Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 15, 2009, 08:20 PM   #1
Personal Sales Rating: (1)
Widest wheel/tire combo
I plan on getting a GSR and putting KW coilovers on it. What is the widest tire/wheel combo that will give me the most grip on the track. I don't mind rolling my fenders. I just don't want anything that sticks out too much.
Offline
Old Jul 15, 2009, 09:26 PM   #2
Personal Sales Rating: (2)
Guru's Avatar
Drives: 08 EVO X WW GSR SSS Aero Navi
Go +30 to +35 to get the wider tires on there. Anything less than +30 and you'll have trouble getting 275's to fit without rolling.
__________________
Dan
Thinking of a Blouch Turbo? Read this first:
http://forums.evolutionm.net/service-parts-tuning-review/375268-stay-away-blouch-turbo.html
Offline
Old Jul 16, 2009, 12:25 AM   #3
Quote:
is this on a 10.5 in wide wheel?
Offline
Old Jul 16, 2009, 12:51 AM   #4
Personal Sales Rating: (0)
Drives: EVO IX
i have a friend that is running.. 19x10.5 +? (i'll try and find out..)
on 275 all around.. and he only had slight rub after rear fender roll'd. if your running KWs then you may be able to take out the rubbing with an agressive camber in the rear.
Offline
Old Jul 16, 2009, 01:41 AM   #5
Personal Sales Rating: (6)
endGameXIII's Avatar
Drives: Evo X GSR
i think a stiffer compression rate would prevent it from compressing enough to rub.
__________________
SEIBON skirts + diffuser + rear ext + ralliart tails + CW hood ✔
Rexpeed vents + gurney flap + grill ✔
Nisei UICP + UR LICP + AGP FMIC ✔
WORKS .9" springs + AMS bushings ✔
Defi boost gauge ✔
moleskin ✔
AMS O2 dp + cat pipe ✔
Ralliart front strut bar ✔
Magnaflow Cat-back ✔
HKS Kansai rear bar ✔
Vibrant resonators ✔
HKS WGA + HBSpeed ✔ (338.1ft/lbs, 350whp)
Volk TE37 + Toyo T1R ✔
Whiteline sway bars ✔
Blacktop Aero lip ✔
Titek carbon panel ✔
Girodisc Stage 4 ✔
Offline
Old Jul 16, 2009, 08:29 AM   #6
NTEC Club Forum Leader
Personal Sales Rating: (4)
goofygrin's Avatar
Drives: RR EvoX
With a 10.5" wheel, if you go much less than +15 offset you're going to be running into the strut/coilover with 275 tires. I had about 2-3mm clearance before I got new mounting brackets from Stance.
__________________
Are you in the North Texas area? Check out NTEC!
mmmm corn
Offline
Old Jul 16, 2009, 09:15 AM   #7
I only want to dial in camber if it is the optimal settings for street/track use. I do not want to add camber just to make the tires not rub.
Would a 9.5 in rim work better with 275 tires? I care mainly about getting the best track performance while still being able to drive it everyday.
Offline
Old Jul 16, 2009, 09:32 AM   #8
goofygrin's Avatar
Drives: RR EvoX
My RPF1's (18x10.5+15) with 275/35/18 RA-1's don't rub except on the fender liner at full lock (and that could be smoothed out with a heat gun, except it's illegal for my autocross class).
That's front fenders slightly pulled, rears rolled and pulled.
Even 285/30/18 Hoosier A6's didn't rub except at full lock.
A 275 on a 9.5" wheel will give you worse performance than a 275 on a 10" or 10.5" wheel. You might be better off going with something skinnier in order to keep the sidewall from bulging.
ETA: I'm running -2.8* to -4.5* of camber up front and -1.3* to -2.2* of camber in the back (depends on what I'm doing).
Try shooting for -3* up front and -1.2* to -1.8* in the rear for the track (autocross is a different story).
You can kind of see how much I rolled it/pulled it in this pic:
And it does tuck:
__________________
mmmm corn
Offline
Old Jul 16, 2009, 11:25 AM   #9
goofygrin, what suspension are you on? I can't really tell from the pics, but do they stick out a little? i was hoping to avoid the lowrider look where the wheels stick out.
If I run -3 up front, won't that cause unusual wear on the streets? I was hoping to not get a set of track wheels. I just want to run on 275 Star Specs on the street and track. I will probably do about 10 track days per year.
Offline
Tags
105, 22, 275, 30, combo, combos, evo, rock, series, tire, tireswheel, wheel, wheels, wheeltire, widest, x
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
