Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 2, 2009, 04:26 AM   #1
Personal Sales Rating: (0)
Drives: Evo X
brake pads
I have to replace my brake pads for the first time and I'm at about 24000 miles. Would it be better to replace them with the stock pads or go with some different ones? How much should the dealer reasonably charge me to change them out?
Offline
Old Nov 2, 2009, 05:12 AM   #2
Personal Sales Rating: (1)
Drives: evo x ,92 talon tsi , 88 starion esir
the stock pad retail is about 750 bucks for front and rear most shops will use what is called flat rate and is prob going to be some where in the 1.5 hour range for front and another 1.5 for the rear so 1.5+1.5=3.0x there labor rate plus the parts
i would not spend nearly 1k to put brakes on
do you track your car or dd it? if you track it i would order the hawk pads
if you just dd your car i would go to the parts store and get like brake best or something like that
i put the brake best ceramic pads on mine they dont dust and turn your wheels black but the do squeak the frist 2 or 3 times you stop each day
good luck hope this helps
__________________
current mods
fp red
cosworth mx1 cams and springs
dw 800 cc injectors
aqumist hsf1
apexi avcr
wb 255 fp with ur install kit
ur turbo back exhaust
perrin front mount
turbo trix hard pipes
exedy twin disc
hood dampers
perrin 3" antena
twm short shifter and bushings
blox front engine mount
t1r shift boot
blox neo shift knob
mase tunned 430/377 at 24 psi
near future mods are
atp down pipe with tial 44mm wg
bc coilovers
fenders rolled
volks bronze ce28
Offline
Old Nov 2, 2009, 07:27 AM   #3
NTEC Club Forum Leader
Personal Sales Rating: (4)
goofygrin's Avatar
Drives: RR EvoX
Changing the pads on the X is VERY easy. You simply punch out two pins per caliper and swap the pads (you might have to use a couple wrenches to retract the pistons in the caliper). You should definitely consider doing it yourself.
I'd look into the Girodisc magic pads if all you do it drive around the street. Less dust, far less cost.
__________________
Are you in the North Texas area? Check out NTEC!
mmmm corn
Offline
Old Nov 3, 2009, 12:28 PM   #4
Personal Sales Rating: (2)
mike100's Avatar
Drives: 'MMVIII Evo 10
I'm shopping for a new set front and rear now a little before I need them.
I noticed that the local big chain auto parts store lists "oe replacement" for about $110 front and rear with shims. You think these are like metal masters or something ok for a bargain, or junk. I might throw a bill away and try them. Sucks that Brembo won't sell the exact pad leaving you only to get bent over by MMNA and the dealer network.
Offline
Old Nov 3, 2009, 12:37 PM   #5
goofygrin's Avatar
Drives: RR EvoX
The OEM pad is from Ferodo, not Brembo FYI.
Those pads, if they are the right size, are going to suck.
__________________
mmmm corn
Offline
Old Nov 3, 2009, 04:09 PM   #6
mike100's Avatar
that's good to know... the 2500 series compound? Those worked fine for me on 20 minute track sessions (well, the original pads that came with the car).
I may or may not track this car again. I have another ride I would like to bring out a couple of times this winter, but it is conceivable I'll bring the evo out again if I'm feeling generous enough to bring my brother a ride to flog.
Offline
Old Nov 3, 2009, 09:26 PM   #7
goofygrin's Avatar
Drives: RR EvoX
They aren't the same as the 2500's. I'm sure they are some weird compound that Mitsu speced.
The 2500's bite harder, squeal more, and eat the rotors faster. Don't dust as much though.
__________________
mmmm corn
Offline
Old Nov 3, 2009, 10:28 PM   #8
Drives: Evo X
How do Hawk HPS pads compare Ferodo DS2500's.
Offline
Old Nov 3, 2009, 10:50 PM   #9
goofygrin's Avatar
Drives: RR EvoX
they suck...
Just get the magic pads if you're not going to track. Low dust and noise, good stopping power. Inexpensive.
__________________
mmmm corn
Offline
Old Nov 4, 2009, 12:12 AM   #10
DS2500s are track pads. They would suck for street use; squeal like pigs and eat your rotors. The OEM pads suck too. They are mostly made up of anti-squeal compounds. The Endless SSH are made for the Brembo style calipers and have some heat capability for spirited driving.
Offline
Old Nov 4, 2009, 01:45 AM   #11
Personal Sales Rating: (6)
endGameXIII's Avatar
Drives: Evo X GSR
they suck...
you're just biased. i've heard nothing about the magic pads other than they SQUEAL. wouldn't bother trying now that there are so many options out there. i ordered my hawk hps pads some time ago. always ran with them. they're not the best overall, but best value? you bet.
__________________
SEIBON skirts + diffuser + rear ext + ralliart tails + CW hood ✔
Rexpeed vents + gurney flap + grill ✔
Nisei UICP + UR LICP + AGP FMIC ✔
WORKS .9" springs + AMS bushings ✔
Defi boost gauge ✔
moleskin ✔
AMS O2 dp + cat pipe ✔
Ralliart front strut bar ✔
Magnaflow Cat-back ✔
HKS Kansai rear bar ✔
Vibrant resonators ✔
HKS WGA + HBSpeed ✔ (338.1ft/lbs, 350whp)
Volk TE37 + Toyo T1R ✔
Whiteline sway bars ✔
Blacktop Aero lip ✔
Titek carbon panel ✔
Girodisc Stage 4 ✔
Offline
Old Nov 4, 2009, 06:43 AM   #12
Drives: Evo X
So what are some good street pads that will perform well if I want to drive like a maniac?
Offline
Old Nov 4, 2009, 06:47 AM   #13
EvoM Super Moderator
Personal Sales Rating: (3)
2002 Ford Focus
SmikeEvo's Avatar
Drives: 2002 SVTF, 2006 Honda Aero, 2008 Lancer GTS, 2006 Galant GTS
Send a message via AIM to SmikeEvo
The Brake Rotor, Pad, Line, Fluid, and Duct Thread
Axxis ULTs, Satisfied GS5s, Magics, DS2500s...
__________________
***New Points System and Forum Rules***
Problem with a post or thread? Use the report post button - triangle sign on the bottom left.
SmikeEvo Racing Blog
Sponsored by:
Swift Springs
GTWorx
Offline
Old Nov 4, 2009, 07:17 AM   #14
dek0026's Avatar
Drives: WW X
they suck...
Quote:
i am running a complete set of magic pads now and while they definitely are way way lower in dust than the stock pads, they don't bite nearly has hard as the stock pads and mine don't squeal/squeak unless they're really really hot (like from bedding them in)
Offline
Old Nov 5, 2009, 03:05 PM   #15
Silver Sponsor
Personal Sales Rating: (50)
EVOBrakes's Avatar
Drives: RIP 05 STi / C5 Z06
Send a message via AIM to EVOBrakes
Hawk HPS Pads are great on the Street especially for spirited driving. They can be a little noisy when cold but even pads that are sopposed to be quiet make some noise in cold weather.
- Joe
__________________
EVOBrakes.net
Email: brakeguru@gmail.com or 919-376-1554
DBA4000 FR/RR + Hawk HPS only $599 Link
PFC 2 Piece Rotors - EVO 8/9/MR - $600
Offline
Tags
best, brake, ceramic, change, evo, oe, pads, x
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
