Sep 22, 2009, 12:08 PM
Personal Sales Rating: ( 2)
Drives: '06 TB IX GSR SE
Quote:
Originally Posted by shadykilla
Well I mean is it necessary to tune after every mod. With subbies its almost a law that you must tune after every mod or you car will blow up. I mean I understad after a tbe and stuff like that you should.
That depends on the part you are installing.
But I'm guessin it would be smart to either do a group of mods together unless you can tune after each??
Correct.
Unless you can afford the dyno time, have all your mods installed at the same time, then flatbed tow (if necessary, but DON'T DRIVE it!) the car to your tuner.
__________________
2006 TB IX GSR SE
SPEEDELEMENT tuned
291whp / 300tq pump gas on Dyno Dynamics Dynamometer
Reflash - WORKS Filter - WORKS Exhaust
Quote:
Originally Posted by ambystom01
we had a pet T-Rex in the basement that escaped so I ran onto the golf course where my buddy was doing donuts in an invisible buick.
Offline
Sep 22, 2009, 12:09 PM
Back on topic:
What mods are necessary if you go with a larger turbo?
Also, what is a respectable upgrade from the stock IX turbo and why?
__________________
2006 TB IX GSR SE
SPEEDELEMENT tuned
Offline
Sep 22, 2009, 01:58 PM
Personal Sales Rating: ( 5)
Location: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Drives: 05 Apex Silver Version 8, 2001 GSX-R 1000
Quote:
Originally Posted by golgo13
Back on topic:
Everything I listed would be needed for a turbo upgrade. For you cause you seem very new to turbos and boost I would say an BBK Full or FP HTA Green or Red. The reason why is because they are a stock bolt on turbo. The BBK and FP HTA Green spool better then stock turbo with more top end. But like I said I suggest you do the stock turbo upgrades first before swapping turbo...One thing I didn't mention is you should get cams for a turbo upgrade.
__________________
Stock Block and Head
FP Red 80mm
Kelford 272's
Beehive Springs
Precision 1k injectors
EPM 02 Dump
ETS 3.5" IC Kit
APS BOV
PPI Extreme Ported Hotside, Exhaust Mani, Intake Mani, and TB
469@28psi on 93
Junior Tuned
THE SHOP CT built
Old setup
Stock Evo 8 Turbo
322.7 whp 320tq 21.5 psi on 93 oct
355.8 whp 430tq 25 psi on c16
Offline
Sep 22, 2009, 02:55 PM
Personal Sales Rating: ( 0)
Drives: 08 EVO GSR
I think most people group their mods into stages. Some don't require a tune but they just won't add much power until you do (fmic, piping, less restrictive exhaust).
If you're changing your intake then you should have an a/f gauge or get a tune unless you know the car's tune is stock (Evos run rich stock so the stock tune likes intakes). Injectors and boost mods are probably the ones I'd just have the tuner install pre-tune. I've been told the car will barely run on E85 without a retune, so that's best done by a shop.
Offline
Sep 22, 2009, 03:16 PM
Drives: 04 Lancer Evolution; 05 Chevy Silverado; O3 XR250R
What is your goal, just a few more ponies? If so, just get a cat back exhaust and a down pipe, and maybe an intercooler. If you want 400+whp, you will have to do more mods. Just think of the motor as a pump, new turbo flows more air so that is why peeps redo their top end, valve springs, retainers, cams; etc. If you can flow more air you need more fuel; walboro; injectors; fuel rail; fuel pressure regulator; etc.. If you have more fuel and air, you need more spark to ignite it all better; new coils; plugs; etc... If you have more power, you need better brakes; cross drilled rotors; new calipers; pads; etc..
Think of the modding process as your roadmap, and your goal is your destination. You have to now where you want to be before you get there.
Here is a crazy idea, why not take the car to a respectable tuner and ask their opinion?
__________________
"A fit young racing driver in a supercar and he can not pull away from a fat man in a four door saloon."
Jeremy Charles Robert Clarkson
Offline
Sep 22, 2009, 03:49 PM
Quote:
I don't expect you to read the whole thread, but my car isn't stock.
