Clutch/Brake Fluid Resevoir Cap Missing (fluid low and clutch pedal drops to floor)
Hello everyone. I was hoping that someone could help me out here with something. Just for reference i drive an 06 9 MR
So today i woke up for class and got into my car and started it up. I put the car into reverse and let out on the clutch (exedy twin HD) and suddenly stalled. Thinking that i just didnt know how the hell to drive i started the car up again inwhich it took 3 trys of turning the car over for it to start again. I put it in reverse and pulled out of the spot. I then Put the clutch in to shift to first gear and BAM my pedal went straight to floor. (i thought to myself that CLEARLY that isnt good)
So i popped the hood and checked everything out. I then noticed that the Twist Cap to the Clutch/Brake fluid reservoir was mysteriously missing and the fluid was a bit below the MIN line on the reservoir. I have no idea what the heck happened to the cap. I searched the engine bay and found nothing. I am guessing that i lost pressure to the clutch line and thus that is the reason why i cannot get my car into gear at all because i cannot press the clutch in (it just drops). If i pull the clutch towards me it sort of POPS into a secure position. Then you press it and it POPS back out.
So basically i am wondering what the heck should i do?? I obviously need a new cap.
I am wondering this....
Can i just get a new cap and fill the reservoir back up, stick the cap back on and everything will be fine?? Or do i have to do something else? Like do i have to put the fluid in put the cap on, pump the clutch, bleed the line, REMOVE MY ENGINE??
Any help would be great.
Thanks!
Thanks!
thats crazy that it just disappeared.
get a new cab, refill the reservoir, and you should really bleed the clutch system to get any air that got in out..
then back to normal, everything should be fine.
i bet if you search the how to section you can find a write up on how bleed the clutch system. extremely easy and simple.
Would you think that if i bleed the line with a MOTIVE power bleeder then stuck some rubber stopper in there and Duct taped and electrical taped the **** outta it do you think that would be sufficient enough to work for a couple of miles?
Steps so far are
1. Fill motive bleeder up 1/4 - 1/2 full of DOT 3 or 4 brake fluid.
2. Pump Motive to 15 psi
3. Bleed the system out.
Now this is where i am not sure what to do. Obviously if you just hook up the motive and pump it will force fluid through the system but the fluid wont have anywhere to go...
So this is the part where the bleeding comes in
Is there a screw on the Clutch/brake fluid reservoir that i need to turn in order to bleed the fluid and air out?
Also once you release this screw (which i am not sure where it is on the reservoir) fluid will start coming out and i assume that **** is not good to get all over stuff.
So i have come across this TUTORIAL
http://www.joe250.com/cars/evo8/brak...ebleeding.html
If you scroll down it shows you how to make a catch bottle but it does not show you WHERE to connect the bottle and the tube to.
that tutorial is for bleeding the brakes. So therefore it shows you where to connect the catch bottle to on the calipers but it does not show you where to connect it to on the Reservoir in order to do the clutch.
Ok scratch this thread haha
I just fixed it. I topped off the reservoir and bled the line. Pumped the clutch topped it back off bled the line again pumped it again etc and now the clutch is back.
Thanks again!
Thanks again!
Jacks Transmissions
Jacks Transmissions
50
Feb 20, 2016 02:54 PM
golgo13
11
Jun 23, 2014 08:36 AM
spyghost
Lancer How Tos / Installations
Aug 8, 2013 11:00 AM
Spac3clown
13
Mar 23, 2012 08:16 PM
