Oct 15, 2009, 08:26 AM
Gold Sponsor
Personal Sales Rating: ( 5)
Drives: 05 STI, 06 EVO IX, 91 RWD DSM
EVO X Heads, Blocks, Internals! Manley, Cosworth, Kelford, BC & more!!
We've been selling and building the 4B11 already and it's showing more and more promise... might have a little something something to share with you guys soon too. We'll see what happens!
We're really trying to take the bull by the horns here and offer some great products for those already looking to really make statements with this new beast!
We've already been working on cylinder heads and have over seas guys on some stuff to see how it goes. So far, it's pretty good! This thread will be our 1 stop engine parts thread for everything inside the 4B11! We're talking down and dirty!
Manley!!!
PLATINUM SERIES LIGHTWEIGHT PISTONS
9:1 Compression, standard and .20 over bore available!
TURBO TUFF I BEAM RODS
Manley Pro Series connecting rods are forged from aircraft quality 4340 vacuum degassed material. Each rod is fully machined in the Manley Lakewood, NJ factory to the highest standards. Our signature "Turbo Tuff" design combines the appropriate weight and rugged strength for ultimate horsepower applications. Each rod is shot peened after machining and magnafluxed. Bores are round and without taper. Bend and twist is tightly controlled. Cap fasteners are 3/8" APR 2000 cap bolts.
PRO SERIES VALVE SPRINGS RETAINER KIT
Manley valve springs are wound from super clean alloy. Each design minimizes stress to ensure long service life with high lift camshafts. Retainers are manufactured in our own double spindle CNC machines to exacting tolerances and precise installed height specifications.
Wiseco
We've got these 9:1 pistons in 85, 85.5, 86 and 86.5mm!
Brian Crower
Stage 2 - 272* Ok with stock springs
Stage 3 - 280* Requires Upgrade springs
Valve Spring and Retainer Kit
Designed for high rpm, BC valve springs are wound from only the highest grade, super clean, chrome silicone alloy and feature proprietary processing procedures for consistent pressures. BC titanium retainers are CNC machined from 6AL4V round bar titanium to exacting tolerances.
4B11 STAINLESS STEEL VALVES
BC valves are made from premium stainless steel, fully machined and swirl polished for ultimate air flow. Dished head for added weight savings and increased valve control at high rpm. Standard and oversize head.
4B11 STROKER KITS
The 4B11 stroker kit from Brian Crower features: - BC 4340 billet steel crankshaft (84mm stroke).
- Choice of 4340 steel billet connecting rods w/ARP fasteners.
- CP aluminum forged pistons (any bore size, any compression ratio).
- High strength steel alloy wrist pins for added longevity and reduced flex.
- Ductile iron plasma top rings, tapered second ring, low tension oil rings.
- Fully system balanced and ready to install.
- ACL Race Series rod and main bearings sold separately.
The BC stroker kit for the Mitsubishi 4B11T engine platform incorporates a 98mm stroke crank. Depending on bore size that you decide, the BC kit will take you up to a 2.5L with a sleeved 90mm bore. The kit utilizes premium steel billet connecting rods in your choice of fastener (ARP2000 or Custom Age 625+ for severe-duty). As usual, each BC kit features custom CP pistons, steel alloy wrist pins, full ring pack and locks.
I've got a lot more in the works folks! I'll be updating this constantly with the other engine parts we have available and the new cylinder head and short block offerings!!!
Thanks for your time and continued support. Remember, we WON'T be undersold!
__________________
Marti
AIM: Marti at Slowboy
321-304-4907 x.106
mar@slowboyracing.com
slowboyracing.com
WWW.SLOWBOYRACING.COM
Click for all of our latest promo, deals and products! Also for the car of the week for your $100 prize!!!
Offline
Oct 16, 2009, 10:33 AM
Gold Sponsor
Cosworth Engine Goodness!!!!
Needless to say, Cosworth is one of the best in the business. Their trail blazing product line is always a step ahead of most others and their quality is second to NONE!
We work very closely and directly with Cosworth to be sure to offer your their latest and greatest at a great price! Check out just some of their offerings below!
Cams!
