Jul 24, 2009, 11:47 AM
Personal Sales Rating: ( 60)
Drives: 2007 Civic Si, 2008 Acura RDX, 1998 Civic Hatch, 1993 Civic Hatch
Apexi AFC Neo : 5 Available In Stock : $329 Shipped!!
We just got in a small batch of Apexi Neo's that have been on backorder forever. These are priced to go as we just dont need them here and would rather see you putting them to good use!! The Apexi SAFC has been around for years and with all the new features that were implemented on the Neo this is a perfect setup for a mildly modded Evo X.
APEXI PART #401-A917
MFG INFO : The AFC-neo is a multifunctional sub-computer that allows the tuner to fine-tune air-fuel ratios, calculate MAF/MAP transfer functions, control VTEC or other solenoids, address stall issues associated with open-air blow off valves, and monitor key ECU data.
Changes in air-fuel ratio are achieved by correcting the airflow sensor signal or pressure sensor signal at 16 different RPM points, and at high and low throttle positions, all of which can be moved according to the customers needs. By changing this input signal, the tuner can alter the injector pulse width as calculated by the ECU.
The AFC NEO is unique in the sense that it has a built in MAF/MAP transfer function, which is necessary when the tuner swaps MAF/MAP sensors from one vehicle application to another. By setting the sensor IN and OUT to the appropriate sensor numbers, the AFC NEO can act as a translator/emulator unit, eliminating the need for costly sensor or ECU reprogramming.
The unit also has a VTEC solenoid control function that allows the tuner to change the VTEC engagement/disengagement point on Honda VTEC systems (not compatible with iVTEC systems). The VTEC solenoid control and also be used to control other types of solenoids as used in nitrous-oxide and water/methanol injection systems.
On MAF applications with open-air blowoff valves, there is a deceleration air correction feature that allows the tuner to compensate for the over-rich condition that occurs at throttle-off. By adjusting the MAF signal at throttle-off condition, the tuner can reduce the amount of fuel injected and prevent stalling.
In monitor mode, the driver can monitor digital engine RPM, throttle position, battery voltage, airflow sensor capacity usage, pressure sensor data, Karman frequency, MAF/MAP/Karman correction factor, and solenoid on/off status.
The AFC NEO is a universal unit that can be used on a wide range of cars and trucks that have an air metering system that uses a VAF, MAF or MAP sensors operating within the 0-5 volt range, as well as applications using Karman sensors. There are some unique applications that do not allow for the proper functioning of the AFC NEO. If you are not sure, please contact Apex for assistance.
Please call us at 866-703-8794 to order. In Store local pickups are always welcome but please add 7% PA Sales Tax. We accept Visa, Mastercard, American Express and Discover.
Thanks
Import DPS
Offline
Aug 18, 2009, 01:15 PM
Still have 2 left EvoM
Offline
Aug 24, 2009, 03:44 PM
Offline
Aug 25, 2009, 10:15 AM
Thanks for the orders!!
Offline
Aug 27, 2009, 03:58 PM
Bump!!! Still available!!
Offline
Aug 31, 2009, 11:27 AM
2 Left!!
Offline
Sep 2, 2009, 12:29 PM
Bump!!
Offline
Sep 3, 2009, 10:38 AM
Bump!!!
Offline
Sep 8, 2009, 11:13 AM
Offline
Sep 9, 2009, 10:14 AM
Bump!! Still available
Offline
Sep 11, 2009, 04:31 PM
Bump!!! Plenty of Parts in Stock!!
Offline
Sep 14, 2009, 07:17 AM
Bump!!!!
Offline
Sep 17, 2009, 11:40 AM
Get them while there on sale!!
Offline
Sep 19, 2009, 09:58 AM
Import DPS is your #1 Source for all your Mitsubishi Evolution Parts!!
Offline
Sep 22, 2009, 09:19 AM
Offline
Tags
2009, 401a917, afc, air, apex, apexi, civic, computer, controller, decel, feature, fuel, neo, safc, si, tuner, vaf  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
