Go Back   evolutionm.net > EvoM Forums > EvoM Newbie / FAQs Forum
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 3, 2009, 04:33 PM   #1
Personal Sales Rating: (0)
Drives: 2006 evo 9
whats really needed for 450hp?
I am trying to figure what mods are really needed for 450hp on 93oct, for daily driving until I build the engine later down the road
Mods
kelford 272 cams
crower valve springs+retainers
walbro 255hp
TBE
Act clutch kit
Injen Intercooler pipe set
aem wideband
aem true boost control
street tuned.
car ran 12.3@110 last weekend, I assume the car is making 350hp right now.
I have a ported fp black sitting in my room, I plan on getting a buschur 3.5 street intercooler and 1200cc injectors.
now I know the turbo is a bit overkill but I will want more later.
so do you think that a ported exhaust manifold, intake,65mm TB,and swaintech coating for the hotside, and exhaust manifold is needed to make this power? or will it be fine without it for now.
thanks!!
Offline
Old Nov 3, 2009, 04:39 PM   #2
Personal Sales Rating: (1)
LOVEBOOOST's Avatar
Drives: 03 evo8
I think u will be fine but honestly there isnt much results on the black to know what it can make... but my opinion u will be find but for a little more power I would go ahead and get that stuff mainly port the manifold
Offline
Old Nov 3, 2009, 05:21 PM   #3
Drives: 2006 evo 9
I hear yea, I just would really like to bolt it up now,so I can sell the stock ix turbo and use that money for the other parts I do need
Offline
Old Nov 3, 2009, 05:56 PM   #4
bostonhatcher's Avatar
Drives: 2000 Mitsubishi Eclipse GSX
There's a big difference between pump gas and e85 on the stock appearing turbos. The bigger housing turbos can do quite a bit on pump gas.
If you're set on 93 then get a bigger turbo.
Offline
Old Nov 3, 2009, 05:58 PM   #5
Personal Sales Rating: (3)
Drives: 2006 IX MR
I have almost all the same mods you do (different companies on some parts; Kelfords rock!) I'm installing a ported FP Red and PPI Ported EM/IM/hotside/O2/65mm TB in the next few weeks along with some 1000cc injectors and getting tuned by Mellon. It'd be nice to make 450 on pump...
The ported stuff can't hurt, but I don't know how much they will add to the final numbers. I think until we build our engines, get non-stock IM/EM or O2 dump, or switch to E-85 we will both be limited in how much power our engines will make.
__________________
Tuned by Mellon
Offline
Old Nov 3, 2009, 06:12 PM   #6
scarface2jz's Avatar
Drives: 2006 Evolution MR/SE
Port the TB, intake and exhaust mani's, get an external dump 02 housing, or divorced with recirc at least, ETS 3.5" FMIC, HKS DLI ignition, crank up the boost to like 27-28psi, or get meth and hit 33-34psi, you should break 450whp
But with your mods you shoulda hit at least 11.9 @ 115, if I were you I would work on the driving, with the mods in my sig I went 12.1 first pass ever @ 113, and my 1/8th times were 7.8 @ 90mph good enough for an 11.8 with a 1.6 60', I was cutting a 1.8 60'
__________________
2006 Mitsubishi Lancer Evolution IX
MR SE Apex Silver
GReddy Ti-C competition TBE, Buschur intake, Hallman RX Pro MBC, Injen LICP, Erkel Tune, ACT street clutch, Stage 4 driver mod. Top Level Built/E-spec tuned FTW "get the most for your combo!"
6th Annual Evo vs. WRX/STI Day @ Etown. Stock Appearing Heads Up, 2nd place !!! 12.1 @ 113
Offline
Old Nov 3, 2009, 08:43 PM   #7
Drives: 2006 evo 9
well I am looking into converting to e85 since there is a station 8miles down the road. I just need to figure the injector sizing, also I still only want to run the single walbro for now. I will set up duel maps for 93oct and e85.
Offline
Old Nov 3, 2009, 08:48 PM   #8
Personal Sales Rating: (2)
buchnerj's Avatar
Drives: 2006 Evolution IX MR, 1998 Honda Prelude
If you switch to E-85 you should already be at 450 at least with the mods you have and the stuff to install. I am at 475ish with the mods in my sig and the black should be able to do that easily based on what i've heard.
__________________
06 Apex Silver MR
80MM FP Green - Ported 73HTA
HKS 272 Cams
Precision 1200cc Injectors
Walbro 255 lph
Hallman Pro RX MBC @30 psi
ARP Headstuds / Conrod bolts
Injen UICP/LICP
Injen Ram Intake - K&N Cone
APS TV BOV
Greddy Spec-V FMIC
Greddy Turbo Headers
ARC Titanium Catback Exhaust
Megan Radiator
Megan O2 Housing - Ported
DC Sports downpipe/catdelete
Okada Projects Plasma Coils
Excedy Twin HD/ Fly
ROBISPEC/// KW3 Custom Clubsports
E-85 Ethanol
Offline
Old Nov 3, 2009, 09:14 PM   #9
Personal Sales Rating: (4)
xRoguex's Avatar
Drives: 2005 Evo SSL
Send a message via AIM to xRoguex
I plan to be close to 420 on BR's dyno with my mod list.
