Nov 2, 2009, 08:23 AM
Personal Sales Rating: ( 4)
Drives: 2008 Evo X GSR
Definitely look to KW Suspension.
__________________
Tuned by DG Motors 311whp/325wtq
Offline
Nov 2, 2009, 11:05 AM
Personal Sales Rating: ( 0)
Drives: 2008 Lancer Evolution MR
Zeal/Endless make the Function series coilover for the EVO X. There legit, and also allow for custom spring rates when purchased.
Just picked up some Function T's (nickel plated for longevity and added corrosion protection).
__________________
Hard Right 2 Lift...
Powered By:
GSTMotorsports
Offline
Nov 2, 2009, 02:59 PM
Silver Sponsor
Personal Sales Rating: ( 63)
If you're looking for a good track-dedicated coilovers, try looking into STANCE GR+ Pro SS-D's
The valving is set to compliment the heavier spring rates.
Lower bracket design also allows you to run HUGE tires with lots of camber adjustments without running into inboard clearance issues!
Just ask Goofygrin... he's on STANCE GR+ Pro SS-D's with 275 Hoosiers and running -4.5 degrees of camber...18x10.5 +15 Enkei RPF1's.
__________________
www.TougeFactory.com
1201 Busse Road
Elk Grove Village, IL 60007
847.290.1531
www.STANCE-usa.com
www.versionSELECT.com
PM me for BEST PRICING: AMS / ICHIBA / HJC Motorsports Helmets / Whiteline /
EXEDY / CARBONETICS / RECARO / OMP / RACETECH / Enkei / Full-Race / PeakBoost / SWIFT Springs.... and much much more.
Offline
Nov 3, 2009, 09:19 AM
2008 Mitsubishi Lancer Evolution
Drives: 2008 Evolution X GSR
Just to add the coilovers also have to double for daily driving. Im' looking for something that would give me the best performance for track and DD.
Offline
Nov 3, 2009, 12:57 PM
I've also heard good things about the HKS Hypermax III coilovers.
Does anyone have experience with these?
Offline
Nov 3, 2009, 09:23 PM
Drives: Evo X GSR
why doesn't anybody ever mention muellerized JICs?
__________________
EVO X GSR
UR 3" single Cat Back Exhaust
UR 02/dp and testpipe/mini muffler
HKS drop in filter
Custom tune by HB Speed
Muellerized JICs
Offline
Nov 4, 2009, 10:44 AM
I completely forgot about the Meullerized JIC coilovers ... he's really good with evo suspension tuning.
THANKS!!!!
Quote:
__________________
DG Tuned 300whp Evo X *Stock Cat*
ETS 3" Intercooler & piping
HKS Hi - Power Exhaust
HKS SSQ BOV
AEM Intake
Ichiba Down Pipe
Hotchkis Sway bars
BC Racing BR Coilovers
Offline
Nov 4, 2009, 11:21 AM
Quote:
Originally Posted by raytrix
Robi spec KW3 are really good track coilovers and they can be pretty stiff if you want them to be.
Thats what I run in my car and they've done good by me!
__________________
08 GSR - Best ET so far 12.1
Offline
Nov 4, 2009, 01:50 PM
Drives: Evo X GSR
Quote:
THANKS!!!!
They make you fill out a detailed driving survey before your appoinment, in order to asess the best suspension setup for your driving and goals.
__________________
EVO X GSR
HKS drop in filter
Muellerized JICs
Offline
Nov 4, 2009, 03:34 PM
Personal Sales Rating: ( 13)
Drives: Evo X
I'm also looking for something. Lots and lots of options out there.
Wanting something around 1500. For Autox / track days / and driving there.
The Stance so far seem the best option. Hard to say between the SSD or just the pro model. The SSD has 14/12k rate and the pro has 10/9k rates. Any advice on those rates? The 14/12 seems very aggressive.
Maybe even the Meullerized JIC coilovers but they are more than I want to spend.
