Oct 8, 2009, 01:18 AM
Personal Sales Rating: ( 0)
Drives: Evo x Mr PB
High pitched squeak from brakes?
whats goin on, a cousin of mine said it was dust on the brakes or something. it wasnt that bad before but now its pretty intense when i push the brakes all the way down.
Offline
Oct 8, 2009, 01:25 AM
Personal Sales Rating: ( 1)
Drives: BBY Evo VIII
Get a can of brake cleaner and clean everything off. How many miles do you have on your car? Could also be something stuck in your brake system. Best bet is to take the wheel off and inspect your pads then spray them down with brake cleaner if you can't see anything visiable.
Offline
Oct 8, 2009, 01:25 PM
Personal Sales Rating: ( 9)
2008 Mitsubishi Lancer Evolution
Drives: HBSpeed Tuned X GSR | STi
it's pretty normal with the brembos, usually occurs at slow speeds
__________________
JOEY | '08 GSR 326HP/344TQ | '10 STi
| HKS Legamax Catback | AEM Intake | Nisei MB Pipes | ETS 3.5" IC | Cobb AP, Rear Sway | Walbro | DW 800cc | UR DP/O2 | RRE RallyCat | WORKS SSK, Base Bushings | AMS Cable Bushings | ARC Ti Knob | T1R Boot | RalliArt AC Panel, Taillights | BC Racing Coilovers | Volk CE28N TA 18x9.5" +24 | JDP RA Lip | APR CF VG, CF Rad Panel, Grill Cover | Defi Boost, CUII | Rexpeed Spats, Vents, Hood Dampers | OEM Visors, Trunk Spoiler, '09 Cupholder |
Offline
Oct 8, 2009, 02:23 PM
Drives: RR Evo X
yeah get use to it. You can search and find some better pads that have less brake dust but other than that a trip to the car wash to blast that dust out once a week helps.
Offline
Oct 8, 2009, 08:05 PM
Drives: Evo x Mr PB
I have 5 k miles on my car. I wanted to go to the stealership but they are like 1 hour away and I also could get the recall stuff out.
as far as the brakes go, I can do that, can I just get a power washer and do work
its kinda ****ty how after 5k they sound like that.
Offline
Oct 8, 2009, 09:21 PM
Drives: 2008 Apex Silver Evo x
Its just the nature of the beast. These pads are extremely dirty and noisy ( at times).
__________________
Dane
PSU'11
2008 Evolution X
Apex Silver
Speed Circuit Wicked edition exhaust
Speed Circuit Test Pipe
HKS Drop In
Offline
Oct 8, 2009, 11:08 PM
Drives: Evo x Mr PB
so should i take it to the dealer so they can do it and look at everything else to make sure its ok. AND do the fuel recall/hood latch recall???
Offline
Oct 8, 2009, 11:24 PM
Personal Sales Rating: ( 13)
Drives: cheetahs crazy with his Evo X MR
If you have 5k miles on your evo, odds are they already did the hood latch recall (maybe not though).
I don't think they will do anything about noisy brakes. Kind of the way it is with performance brakes. The noise is either between the pad and the caliper or the pad and the rotor. To fix the rotor, use some brake cleaner. To fix the caliper noise put some high temp grease on the friction lining on the outside of the brake pad.
GL
__________________
2008 Evo X MR GG -- New
2003 Evo VIII RR -- Sold
2004 Lancer Ralliart LB -- Sold
English Racing -- MidgetSpec -- ETS -- Ralli ////Art -- Blitz
Quote:
Originally Posted by EvosnatcH
Welcome to your new addiction, its kind of like crack with out all the side effects minus the burning hole in your wallet
Offline
Oct 8, 2009, 11:33 PM
Drives: Evo x Mr PB
i have, No idea how to do that, wtb tutorial plox
Offline
Oct 8, 2009, 11:34 PM
Personal Sales Rating: ( 6)
Drives: Evo X GSR
the squeal on my pads go away after a car wash...but like others said, these are some dusty pads. they get the job done, though. your best bet is getting some low dust pads. actually...any non-race pads will probably have less dust.
__________________
SEIBON skirts + diffuser + rear ext + ralliart tails + CW hood ✔
Rexpeed vents + gurney flap + grill ✔
Nisei UICP + UR LICP + AGP FMIC ✔
WORKS .9" springs + AMS bushings ✔
Defi boost gauge ✔
moleskin ✔
AMS O2 dp + cat pipe ✔
Ralliart front strut bar ✔
Magnaflow Cat-back ✔
HKS Kansai rear bar ✔
Vibrant resonators ✔
HKS WGA + HBSpeed ✔ (338.1ft/lbs, 350whp)
Volk TE37 + Toyo T1R ✔
Whiteline sway bars ✔
Blacktop Aero lip ✔
Titek carbon panel ✔
Girodisc Stage 4 ✔
Offline
Oct 8, 2009, 11:41 PM
... with all that being said, be aware that aftermarket pads are known to burn through rotors. You have nice 2 piece rotors, would be a shame to burn through them.
__________________
Offline
Oct 9, 2009, 10:14 AM
Drives: WW X
Quote:
it's easy. go on youtube watch the videos for how to change brembo brake pads.
then jack it up and remove the pads and grease the hell out of the backs (the opposite side that sits in the caliper) with brake grease. you can get the grease in small packets at the counter of a autoparts store. they're like 99 cents.
i figured out how to do this and i am no expert.
Offline
Oct 9, 2009, 11:39 AM
Drives: Evolution X GSR Graphite Gray
The squeal could be due to any of the following:
1) dust (solution is to clean)
2) design of the non-spring loaded stock monoblock callipers which in general tend to transmit more sound than a spring loaded multi-piece calliper. (No real solution until next pad change)
3) Glazed rotors (since you are under 12000 miles, mitsu will give you one free rotor-cut if you take in the car with this complaint)
4) If you are comparing it to a daily driven car like a camry/accord, remember that stock pads on these cars are ceramic pads which are low performance, but also low on noise and dust. The evo's pads are metallic, which translates to high-performance, high dust and higher noise.
For (2), at your next pad change, you can opt for some anti noise shims like those sold by girodisc.
I am however surprised that you hear the sound when you depress the brake pedal all the way in. In my case, it only happened when light-braking, beats me!!
hope that helps.
Offline
Oct 9, 2009, 11:40 AM
Drives: WW Evo X
A thread like yours pops up every week (do a search). Car and Driver tested the Evo MR and the RA and the braking distances were 158 feet and 184 feet respectively. The squealing is a badge of honor; you are not driving a RA.
Offline
Oct 9, 2009, 05:03 PM
Drives: Evo X GSR
Quote:
where the hell did you hear that...
__________________
Defi boost gauge ✔
moleskin ✔
Blacktop Aero lip ✔
Girodisc Stage 4 ✔
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
