To build a trans Or not to!
Hey guys have 03 evo 8 and my trans recently went out. I am debating on whether I should get my trans built or not. If a matter of time of it going out? Or will it be ok if I launch right and keep up on the maintenance. The car will see a trip to the drag strip occasionally and is currently my daily.
Current mods
-Precision 880cc injectors-
-Hks 272s cams-
-Arc heat shield-
-Aem intake-
-Espirlir Jgt 500 Cat back-
-Greddy 3 inch inter cooler-
-Synapse bypass valve-
-Megan Down pipe-
-Clutch masters stage 4 clutch-
- Stage 3 transfer case (Quaff Diff)-
I want to do a fp red on pump gas in the spring and have a e85 map for the track
So should I be alright with stock evo 8 trans? Or would it be risky?
Current mods
-Hks 272s cams-
-Arc heat shield-
-Aem intake-
-Megan Down pipe-
