Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 3, 2009, 11:31 AM   #1
WAM
Personal Sales Rating: (0)
WAM's Avatar
How hard to replace studs?
Front wheel studs on an X. I need to replace a broken one, but maybe I'll put longer ones in if it's not a big deal. Anybody done it?
__________________
'08 Evo X MR, silver
Offline
Old Nov 3, 2009, 11:36 AM   #2
Gold Sponsor
Personal Sales Rating: (9)
Force-Fed Performance's Avatar
Drives: 570whp stock block IX, 66Chevelle, EK hatch DD.
GRAVY, pound it ut with a hammer, stick the new one thru and use a air gun to suck it in... JUST MAKE SURE to put a big washer or big nut between the hub and whatever you are tightening it with to keep from damaging the hub
__________________
Force-Fed Performance/ A Division of EPIC MOTORSPORTS
http://www.myspace.com/forcefedperformance
834 Stanley Street Fayetteville NC 28306
910-920-1140
Force-Fed (919)300-9673
Kelford Cams
ACT Clutches
Mishimoto Radiators/Thermostats
Aeromotive Products
Full-Race
ETS
Amsoil Authorized Dealer
Offline
Old Nov 3, 2009, 11:38 AM   #3
Drives: OB 08 Lancer Evo X
Indeed. Also, there should be an open spot on the hub where you can pound the stud out the back without it getting obstructed.
Offline
Old Nov 3, 2009, 11:42 AM   #4
Gold Sponsor
^ you should have no problem if the follow thepast two posts
__________________
910-920-1140
Kelford Cams
ACT Clutches
Aeromotive Products
Full-Race
ETS
Offline
Old Nov 3, 2009, 11:43 AM   #5
WAM
WAM's Avatar
Great. Will the new one stick far enough out I can get a lugnut on it with the wheel in place, or should I maybe try to find a regular hex nut to do the job with the wheel off? Lube the splines or do it dry?
__________________
Offline
Old Nov 3, 2009, 11:49 AM   #6
Quote:
I always just use a lug nut and some washers. Any M12x1.5 nut will work as well. I never lube wheel studs, there's really no need to if you always torque your wheels properly. That, and you can break a stud if the threads are lubed and you still torque to 85 lb-ft.
Offline
Old Nov 3, 2009, 03:10 PM   #7
WAM
WAM's Avatar
Thanx guys, project's done. I was a little concerned because the aftermarket studs had a coarser spline than OEM. But I checked with the mechanic types at a couple tire shops and they said no problem. What they talked me into: Anti-seize on splines and thread. Two washers with anti-seize between. And an open lug nut installed backwards to pull it in. And a half-inch impact. No problems at all.
__________________
Offline
Old Nov 3, 2009, 03:11 PM   #8
Gold Sponsor
Good deal
__________________
910-920-1140
Kelford Cams
ACT Clutches
Aeromotive Products
Full-Race
ETS
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