__________________
05' Evo 8 SSL
: : Serenity : :
Heavily Modified
FP 80mm Red, BR Race FMIC, BR 65mm TB, MAP Intake mani, BR 3" Exhaust, Megan O2, MAP Exhaust mani, Kelford 272's, Supertech Springs, Spoolin COP, HKS intake, HKS BOV, ECU controlled boost, Innovate WB, Defi Guages, Exedy Twin HD, ShepTrans and Xcase.
Sponsored by the USMC and US Army.
ROM - 96530006
Tuned by Asmodeus
Offline
Old Nov 3, 2009, 10:17 PM   #10
Personal Sales Rating: (16)
jmtx86's Avatar
Drives: Audi S4
H/P shouldn't be your goal 1320 should be. If you switch over to E85 you should run minimum 1000cc injectors (id go with 1200) and with a red you should have NO problems reaching your power goals. As far as the pump goes, well see if the 225 keeps up if not your going to have to run a dual setup or go another route.
__________________
02 s4
04 Evo VIII
04 Sti
89 CRX RIP
Building another Honda Real soon
"If your in control, you're not going fast enough"
Offline
Old Nov 3, 2009, 10:27 PM   #11
buchnerj's Avatar
Quote:
+1 to this. That is what was going on with me, we are pretty sure with a few more tweaks and porting my intake and exhaust manifolds we could hit 500, but I am running out of fuel around 480, so we dialed it back. I need a double pump setup, but I am shopping for a built motor before I go down that road.
__________________
06 Apex Silver MR
HKS 272 Cams
Walbro 255 lph
Injen UICP/LICP
APS TV BOV
Greddy Spec-V FMIC
Megan Radiator
Excedy Twin HD/ Fly
E-85 Ethanol
Offline
Old Nov 3, 2009, 10:55 PM   #12
BLKCarbonEVO's Avatar
Drives: 2006 EVO IXMR
Send a message via MSN to BLKCarbonEVO
Easy! Get a Magnus v5 and throw that on with the Black. The magnus will net you great power on pump. It will allow you to run a lot more timing and your car won't be near as knock happy. We have a bunch on "normal" modded FP Reds at 450 here in the NW. I think the Black will get you were you want!
Pump setup:
1) Magnus v5 w/ ETS Short Route UICP
2) I would go 1200cc injectors so you have room to grow.
3) Milspec 65mm TB - We have 700hp cars on stock tb and doesn't seem to be limiting hp!
4) Port Exhaust Manifold
5) "BLACK"
6) External dump 02
7) Full 3in Exhaust
8) ETS 3.8 Garrett FMIC FTMFW
9) FP 18psi wastegate
10) A good EBC so you can hold 30psi to redline (on the black I don't think you will have a problem holding 29-30psi to redline)
11) Get a nice big 4in intake with foam filter, unless you drive in a dirty place
12) Get a 50mm BOV so that you don't leak. There are tons of BOVs that leak. The Tial and TurboSmart Raceport are both great BOVs.
You should be able to run 30psi no problem and should break 450 on pump. Remember on pump it's all about air flow because unlike meth/E85/Q you just can't turn the boost up to make power. You need to make the most power on the lowest boost since your limited!
Good luck on your build
Mikey
__________________
Mikey's 2006 EVO IX MR: ER VIII 5speed, Magnus v5, 3.8" Garrett FMIC, ETS Short Route UICP, TurboSmart RacePort BOV, RC 880cc Injectors, Perrin Fuel Rail, Walbro 255, ARP Head Studs, HKS 272/280, HKS EBC, R/TErnie Ported Exhaust Manifold, R/TErnie Full 3" V-Band External Dump O2 housing, R/TErnie Modified Perrin 3" V-Band Downpipe, Nesei LICP, FP 25psi Wastegate, Apexi N1 Test-Back, AEM Meth kit (M15), Exedy Twin Plate, FP Red+30lbs+ER Tune = 520hp/406tq
http://www.myspace.com/blkcarbonevo
Offline
Old Nov 4, 2009, 06:03 AM   #13
Drives: 2006 evo 9
Does the magnus require special upper intercooler piping? Will it slow my spool down? Man it's gonna take some time to save up for all those parts
Offline
Old Nov 4, 2009, 06:23 AM   #14
EvoM Super Moderator
2002 Ford Focus
SmikeEvo's Avatar
Drives: 2002 SVTF, 2006 Honda Aero, 2008 Lancer GTS, 2006 Galant GTS
Send a message via AIM to SmikeEvo
350 engine hp or wheel hp?
With a 110 trap, I can tell you right now that you do not have that much power.
I was trapping 116-117 on 93 oct with less mods (340 whp on DLL).
__________________
***New Points System and Forum Rules***
Problem with a post or thread? Use the report post button - triangle sign on the bottom left.
SmikeEvo Racing Blog
Sponsored by:
Swift Springs
GTWorx
Offline
Old Nov 4, 2009, 06:36 AM   #15
Drives: 2006 evo 9
well I used one of those 1/4 mile calculators based on my time to figure my hp. I believe if my 2-step was higher I could have got a better time. Right now it's only set to 5000 rpm.
Offline
Tags
14, 450, 450hp, audi, eclipse, evo, gsx, hp, injectors, ix, mile, mitsubishi, mr, needed, s4, wrx
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
