Well the Tirerack chart is right but it's really the ratio of front to rear traction that determines if a car oversteers or understeers. Also factor in driving style, temperatures, and what adjustments were made to the car to handle the way it does all can effect how a car handles under various conditions. This is from reading various articles online and practical experience.
All tires have an optimum pressure (and operating temperature) for maximum grip and keeping them at an even temperature across the contact patch is usually the aim. Usually grip increases as you lower the tire pressure until a point where the sidewall becomes so soft that it rolls over in turns. Exessive heat from a sidewall flexing too much will make a tire more slippery. An exception to this would be straight line drag racing, then going somewhat lower than optimum can still increase traction assuming you don't need to turn the car.
So if fronts are Optimal, and rear are set for Optimal +4 PSI, you will run cooler than optimal in the rear with more sidewall stiffness, slightly less contact patch, and more Responsiveness. Having Less Traction in the rear of the car in relation to the front results in more
oversteer. You could also have the front at optimal and rears Optimal -4 PSI in which case you would flex the sidewalls more and increase heat to where they would become more slippery with less responsiveness.
If you were Optimal -4 PSI in the front, and rear at optimal, this would induce
understeer compared to previous example. Now you have less traction up front due to overheating tires rolling over on the sidewalls and getting slippery where as the rears are still at the optimal pressure compared to the front. Go the other way and have Optimal +4 PSI front with rear at optimal and you would see more responsiveness from the front tires but less traction, slightly less contact patch, increases sidewall stiffness.
Both examples would assume these are hot running temps and you are out on a track where you need make turns.
A better way to do a chart would be:
Adjustments......... Decrease Understeer..................... Decrease Oversteer
Adjustments........... Increase Oversteer..................... Increase Understeer
Front ....................... More Traction ................................. Less Traction
Rear ........................ Less Traction ................................. More Traction
You can check this link out, mainly shows how all the different mods effect how the car handles, and how going too far in either direction will reduce traction at that end of the car.
http://www.lfsforum.net/showthread.php?p=1074405
and
http://www.racelinecentral.com/RacingSetupGuide.html (More for a circle track setup but if you filter out that part it's an interesting read)
Using the tire pressures to reduce traction at one of the car or another is basically a band aid since now you are sacrificing some of your total available traction from your tires limited contact patch in an effort to control the cars behaviour. The best option is to have front AND rear tires at optimum pressures for the temperatures you are using them at and tune the car's handling characteristics with suspension adjustments to where you want it to be.
__________________
Chris Wirth
Onelap.RochesterDSM.org
2008 Evolution X (11.7 @ 118 mph)
- Garrett GT3076R - Prototype Intake Manifold
- Full-Race Tubular Exhaust Manifold - 800 CC Inj - Walbro FP
- ETS 4" FMIC - ETS 2.5" IC Pipes - AMS Intake
- ETS 3" v1 CB - ATP O2 DP w/ 44mm Tial
- MBC 25/27 psi - Works BOV - EcuFlash Tune
- ACT-ME1-HDG6 Clutch - ACT Streetlite Flywheel
- 275/30-19 Yokohama ADVAN Neova AD08 on 19x9.5 Kosei K3 Wheels
- BC Racing ER Coilovers (10k/10k) - Rear Anti-roll Bar
