Sep 25, 2006, 09:50 PM
Personal Sales Rating: ( 12)
Drives: '04 'mac black EVO8, '04 black onyx IS300, 1998 eclipse gst(R.I.P.), 1993 Honda Accord A.E., 1990 Ford Mustang-built 302(sold), 1971 Chevy Elco built 307
Quote:
Originally Posted by evil mechanic
yeah if it was real rich. but what if its just a little rich. then it would appear white from the rear view right? like i said if thats not it than pressure test the cooling system.
no it would still be black
__________________
Helix intercooler pipes,Helix 3" DP,Helix 3" exhaust,Invidia o2,Helix DNA coilovers, WORKS filter,3" WORKS HFC,Greddy Type S,FPWR Turbo w/Ti internals,10.5 Hotside,Works p2 flash w/boost control, Works 269 cams,Revolver valvesprings/retainers,ARP headstuds,Walbro 255,6000k HID upgrade,DoLuck CF lip,Omori multicolor electronic 60mm gauges,B&M short shifter,Pocketlogger,HKS type 1 TT,custom grounding kit,voltage stabilizer,Axas shift indicator light
Offline
Sep 28, 2006, 03:16 PM
Personal Sales Rating: ( 10)
Drives: 1994 impreza-BEATER!
SO....I am confused. I went to a shop and they did a combustion Gas leak test....a test to see if the head gasket or head is blown/bad, they say everything is good, and that they could not get the car to blow smoke. I drove home and I put load on it and poof white smoke....what could this be? I really need some help here guys...
Thanks
Brandon
__________________
Looking for a Honda or a Daily driver?
I work at Honda and can make evo.m members good deals on new and used Hondas.
Offline
Sep 28, 2006, 06:34 PM
Personal Sales Rating: ( 0)
Drives: 06 GG MR
I would have to agree that its most likely a coolant leak. Fuel doesn't look white that I've ever seen, and oil is always blue. And it would make sense since its under hard acceleration which would indicate high boost levels. Gotta love turbo cars!
Offline
Sep 28, 2006, 07:52 PM
I agree but I had a test done that specifically looked for coolant issues...I am so confused...
__________________
Offline
Sep 28, 2006, 07:55 PM
Personal Sales Rating: ( 21)
Drives: 05 element, 03 evo (mutating)
might be the turbo. clouds of white stinky smoke? not at idle but put your foot in it and you are in the clouds.
but you have no trouble with boost?
Offline
Sep 28, 2006, 08:01 PM
Personal Sales Rating: ( 22)
Drives: 2005 EVO8 Apex Silver no more
why not take it to the dealer, return your visible parts back to stock. You tried putting your stock fuel pump back in?? I dont know why you replaced your fuel pump anyways and are not tuned for it, pumps on the 9's are better than the 8's.
Offline
Sep 28, 2006, 08:08 PM
Drives: 2003 BBY EVO VIII
you dont have to get tuned for a new fuel pump i dont think.
either way it could be the seals on your turbo, which would put huge amounts of bluish smoke out, or as i said a pinhole leak in your headgasket.
A pinhole leak can pass the tests for a coolant leak, but once you get into boost it will force coolant through the hole and into the combustion chamber which ='s white smoke.
edit: nvm saw first post for mods.
Offline
Sep 28, 2006, 08:33 PM
Thanks guys, Limp i think that is what I am probably going to do me and some buddies are gonna put it back to stock and take it in. If you guys care I will keep you updated.
Also no issues with boost or overheating. But idle has been a lil weird lately, but its getting cold here.
__________________
Offline
Sep 28, 2006, 11:18 PM
Personal Sales Rating: ( 8)
Drives: EVOLUTION IX
why did you add a fuel pump on a IX? its not needed for what mods you have, especially only a 255lph
Offline
Sep 28, 2006, 11:24 PM
Personal Sales Rating: ( 6)
Drives: 2003 Apex Silver Evo
thats really weird about your idle. If it idles low when cold then thats bad. It should idle high when its cold to get the engine up to operating temps. Like everyone said return your car to stock and take it to a dealership.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
