Cobb Version 2 Access Ports
Cobb Access Port Version 2
To order during after hours please order from the site! www.spun-autosports.com
The AccessPORT by Cobb Tuning, Inc. is a hand held programmer that allows you to unlock your
vehicle's hidden potential by reprogramming the stock Engine Control Unit (ECU). Performance
tuning data is uploaded to the ECU via the OBD-2 diagnostic port in a matter of minutes, and
requires no cutting, wiring, or other such modifications. Unique to the AccessPORT is the ability
to change tuning data on-the-fly without having to completely reprogram the ECU. This
technology allows the AccessPORT to get the most performance out of your vehicle in the least
amount of time.
Using off-the-shelf staged tuning maps along with the appropriate vehicle modifications, the
AccessPORT users can see power gains in excess of 50HP. Better yet, the AccessPORT truly
unlocks the ability to extract a vehicle's peak potential through custom tuning for any level of
modification.
The AccessPORT's features include:
• On-the-fly map switching
• Monitor vehicle sensor data and display in analog or digital format
• Vibrant color graphic display with First-Ever full 260,000 color OLED, high-resolution
screen
• Read/Clear engine trouble codes
• Preloaded with performance, economy and convenience maps
• Update via the Internet
• Measure 0-60 and ¼ mile times
• Adjustable on-screen Shift Light functionality
• Estimates horsepower and torque
• Displays current and averaged fuel economy
• Drag race simulation with reaction time and “time slip” data
• Built in on-screen help mode function
• Multi-Language support
• RoHS compliant (Lead Free design)
• Custom performance tuning for your specific vehicle and modifications as provided by an
authorized AccessPORT ProTUNER™ center, or upgrade to the StreetTUNER™
software package for do-it-yourself tuning
08+ EVO X $695
Defi Gauges
Link Imperial Gauges 60mm Lights up Amber or White
Boost
Oil Pressure
Fuel Pressure
Oil Temp
Water Temp
EGT
Link BF Gauges 60mm Lights up Red or White
Boost
Oil Pressure
Fuel Pressure
Oil Temp
Water Temp
EGT
Blue Racer Gauges 52mm Lights up Blue
Boost
Pressure
Volt
EGT
Temp
Defi Link Controller Needed for BF and Imperial Gauges
Tom
www.Spun-Autosports.com
412-760-2127
