Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 3, 2009, 08:58 PM   #1
Personal Sales Rating: (0)
Drives: evo x
How is the rear camber adjusted?
What exactly is modified in order to change the camber in the rear?
Online
Old Oct 3, 2009, 09:31 PM   #2
NTEC Club Forum Leader
Personal Sales Rating: (4)
goofygrin's Avatar
Drives: RR EvoX
There are two eccentric bolts/washers in the rear on each side. One changes toe, one changes camber.
You need two 17mm wrenches. You loosen the nut on one side of the $20 bolt and then turn the bolt head to roll the $10 washer in a slot cut into the suspension arm. Once it's set, then you tighten the nut back down. These bolts/washers last approximately 6-7 alignments before one or the other strips out. In my case it's been the washer. This is especially true if you are aggressively dropped and you're putting a lot of pressure on these pieces to get a good alignment.
Of course if you take it to a place and they can't figure this out by looking at the rear suspension for about 2 seconds, then you need to take the car somewhere else.
__________________
Are you in the North Texas area? Check out NTEC!
mmmm corn
Offline
Old Oct 3, 2009, 09:56 PM   #3
Personal Sales Rating: (2)
Drives: Acura RSX Type S
lol @ pointing out prices. I had no idea the Evo didn't need a rear camber kit until I ordered the BC coilovers. Easiest suspension install ever.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
