbine Wheel: TD05H
* Compressor Cover: MHI/Artisan Spec
* WHP:475-500
* Max Boost: 30-35psi
* MISC: 360 Thrust bearing, upgraded actuator highly recommend to stop boost
taper.
$1000 shipped anywhere inside the 48!!!!
