Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
XXR 527's Fitment offset vs Stock.. Help please
Old Jul 18, 2014, 09:43 PM
TxFAkuma's Avatar
I am looking on google for the 2014 gsr's offset and cant find them anywhere. Do you guys have any idea what the stock offset is? I'm sure the stock wheels are EnkeiŽ cast aluminum alloy, 18 x 8.5 wheels. Will the XXR 527 18x8.75 Chromium Black 5-100/5-114.3 [+35mm] fit on my car? Or should i go 20mm offset? 5-114.3 is our bolt pattern correct? will the 8.75 make the fitment an issue because the stock is 8.5?
I like these rims because im cheap and they look good. i just wanna know what fits.
thanks everyone.
Old Jul 19, 2014, 12:28 AM
tbaird58's Avatar
pretty sure the offset for the x wheels are +38 on both the gsr and mr rims, if you get the 18x8.75 +35 they will fit fine on your car
Old Jul 19, 2014, 07:27 PM
Centralcalievo's Avatar
20 offset sits very flush on theses cars and would require a fender roll if your lowered
Old Jul 19, 2014, 10:42 PM
TxFAkuma's Avatar
Will that stick out the tires? Or will it actually be pushed in because of the minor change of the offset?
Old Jul 20, 2014, 12:09 AM
bphx123's Avatar
I had xxr 527 18x9.75 +22 offset with stock tires and swift springs, fitted just fine. You could go with 18.75 but mind as well go bit wider.
Old Jul 20, 2014, 12:14 AM
bphx123's Avatar
Here you go stock tires, lowered, 18x9.75 +22 or +20 not sure exactly but they only have one size in +20s so it's same one.
http://imgur.com/F8xSoJe
Old Jul 20, 2014, 02:17 AM
Jdjones24's Avatar
Don't get XXRs. Get Rays, WedSports or Advans!!!
Old Jul 20, 2014, 11:34 AM
TxFAkuma's Avatar
So if i do the XXR 527 18x8.75 [+35mm] wheels they will fit perfectly without modifications?
If i do the XXR 527 18x9.75 [+20mm] wheels, will these fit perfectly? I'm assuming this is much wider?
This is on stock height & tires.
I was gonna go with the 18x8.75 so it is just basically a slip on. But if the 9.75 still fits and it looks much better and i dont need spacers or anything then i will go with the 20mm offset.
Need advice. Thanks.
Old Jul 20, 2014, 09:18 PM
bphx123's Avatar
Yes both will fit just fine. If I was you I would go with 18x9.75 as it looks much more flush.
Old Jul 21, 2014, 04:06 PM
TxFAkuma's Avatar
Thank You. I'll go 9.75 and 20mm offset!
Old Jul 22, 2014, 02:14 PM
bphx123's Avatar
Not everyone is balling like you... I don't see anything wrong with XXR, I put 20k on mine w.o any issues... It will hurt less if I scratch them, comparing to 3k wheels.
Old Jul 22, 2014, 04:50 PM
evo 1768's Avatar
xxr 527 18x9.75 +22 offset and swift springs, Name:  5615ba75-fa55-40b8-8ccb-985f9074f1a9.jpg
Vitoykshch (Dec 17, 2020)
Old Jul 22, 2014, 07:28 PM
TxFAkuma's Avatar
Holy crap man you got a nice whip. You just made me really want those rims now lol. I'm not sure how their gonna look on the stock suspension but those springs you got look great with the car. Are those chromium black? What's your exhaust? The rims only come in 35mm or 20mm offset Not sure how u got 22mm. I'm new to the rims game..
Thanks for the picture!
Old Jul 23, 2014, 10:53 AM
bphx123's Avatar
I think his are +20 as well here is the link for the ones that I bought, fitted w.o any issues.
http://www.nlmotoring.com/XXR-527-Wh...p/52789542.htm
Old Jul 23, 2014, 11:30 AM
RazorLab's Avatar
Received 1,038 Likes on 760 Posts
The +20 XXR's will stick out a bit in the rear depending on how low you have the car. Less low, the more it sticks out.
This is mine with Spec R springs.
Quick Reply: XXR 527's Fitment offset vs Stock.. Help please
