May 24, 2007, 12:30 PM
Personal Sales Rating: ( 0)
Drives: Nothing worth mentioning lol
header a good mod?
I know they are for camaro's and stangs just wondering for evo's...megan's is pretty reasonable.
__________________
Have owned modded,96,97,01 Z28's. Looking at possibly making the switch .
Offline
May 24, 2007, 12:33 PM
Personal Sales Rating: ( 4)
Drives: 2004 Evo VIII
There are gains to be made, however not nearly as much as would be seen on lt1/lt4 or the 4.6
__________________
Quick Time Performance DP and E-cutout: Stock Cat-Back HKS 272s: Megan o2: HKS DV: RMR ICP: Hallman @23 psi: 10.5 hotside: ARP Head Studs: ACT Street clutch: Sean Ivey Tune
Offline
May 24, 2007, 12:36 PM
Quote:
Obviously, I know that lol...btw im from Oakhurst..It says 12 hp , sounds about right, and not bad for 225 bucks..
__________________
Offline
May 24, 2007, 12:40 PM
Personal Sales Rating: ( 13)
Drives: 2003 Evo 8
If you do a search you will find the pros and cons. BTW its an exhaust manifold not a header for the evo.
__________________
2003 GSR EVO
HFC, Greddy SP2 Exhaust, HKS intake, Megan Exaust manifold , Megan O2 turbo outlet, reflash, AVC-R@21 PSI, walbro 255, HKS 264 I/E, Shep stage 2 Transfer Case with Ralliart LSD. Blox polyurethane front engine mount.
Offline
May 24, 2007, 12:42 PM
Quote:
Some companies call it manifold some call it header. In the middle of a search as we speak. Thanx for giving me your experience w/ it seeing u have it lol.
__________________
Offline
May 24, 2007, 01:10 PM
Personal Sales Rating: ( 1)
Drives: '08 WW EVO X GSR, '06 GSXR 600
Alot of people port the stocker.
__________________
SSS//Navi//Advan Racing RS//BC Racing Coilovers//Hallman Pro MBC//AMS FMIC//Works Air Filter//Greddy-Trust Dual Cat-Back Exhaust//Defi Boost Gauge//APR Vortex Generator//Ralliart Tails//20% Tint//Valentine One//
Offline
May 24, 2007, 06:05 PM
Silver Sponsor
Personal Sales Rating: ( 30)
Drives: 05 EVO & 91 Stealth TT
if you're thinking about getting an EVO, it would be an odd first mod. The stock turbo back exhaust is pretty bad especially when you raise the boost up a bit.
Offline
May 24, 2007, 06:10 PM
Personal Sales Rating: ( 37)
Drives: 05 Lancer Evo VIII, 03 Volvo S-40,97 VW Jetta
you can port the stocker that way it wont crack, the megan racing is a reasonably priced header though and pretty durable
Offline
May 24, 2007, 06:13 PM
Drives: EVOLUTION IX MR - K7 GSX-R 600
Port the Stocker!
__________________
EVOLUTION IX MR
Tuned by Archie 'slow1'
Offline
May 24, 2007, 06:15 PM
Personal Sales Rating: ( 2)
many people seem to have a problem with the megan manifold cracking. you are better off porting the stock manifold. the only "header" that will yield more gains on the stock turbo is the full-race manifold that goes for almost a grand...
steve
Offline
May 24, 2007, 06:27 PM
Personal Sales Rating: ( 14)
2008 Mitsubishi Lancer Evolution
Drives: Evo X Rally Car - 2010 Tundra TRD Rock Warrior
with stock turbo i wouldn't do it.
port the stock one .
Offline
May 24, 2007, 06:31 PM
Personal Sales Rating: ( 117)
Drives: 04 Evo 8
porting the stocker will get you slightly better gains, and you wont loose the down low torque
__________________
9.0 wiseco/crower motor, FP RED, PPI ported 10.5 hotside/exhaust/intake manifolds, PPI 65mm TB, S2 cams, SMC meth, intake, exhaust, ETS FMIC, O2 housing, Forge MBC.
Faisal (586) 610-2830
Offline
May 24, 2007, 06:46 PM
Drives: 03 evo
this is the way i look at it...
if you by the megan mani for $225, look at it as a loaner while you get your stocker ported and coated and all that good stuff.
now when the megan mani cracks(if it cracks) you got a ported and coated stocker to throw on
i have had a megan on for about 8 long and hard months and no signs of cracking yet, plan on getting the stock one ported and coated soon but keep putting it off.
p.s. if you buy the megan do NOT use the gaskets they supply re use the stock or buy new stock ones!!!!!!!!!!!!
Offline
May 24, 2007, 09:59 PM
Personal Sales Rating: ( 5)
Drives: 2006 RR EVO 9 1993 Taurus SHO 2006 4Runner 86 Buick GN
There are way more mods you can do for a first mod...that will probably show you more of a gain than that one. But it couldnt hurt either way. Youre gonna need a tune to see any results from it though.
__________________
THE QUICKER-PICKER-UPPER
Cosworth M2 Cams * ARP Headstuds/Rod Bolts
ETS 3.5" Intercooler * Hallman MBC w/ cockpit control * Walbro 255 Pump * Works Ride Springs
Works 30% Shorty Shifter & Bushings * HKS Racing Suction Intake * Tuned by DG Motors
TurboXS UICP-LICP * Titek O2 Housing
Ported 10.5 Hotside * 3" Skunk2 Cat-Back
3" DC Sports DP w/delete *
Megan Exhaust Manifold * AGP Catch Can
Samco Hoses * Solid Lower Motor Mount *
Offline
May 24, 2007, 10:05 PM
Personal Sales Rating: ( 50)
Drives: evolution 8
if you port the stocker or get the megan youll need to get a 10.5 hotside and stainless o2 housing to achieve worthwhile gains
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