Offline
Nov 4, 2009, 03:42 PM
Personal Sales Rating: ( 5)
Drives: 00 Eclipse GT SDS Stg. 3 & 08 RR EVO X GSR
Might want to look into AMR coilovers... another option.
__________________
List:
-CBRD Tune -COBB AP -COBB UICP, LICP, BOV HP -COBB SFI -COBB Turbo Inlet Pipe -COBB Sway Bars -ETS 4" FMIC -AMS DP -T1R Exhaust -MXP TP -FORGE WGA -xMR Catch Cans -AMS Front Rollerstop -AMS Fuel Rail -evoDynamics 3 Port -Deatschwerks 800cc -Techna-Fit SS Lines -TWM Short Shifter -WORKS Bushings -SWIFT Sport-Mach's -Whiteline Kit -AEM UEGO -STRI PSI Gauge -Rally Armor Mudflaps -PERRIN 3" Ant.
Future:
ROTA Torque
CBRD BBK Turbo
Kelford Stg.2 w Springs
SteepSpeed Exhaust Manifold
Online
Nov 4, 2009, 08:03 PM
Drives: 05 Apex VIII
Wow so many options. For a daily driver who doesn't go to the track often, what would you guys suggest for under $2k? I want quality suspension but don't need that much adjustability. I go to an occasional HPDE 1-2x a year.
Offline
Nov 4, 2009, 08:18 PM
Silver Sponsor
Personal Sales Rating: ( 20)
Drives: 2004 STi
Quote:
These rates show that they do not understand how the EVO suspension works. This is very basic stuff and they're getting it wrong. Like freshman year, Intro to Suspension Dynamics 101 stuff. Chapter 2, in bold letters, in it's own box in the sidebar so you KNEW it was going to be on the test. Seriously.
YOU DO NOT WANT SOFTER RATES IN THE REAR ON THE EVO IF YOU CARE ABOUT HANDLING.
My advice on those rates is to avoid them and anyone who pushes them because they do not know what they are doing. And spring rates are the EASY part when it comes to coilovers.....shock valving is what's difficult. If they can't get that right...well then it says a lot.
Sorry to lecture and i know it sounds harsh, but it's the truth.
edited for "emphasis"
- Andrew
Reason: there.
Offline
Nov 4, 2009, 09:35 PM
Silver Vendor 2004 EvoM Shootout Champion
Personal Sales Rating: ( 23)
Drives: evo8
Quote:
Originally Posted by Sleestack
Not to hijack but I'm going with an ASt monotube 5100 setup. Anyone else running these?
Yes I run them on my 08 GRB Sti...GREAT... but in a different price range (and worth it) One reason I have built my business on the KW V3 "system" is is is the least expensive true independent valved double adjustable suspension out there...
I will be in NJ just before thanksgiving.....want a full set-up?
__________________
ROBISPEC///
EvolutionM Tuner Champion 2004 ///EvolutionM Nitto Tire Champion 2006 ///1st Open Touring Challenge T-3 /// 2nd Limited AWD SS time attack /// 1st SCCUSCC Roadrace /// 1st & 2nd NASA TT Unlimited Class 2005 ///2nd TTR NASA Nationals 2006
"BEST turning AWD EVO, I've driven!" - Best Motoring's Keiichi Tsuchiya
Partners:
Buschur Racing /// Mike W /// KW /// Whiteline /// ENKEI /// Nitto Tires ///STASIS ALCONS /// APR
robispec.com
"...live a little!"
Offline
Nov 4, 2009, 11:03 PM
Drives: Evo X
- Andrew
So would swapping the springs around if they fit hypothetically, to 12/14K be the better way to go?
What company has gotten the spring rates right? Everyone I have seen does higher rates in the front.
Offline
Tags
bc, camry, coilover, coilovers, daily, driving, er, evo, evolution, evom, gr, jic, muellerized, rates, spring, ssd, stance, suspension  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
