Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Evo x brake kit
Old Jan 11, 2010, 12:06 PM
Bear.914's Avatar
Evo x brake kit
Is there a smaller brake kit on the market example ( 328mm rotor (12.9 inches). ) for the evo X so you can run a 17 inch wheel ?
Old Jan 11, 2010, 01:37 PM
Robevo RS's Avatar
AMS selling a gravel kit or for the drag cars. Look up they website or send them an email or pm.
Old Jan 11, 2010, 04:02 PM
Bighec's Avatar
AMS has a kit
Old Jan 11, 2010, 06:45 PM
Hiboost's Avatar
You could probably swap stock for stock with an Evo 8/9 that wanted to switch and get some money as well. Maybe even just the front swapped.
Old Jan 11, 2010, 06:53 PM
Bear.914's Avatar
18's are a killer! im sure 8/9's are fine with there 17's lol
Old Jan 17, 2010, 03:54 PM
Evo a Mula's Avatar
ams is the only people out with a kit..1000$ thoe loool
Old Jan 17, 2010, 09:11 PM
Bear.914's Avatar
someone said maybe 8/9's will work so ima see whats good if that could happen
Old Jan 17, 2010, 09:28 PM
henryDgreat's Avatar
what's the size of an evo x brake?
is the caliper interchangeable or you need both caliper and disc?
Old Jan 20, 2010, 06:27 AM
MSI
MSI's Avatar
There is also the grpN Brembo kits ... you can run these using a 17" wheel as well.
Same calipers that are on the SIERRA SIERRA evo.
Old Jan 25, 2010, 03:20 PM
Turbones's Avatar
Need Caliper and disk.
moey124
May 12, 2014 12:20 AM
LeoFama617
Outlander Sport
11
Mar 20, 2014 05:50 PM
Andrew@AMS
23
Jul 25, 2009 02:29 PM
AutoMotoSports
Automotosports - Illinois
10
Jun 5, 2008 10:31 AM
yikez
Jun 1, 2008 05:00 PM
Quick Reply: Evo x brake kit
