View Poll Results: Clear
Clear
0%
Clear
0%
Voters: 0. You may not vote on this poll
All Wheel and Tire Fitment Questions and Confirmations Go Here
#856
Can 9.5" wheels be run on stock tires? Can 10.5" wheels be run on stock tires?
Basically Ive got newish stock sized tires on OEM wheels. I want to get wheels now and then will get wider tires when its time to replace.
Thanks.
Thanks.
#857
I'm curious, can you run 18x9.5 +22 with a 285/35 on just swift sport springs? I know rolling the rear fender is needed but would it rub the stock strut?
#861
Just wanted to see if any here ran this setup and can weigh in.
Not trying but accomplished
#863
You will still need to roll the rears with 265's, unless you find a super skinny 265. I had Toyo R1R and they rubbed. You won't really know until you put them on.
Can you run 265's? Sure. You can, and I did for a while. 275's is just a better fit.
Tread width and wheel size aren't intended to equal one another.
#865
Alright guys. Im not one to typically do this but I need help. I have an Evo x with stock struts and tein lowering springs. I'm getting new wheels but can't decide. Im interested in nt03 and want to know how to make them fit without rubbing and preferably without spacers. If this fails. What would be some decent wheels that fit with my setup without rubbing and again without spacers. Thanks for any input.
#866
You could be ultra conservative and get stock size and offset and run stock rubber. I see they make an 18x8.5+38.
But assuming you want something that sits more flush I think the 18x9.5+27. Run that with a 265/35R18 tire and it'll sit a lot more flush. However, I can't guarantee it won't rub in the rear. That depends on many things (like tire choice, alignment...).
It won't rub much though so a very light roll of the rear fender liner would fix any issues. That's the size I would recommend.
#867
anyone know of a evo x running work emotions xd9 18x10 +18. i contacted work wheels usa, and they said the would clear the front calipers with 25mm spacers , but vendors have told me they will not clear the front calipers.
#868
Well, I mean it depends on how aggressive you want it to be.
