Oct 7, 2009, 05:32 PM
Personal Sales Rating: ( 2)
Drives: 06 RR Evo RS (sold ) RR Evo X GSR
Mitsu's S-AWC, Subaru's Symmetrical system, Audi's, etc...
Is the Evo's the best one out there? I know a bunch of car companies have these types of systems... are they all basically the same?
Offline
Oct 8, 2009, 08:49 AM
Personal Sales Rating: ( 0)
Drives: WW 2010 EVO X GSR
I've been working in Audi in Korea for couple years before I came to the states
As far as I know the S-AWC that Mitshu came out with on the EVO is somewhat the latest generation of all wheel drive system. Audi's latest AWD system will be out with the new B8 S4's. The upgraded feature is torque couldn't be moved side ways (from left wheel to right wheel) only could be distributed from Front to Rear wheels.
Big difference is Mitsu's S-AWC is electronically controlled AWD and AUDI is I'm not too sure which words to use but mechanially controlled AWD.
Hope it helped your understanding a little bit..
Offline
Oct 8, 2009, 09:51 AM
Drives: 2008 evo
i like subaru's AWD set up much better, symmetrical has equal cv joints, thus no torque steer, the lay out is much easier to work on,
Offline
Oct 8, 2009, 10:08 AM
Personal Sales Rating: ( 3)
2008 Mitsubishi Lancer Evolution
Drives: 2008 Evolution X GSR, 2009 Mini Cooper JCW
Quote:
You're having torque steer issues on your X?
Offline
Oct 8, 2009, 01:55 PM
Drives: 2 ****su's
Easier to work on < Better performance
__________________
RR X GSR
Bolt-ons
Self Tune
VDR Dyno Numbers
Evo-M mode
357whp
366wtq
Offline
Oct 8, 2009, 02:16 PM
Quote:
That may be one of those "in theory" statements.
Offline
Oct 8, 2009, 02:26 PM
Personal Sales Rating: ( 13)
Drives: Evo X Rally Car
the most productive or successful is the S-AWC from Mitsubishi.
Why?
Because by plane numbers /engineering point of view/ most of the time against lighter - more powerful- better shaped- better weight distribution - better gear ratios car can not get away from the mighty evo AWD system.
And this is just one point of view. The other one which is just as big then the first one, usually the most easiest car to drive vs the competitions.
So what else you can actually want form the AWD system to being prove the best?
Rob
__________________
Rallyarmor - Schroth Racing - Endless - Hot Bumpers - Forced Performance ( RED ) - Driver Technologies- HMS Motorsport- Toyo tires - AMR Engineering - Speedline Corse -BRIAutoengineering - AMS Performance
HARracingusa.com
Offline
Oct 8, 2009, 02:30 PM
1998 Mitsubishi Eclipse My Garage
Drives: '05 WW CT9A GSR SSL, '98 NW D32A
Fans of the other systems will tout the symmetrical or more traditional layouts of systems from Nissan, Audi and Subaru because they are RWD based cars with FWD added to make AWD. Mitsubishi starts with a FWD economy car layout and adds the RWD. Most other cars that use a FWD biased layout like Audi and Volvo for instance, aren't known for their handling prowess. However Mitsu uses this layout to great success and Evo has all the accolades to prove it. It has the world's premier AWD system.
__________________
Skeet
Driven to Thrill
Offline
Oct 8, 2009, 02:39 PM
Personal Sales Rating: ( 5)
Drives: 00 Eclipse GT SDS Stg. 3 & 08 RR EVO X GSR
Quote:
The current EVO X, is the the first EVO to have its AWD System designed from the ground up. So they did not start with FWD or RWD, they started with building a entire new system.
Thus it is superior to the EVO VII,VIII,IX systems.
__________________
List:
-CBRD Tune -COBB AP -COBB UICP, LICP, BOV HP -COBB SFI -COBB Turbo Inlet Pipe -COBB Sway Bars -ETS 4" FMIC -AMS DP -T1R Exhaust -MXP TP -FORGE WGA -xMR Catch Cans -AMS Front Rollerstop -AMS Fuel Rail -evoDynamics 3 Port -Deatschwerks 800cc -Techna-Fit SS Lines -TWM Short Shifter -WORKS Bushings -SWIFT Sport-Mach's -Whiteline Kit -AEM UEGO -STRI PSI Gauge -Rally Armor Mudflaps -PERRIN 3" Ant.
Future:
ROTA Torque
CBRD BBK Turbo
Kelford Stg.2 w Springs
SteepSpeed Exhaust Manifold
Online
Oct 8, 2009, 08:39 PM
Drives: Evo X GSR
I'm so confused
__________________
EVO X GSR
UR 3" single Cat Back Exhaust
UR 02/dp and testpipe/mini muffler
HKS drop in filter
Custom tune by HB Speed
Muellerized JICs
Offline
Oct 10, 2009, 03:54 PM
Actually as far as I know Audi's new generation AWD is biased to the rear of 40:60 ratio
It use to be 50:50 ratop
Subaru's AWD is Front biased AWD not to sure about the ratio but i believe up til 07 Sti it was close to 60:40
These days lot of AWD are Rear biased to give a bit of more sporty handling feature like RWD cars
Electronic VS Mechinical AWD
Electronic is lighter compare to Mechanical however it has 0.1 sec of response time where mechanical doesn't have that pause for the system to kick in. Electronic can have errors in programming to cause break down and needs to be checked in long term, mechanical is trouble free specially for Audi's
However both systems are almost equal its just personal preference.
Offline
Oct 10, 2009, 09:22 PM
Drives: Evolution X GSR Graphite Gray
Dang....you had to say it, din't ya?  waiting for the $hit-storm to start...
Anytime now...
Offline
Oct 10, 2009, 09:24 PM
I think the new STIs might be rear biased actually, not too sure though.
EDIT: Found this:
http://www.automobilemag.com/reviews...ancer_evo.html
According to this, the evo is 60:40 F/R and the STI is 40:60 F/R
Offline
Oct 10, 2009, 09:42 PM
Drives: 06 TB Evo IX SE (Sold), 08 AS Evo X GSR, SSS, AERO
I have owned an 05 Sti, 06 Evo IX SE, and now a Evo X and my Evo has by far the best handling out of any of my rides so whatever Mitsu did with it for the X it is amazing in my opinion. Just my .02
Offline
Oct 10, 2009, 09:57 PM
Quote:
Yeah, my old IX RS handled great, but you could feel it more as far as a little bit of a I guess skating feeling maybe? The X has none of it... you just point and shoot. It depends on the feeling you like the most though. No matter which car it was though, I have a safe feeling knowing that if something happens in front of me, I turn and it goes there without hesitation and without worry of losing control.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
