Oct 3, 2009, 11:04 PM
Personal Sales Rating: ( 0)
Drives: 2008 Evolution MR
I want to run 19's
If I wanted to run 19's, what is the most aggressive, wide wheel I could go with without having to do any fender mods?
__________________
2008 GG Evo X MR
-R/F Navi
-Perrin short antenna
-Greddy SE exahust
-Injen Intake
Offline
Oct 4, 2009, 11:17 AM
Personal Sales Rating: ( 4)
Drives: EVO X GSR
You can start by searching, many topics out there already covered this.
But since I don't want to be an a*hole,
19x9 +25 , 255/35R19 lowered by 1.5" fr 1.1" rr no rubbing, any wider and you might rub.
Offline
Oct 4, 2009, 08:37 PM
Drives: 2008 Evo X GSR
I know people running 19x10 ET25 with 265/35/19 rubber on Swifts (-1.0" F, -0.6" R) without issue.
Offline
Oct 4, 2009, 10:53 PM
Thank you sir!
__________________
2008 GG Evo X MR
-R/F Navi
-Greddy SE exahust
-Injen Intake
Offline
Oct 5, 2009, 03:46 AM
Drives: EVO X GSR
Quote:
Ask them to go around a bend aggressively and I'm sure the rear will rub, it rubbed on 18x10 +25 265/35/18 lowered on Eibachs, with coilovers you can prevent rubbing by stiffening the damping.
Offline
Oct 5, 2009, 07:58 AM
Personal Sales Rating: ( 6)
Drives: 2008 Evolution X & 1996 Eclipse GSX
Be sure to compare the tire diameters to verify you are similar to stock values. 275/30-19 is .1" to .2" smaller than the stock diameter where as a 265/35-19 would be .5"-.6" larger than stock and cause more potential rubbing issues. Getting the offset as far inward without hitting the suspension avoids as much rubbing into the fenders as possible which is usually 25-30mm offset. The aggressive tire/wheel combos are usually 9.5-10" wide and around 20mm offset. Running a little more negative camber will tuck the upper portion of the tires into the wheel well better.
__________________
Chris Wirth
RochesterDSM.org
2008 GG Evolution X (New numbers soon!)
- Garrett GT3076R
- Full-Race Tubular Exhaust Manifold - 800 CC Inj - Walbro FP
- ETS 4" FMIC - ETS 2.5" IC Pipes - AMS Intake
- ETS 3" Dual CB - ATP O2 Downpipe w/ 44mm Tial
- MBC 25/27 psi - Works BOV - EcuFlash Tune
- ACT-ME1-HDG6 Clutch - ACT Streetlite Flywheel
- Selling Forge WGA, ETS Headers, & UR O2 DP
Offline
Oct 5, 2009, 12:04 PM
2008 Mitsubishi Lancer Evolution
Drives: Evo X
Quote:
Wow!!! You must have some pretty nice roads in your area because their is NO WAY that we could run 19's up here without damaging the mags... Crapy roads.
Send some pics when it's done. I am sure the look will be crazy!!! Specially the size of the tires. It will be fat ass wide.
Offline
Oct 5, 2009, 12:25 PM
Personal Sales Rating: ( 2)
Limit your boost to 1 psi
Couldn't resist, I'm bored....
__________________
CITI-BANK HAS RAISED THE APR FOR ALL TO 14.99 - PLEASE CHECK YOUR ACCOUNT
Alex
Offline
Oct 5, 2009, 01:12 PM
The Eibach drop is more aggressive than the Swifts, that will make a difference.
Offline
Oct 5, 2009, 11:38 PM
What wheels are you looking at?
Offline
Oct 19, 2009, 04:52 AM
2008 Mercedes-Benz C-Class My Garage
Drives: 2008 mitsubishi evolution x; 2008 mercedes benz c63 amg
i agree with seven_227
i agree with seven_227 on 19x9 25 offset on 255/35's. i use nitto invo on advan rs-d and ohlins coilovers. no rubbing issues anywhere. however tire seems a bit stretched over rim and so i am looking to change to a 265/35 or 275/30 setup. thanks.
Offline
Oct 19, 2009, 12:20 PM
will a 19x10.5 +18 rub at all without fender mods and camber???????????? j/k but thats the setup i want.
Offline
Oct 19, 2009, 03:25 PM
Silver Sponsor
Personal Sales Rating: ( 46)
Drives: LOT's'O'EVO's
we run 19x10 with a WIDE 285,
15mm offset, on kw v3's down pretty low..
trimmed front and rear...
If I wasnt too much of an over achiever, and used a nice 275 it wouldn't have required any front mods lol
cb
__________________
www.cbrdspeedfactory.com
Immaculately prepared facility... State of the Art equipment..
Proven Motorsports Background.. ALMS, Grand-Am, Open wheel...
www.ChadBlock.com
CBRD Radiators, BBK Turbos, Intercoolers, EVO X parts, and CBRD Time Attack EVO backed by Advan
The standard just became standard. Meeting expectations is now not acceptable... we must always exceed them.
Offline
Oct 22, 2009, 08:49 AM
i run 265/30-19 with eibach lowering springs and no rubbing
Offline
Oct 22, 2009, 02:01 PM
Drives: GG Evo X GSR
I run 19x9+25 with 265/30/19 tires and I get some rubbing under hard cornering. Fenders are not rolled but I'm lowered on Stance coilovers
__________________
Graphite Gray '08 Evo X GSR
Power
Greddy Spectrum Elite Exhaust - Cosworth Drop-In Filter - Boost Pill - HB Speed Tune
Suspension and Wheels
Stance GR+ Coilovers - Advan RZ 19x9 +25 Bronze - Muellerized Set-up and Alignment
Vanity
Razo RA24 Onyx Shift Knob - Rexpeed CF Hood Dampeners - Rays Formula Lug Nuts - Advan Low-Type Center Caps - Nokya Artic Yellow H11 Foglights - Piaa Sport Horn 400Hz + 500Hz
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
