Quote:
Originally Posted by mlomker
Are all California cops gear heads? I've seen pics where guys have powdercoated everything black and it ends up looking pretty stock...enough that a non-car nut wouldn't know the difference.
No, they're not. They're smart enough to look at a part that's not OEM and say, "That's not factory. Where is your CARB sticker? I'm writing you a ticket for that and the state referee will have to verify these parts are legal in California."
One of the reasons that meth/water kits aren't cheap is because they have various fail-safes built into them. Some of them will change your engine map to reduce power on the fly.
Okay, that's good to know. Thanks!
Quote:
Originally Posted by DBallz
A ported manifold is just your stock manifold and the inside are ported so it's smoother and less turbulant.
Ah, I was confused. That post was referring to a ported stock manifold, which would work. Thank you for pointing that out.
Dude how many times have the informed person have to tell you aside from what you have fuel pump, o2 housing, LICP, turn up the boost and tune.
Just seeing all the options. I understand that if I add a complete list of parts I will get max gains. I don't want max gains, I just want the next logical part in the chain.
Did you read the AMS cam test?
I did and it left me with a few questions. The guys at AMS were great in explaining the various cam behaviour, which is super useful. The sad part was that it those tests were done on an VIII without MIVEC.
There is no one mods that is greater then another for each mod excluding fuel pump you should always retune why are you not getting this. It's the combo of mods that will yield the most power
Oh no, I do get it. What I'm asking for is the next best part for the buck.
Meth kits don't work like that but if you were to READ up on the difference in the kits and what triggers they us you would understand. Some read boost, MAF, or injector duty cycle. If you run low on meth I think 99% of the kits out there will let you know that is the number one failsafe which is low tank. If your got WOT all the time then you will need to refill your meth all the time. If you drive like a normal person and occasionally fast then your fine
Fair enough. You are right, I have not read too much on the Meth kits, but I will go do that since you have pointed out that I have a few misconceptions regarding that modification.
There is no way a 50 trim turbo can make that much power sorry. 50trims have tuff time making 500 on race fuel so 600 is out of the question.
That's what I was told buy a reputable source, but since I don't have a chart to post I can't prove it. I can post the mods though:
2.3 short block
Stock head w/ cosworth m2 cams
supertech valvetrain
50 trim bb
O2 Housing
FMIC
Turboback exhaust
1000cc injectors
To the OP what other forum have you read on here? Cause most seem to understand after a while and READ other threads about turbos, meth, fuel, cams, and tunes. I'm still in shock that the mods haven't done the usually
Search:
CLOSED
I've been reading lots of other threads and searching trying to find my answers. I think the problem is too much information. Hence the thread that I started. I was hoping it was a simple answer, but that's not the case.
