Aug 11, 2009, 11:17 PM
Personal Sales Rating: ( 16)
Drives: Evo X
ce28n 18x9.5+22
I have searched all over looking for an X with ce28n +22 18x9.5 lowered and just cant find what in looking for. I really love the ce28n 10.5 these guys are running just not sure i want to do all the fender work. I would be running 275/35/18 tires and would help if the cars posted had the same size tires. Any help would be great.
Thanks
__________________
I feel the need, The need for speed!
Offline
Aug 12, 2009, 07:55 AM
Personal Sales Rating: ( 0)
Drives: 2008 Rally Red Evo X 2006 APS TT 350Z
Volk Racing CE28N 18x9.5 +22 Diamond Black
Stay tuned, this thread might deliver what you're looking for...
Offline
Aug 12, 2009, 09:01 AM
Someone in the phantom black thread has 18x9.5 +22 flat black CE28N's.
Online
Aug 12, 2009, 11:16 AM
Drives: Evo X
skidmarq, i saw your thread and think its going to give me everything I need. What size tires are you planning on running? I just can believe there isnt more people out there running this setup.
__________________
Offline
Aug 12, 2009, 11:20 AM
That is actually Chebosto's thread but, to answer your question, I would run a 265/40/18 or 265/35/18. If you go wider than that then you start getting into rubbing territory.
Offline
Aug 12, 2009, 11:52 AM
265/40 is definitely the way to go.
Online
Aug 12, 2009, 12:13 PM
Personal Sales Rating: ( 1)
Drives: 350z TT, X MR
i am probably going to run 265/35 all the way around... (havent decided on brand yet.. maybe Toyo R1Rs or Nitto NT05.. or....) i'll be lowered on Kw V3s.. should have some picts up soon
http://www.1010tires.com/TireSizeCalculator.asp
the 265/35/18 is 1.619% too fast
the 265/40/18 is 2.456% too slow
the 275/35/18 is 0.543% too fast (but might have rubbing issues, so i've heard)
i plan on shaving / rolling the fenders
__________________
Cheston & MotoIQ.com Evo X's Sponsors: TechnoSquare|StopTech|Whiteline Automotive|Defi/TEIN USA|AEM|Mackin Industries|Rays Engineering|KW Suspension|Finishline Autocraft. Special Thanks: Z1auto|VIP Status|Evasive Motorsports.
2008 Evo X MR (Follow the build @ www.MotoIQ.com)
2003 350z Twin Turbo (built & tuned by www.TechnoSquareInc.com)
All your trunks, belong to us. Join the Salad Bar Club.
Offline
Aug 12, 2009, 01:15 PM
Personally, I like the look of more rubber (this the 40 series tires). The argument could be made that 35 series will offer better cornering capabilities due to sidewall flex with larger rubber...
Offline
Aug 12, 2009, 03:44 PM
Drives: Evo X
Oh sorry thought that thread was yours  . I am already running 275 on my 19s so was trying to stay the same size. Thanks for all the help guys.
__________________
Offline
Aug 12, 2009, 04:51 PM
Drives: Evolution X GSR Graphite Gray
I woould not go the 265 40 18 route. Check out my recent thread :
What tires to get
look at the last pic I posted, there is barely enough room in there with a 265 35 18 setup. My wheels are the same size spec as what you are looking for in the Volks (18 9.5 +22).
Offline
Aug 12, 2009, 05:46 PM
Drives: Evo X
Ya im running 275-30-19 right now with minimal rubbing so was planning on running the 275-35-18 i think.
__________________
Offline
Aug 12, 2009, 06:44 PM
Quote:
the 275 35 18 is actually identical to the 245 40 18 in terms of radius and as a result circumference, but it is likely to rub because of the increased width. If you take the picture I posted for reference, and increased the width of the tire by 1 cm on each side (inside & outside), assuming you'll get similar tires, it WILL rub. I am running the RE-11 265 35 18 and it is supposed to run narrow in comparison to other tires, and even then, Iam so close to the inner fender surfaces.
I guess, if you are okay with a little bit of rubbing or if you are gonna get some fender work done, then you can go ahead with your choice of size, otherwise, do not go beyond 265 35 18.
Offline
Aug 14, 2009, 12:05 AM
Drives: Evo X
Thanks for the info CatalysGod, I think im gonna rent a fender tool off a memeber on this site and try running the 275s so I can keep the height the same.
__________________
Offline
Aug 14, 2009, 10:02 AM
good luck
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
