magnetic bolt for oil pan is overkill - i almost never get anything adhere to the bolt, other than it being a pain to put back in because it likes to adhere to the pan instead of the drain hole. it's more trouble than it's worth.
as for the crush washer, you can get cheap ones at autozone/pep boys/kragens. as long as you get the right size, they're fairly cheap to come by. i opted to change it into a hard reusable washer. no leaks, and a better peace of mind keeping it.
__________________
SEIBON skirts + diffuser + rear ext + ralliart tails + CW hood ✔
Rexpeed vents + gurney flap + grill ✔
Nisei UICP + UR LICP + AGP FMIC ✔
WORKS .9" springs + AMS bushings ✔
Defi boost gauge ✔
moleskin ✔
AMS O2 dp + cat pipe ✔
Ralliart front strut bar ✔
Magnaflow Cat-back ✔
HKS Kansai rear bar ✔
Vibrant resonators ✔
HKS WGA + HBSpeed ✔ (338.1ft/lbs, 350whp)
Volk TE37 + Toyo T1R ✔
Whiteline sway bars ✔
Blacktop Aero lip ✔
Titek carbon panel ✔
Girodisc Stage 4 ✔