Ground from new Cosworth billets, these camshafts for the Mitsubishi EVO X will provide substantial power gains while remaining drivable in all conditions. Additionally, these can be installed using the original valve springs if the original rev limiter is retained. If the rev limited is raised, upgraded Cosworth valve springs (20004845) should be used in conjunction with these cams.- Intake duration "266" deg
- Intake lift 10.8mm
- Exhaust duration "266" deg
- Exhaust lift 10.4mm
- Excellent torque and boost response
- Broad power band
- Valve spring upgrade recommended when factory rpm limiter is raised (Cosworth part number 20004845)
Valve Springs
Cosworth High RPM Valve Springs are wound from the world's finest Japanese Kobe steel and feature dual chamfered ends to reduce wear on seats and retainers. Our High performance springs have been engineered with increased seat pressure along with higher lift capability for optimum performance potential and improved valve control. Single spring design allows easy installation with no machining required and is perfect for typical high performance use. Compatible with OE spring retainers.
H11 Head Stud Kit
Essential for high performance engine builds, heavy duty head studs reduce cylinder head movement in high boost or high compression engines optimizing cylinder head to block sealing. Cosworth Ultra High Performance Head Studs are manufactured from H11 tool steel with 260,000psi tensile strength and come complete with nuts and washers. Manufactured with hex broach end for ease of installation. Additionally, genuine Cosworth head studs utilize a base seating feature to evenly distribute maximum load on the stud and not the threads. This feature is typically found only in high level race engines.
Head Gaskets
Cosworth High Performance Head Gaskets are engineered to seal in power under the most
demanding conditions. Constructed from stainless steel with a folded stopper layer, each application features superior sealing compared to conventional multi layer steel gaskets. Additionally, Cosworth High Performance Head Gaskets are manufactured from pre-coated
die cut stainless steel resulting in uniform coating distribution and consistent shape.
Please keep in mind, I am ALL about bundles! We can offer you complete packages to include cams, springs and fasteners for a GREAT price!!!
__________________
Marti
321-304-4907 x.106
slowboyracing.com
Offline
Oct 19, 2009, 10:32 AM
Gold Sponsor
Manley Valve Spring and retainer kits shipping now! We've got tons of great parts available now for immediate shipment!!!!
__________________
Marti
321-304-4907 x.106
slowboyracing.com
Offline
Oct 20, 2009, 01:30 PM
Gold Sponsor
Let's make some power! Talked to some great people doing some really big things! nice to see the EVO X community really stepping it up!!!
__________________
Marti
321-304-4907 x.106
slowboyracing.com
Offline
Oct 26, 2009, 02:59 PM
Gold Sponsor
EVO X Race Cylinder Head!
Hey folks,
We've been hard at work with our new EVO X Head Packages and they've been a hit!
Check out this cylinder head package! The head comes complete with the following:
-NEW OEM Casting
-Brian Crower Valve Spring and Retainer Kit
-Supertech +1mm Over Size Intake Valves
-Supertech +1mm Over Size Exhaust Valves
-New OEM Valve Seals
-New OEM Keepers
-SBR Extreme Porting
-SBR Performance Valve Job
-Assembled and Vac Tested
$3229
As of right now, we're talking a 1 week turn around!!!!!!
Got a good core to send back? We can make the deal even better!
__________________
Marti
321-304-4907 x.106
slowboyracing.com
Offline
Oct 29, 2009, 04:14 PM
Gold Sponsor
tomorrow will be the last day on most of these deals folks! Take advantage of the savings while they are offered. If there is something that you're looking for that isn't on this list, please let us know and we'll do anything we can to earn your business.
__________________
Marti
321-304-4907 x.106
slowboyracing.com
Offline
Nov 9, 2009, 01:50 PM
Gold Sponsor
Another EVO Cylinder head ready to go!!!
__________________
Marti
321-304-4907 x.106
slowboyracing.com
Offline
Nov 17, 2009, 12:24 PM
Gold Sponsor
We've got more Manley Pistons and Rods in stock!!!!
__________________
Marti
321-304-4907 x.106
slowboyracing.com
Offline
Tags
4b11t, bolts, compression, crower, evo, evolution, head, high, install, kit, manley, pistons, rating, spring, stroker, tensile, valve  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
