Where do I go from here?
Hello everyone,
I'm stuck and need some suggestions. Some money has come my way ($1900) and after literally days/weeks of research I just don't know where to put it on the Evo. Some background: Evo 9 MR, 380 AWHP, 355TQ, 30k miles. List of mods:
Power
BR TBE, Kelford 272s, ETS LICP, AMS 3.5" FMIC, FORGE UNOS MBC, Perrin Intake System, AEM Uego, Prosport Boost Gauge
Suspension
Swift Spec-R springs, Agency Power 27mm Rear Sway
On Hand/On order already
Megan O2, PPI ported ex mani and hotside, Whiteline: RCK, Bump steer kit, precision steering kit
I am interested in autocross (thanks chemwarrior!) and know my suspension needs to be tightened up, but I don't want to get so-so coilovers and have to buy better ones later. So, where would my money best be spent?
Items I am looking at:
Perrin PSRS, Whiteline front sway, Energy suspension master bushing kit, ported intake mani (MAP;$229, BR;$199, or PPI;$49), 65mm throttle body (Mil.Spec; $289, PPI; $249), 1000 cc injectors, Aluminum driveshaft (??), Beatrush propeller shaft bushings, AMS motormounts, endlinks (??). Anything else???
Obviously, all of the above parts total more than $1900 and some require a tune. However, does the ported ex mani, O2, and hotside require a new tune? I'm trying to have more money go to parts than installation/tune.
Thank you
Power
Suspension
Thank you
What about a good set of brake pads, lightweight wheels (although the stock BBSs are already pretty light), and/or better tires. Are you trying to stay within a certain class in Autocross, or just looking to do mods that will benefit you on the street as well?
Are you on the stock fuel pump? And what is E-85 availability like in your area? If you are going to go with bigger injectors, maybe bump them up to 1250cc+ injectors and make the switch to E-85.
My first buy with that money would be the aluminum driveshaft. I know that AWD sells an awesome peice that a friend of mine had gotten and he loves it. If I'm not mistaken there under $800. Then with the left overs just pick and chose what else you want from your list.
Good luck!!
-Justin
Good luck!!
-Justin
with the AWD aluminum drive shaft you have to send yours to them and it is $695! But I would go with some AWD Motorsports spec D2 Racing coilovers for $1095 and then save the rest!
I do have the Walbro, forgot to include it on the list. E-85 is pretty much a no-go in my area, only 3 stations have it. I wad thinking about the FIC Bluemax 1250s because eventually Iwould like to make the switch to E-85 when feasible.