I don't have a number goal, I just want to increase the power from where it is now by adding the part that will net the biggest gains. I'm willing to do a few other parts if they necessarily need to go together like an upgraded valve train with aggressive cams so I don't float a valve, etc.
I would like to make decent, reliable power for my daily driver. I don't want to mess around with internals, remove the head studs or spray NAWZ into my motor.
While I'm at the office, this is a better solution from my desk.
__________________
2006 TB IX GSR SE
SPEEDELEMENT tuned
Offline
Sep 22, 2009, 05:49 PM
Personal Sales Rating: ( 4)
Drives: 06 GG MR DD TRX450R
Yea do some of the mods a little at a time like the pump, o2, licp then save for the turbo, cams, and fmic if you decide. Don't be like me and have minor bolt ons and do a turbo upgrade, cams, etc. all at once!  I am impatient..
Offline
Sep 23, 2009, 04:19 AM
Quote:
Oh God is he.
__________________
FP Red 80mm
Kelford 272's
Beehive Springs
EPM 02 Dump
ETS 3.5" IC Kit
APS BOV
469@28psi on 93
Junior Tuned
THE SHOP CT built
Old setup
Stock Evo 8 Turbo
Offline
Sep 23, 2009, 05:08 AM
He comments on all of my posts! ^ Shut your mouth when you talk to me!
Offline
Sep 23, 2009, 06:50 AM
Listen buddy you would know nothing without miy help. And don't forget those free baseline runs your getting......who worked that deal for you ME
Can everyone in here just listen to me especially the OP look at the sig I think I know what I'm doing and speaking about. Get an o2 housing, fuel pump, and MBC and a good tune and you will have about 330hp
__________________
FP Red 80mm
Kelford 272's
Beehive Springs
EPM 02 Dump
ETS 3.5" IC Kit
APS BOV
469@28psi on 93
Junior Tuned
THE SHOP CT built
Old setup
Stock Evo 8 Turbo
Offline
Sep 23, 2009, 11:21 AM
I'm not questioning your knowledge by any means, but I want you to understand that I already have an MBC and a few other modifications.
Would an O2 housing and a fuel pump be a better "bang for the buck" modification instead of a new turbo (FP Green? No idea...), injectors and a fuel pump?
__________________
2006 TB IX GSR SE
SPEEDELEMENT tuned
Offline
Sep 23, 2009, 11:27 AM
Personal Sales Rating: ( 14)
2005 Mitsubishi Lancer Evolution
Drives: 2005 Evolution 8, DD 92 Camry
When modding an evo 9 on stock turbo most usually do this
- Intake system(drop in are a waste of money)
- 3" Turbo Back Exhaust
- o2 housing
- LICP
- Walbro Fuel pump
- MBC, EBC, or 3 port Boost solenoid for ECU control boost
- 3.5" IC
- Injectors depending on how much power you want
- No need for cams on evo 9 with stock turbo...a good tuner and MIVEC is all you need.
Minus the injectors guys on my coast using 93oct make about 350-370. If you want to do a turbo upgrade your going to have to do these mods anyway.
What he said  but it all depend on your goal
__________________
Tomei ARMS/HKS 272s/HKS SMF Intake/ARP HStud/Mil.Spec/PTE880/Megan O2/Buschur Mani/3"TBE/Walbro/Hallman/Injen Intake Pipe/3"FMIC/Synchronic BOV/WORKS XC8
EvolNinja
Tuned by 4WS Tuning
Offline
Sep 23, 2009, 11:30 AM
go to AMS or Buschur website to find their recommend stage of upgraded parts
__________________
EvolNinja
Tuned by 4WS Tuning
Offline
Sep 23, 2009, 12:23 PM
What about something like bolting up an FP Red with the 80mm housing?
Will that work with stock injectors and fuel pump? What needs to accompany modding the turbo?
__________________
2006 TB IX GSR SE
SPEEDELEMENT tuned
Offline
Sep 23, 2009, 12:28 PM
Drives: 2006 Evo SE-SSL, 2001 Eclipse, 05 Mustang GT
Your just asking for death to your engine..Just do the mods that are suggested. There are multiple posts in this thead that tell you what to do.
Offline
Tags
bbk, cams, car, forum, fp green, intake, list, mod, modification, mods, nissan, pathfinder, stock, tune, turbo  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
