Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Mar 19, 2009, 01:55 PM   #1
NTEC Club Forum Leader
Personal Sales Rating: (4)
goofygrin's Avatar
Drives: RR EvoX
Stock Wheel and Alignment Specifications
Wheels
Stock
GSR Enkei: 18x8.5 +38 ~22 pounds
MR BBS: 18x8.5 +38 ~19 pounds
Centerbore/hub size: 67.1mm
Common Upsizes
The most common upsize that can be run without needing fender modifications is 18x9.5 +22.
Any lower offset might require you to roll your rear fenders.
Tires
Stock
245/40/18 -- NOT DIRECTIONAL (so they can be rotated normally)
Common Upsizes
The "best fit" upsize is 275/35/18. However, tires of this size tend to require a wide wheel (10+ inches). Also they will likely rub on the inside of the wheel well in front at full lock. The most common upsize is 265/35/18. This results in a slighly lower tire height/circumference. This means that your speedometer will read 60mph when you're really going a couple miles slower.
Alignment
Stock
The stock alignment is typically messed up when the car is first delivered, just like on the 8 and 9. It might be a good idea to get it checked.
Per the service manual the stock alignment is:
Front:
Toe-in: 0.07* (per side, 0.14 total)
Camber: -1* (per side, non-adjustable per the manual)
Caster: 4* (non-adjustable).
Rear:
Toe in: 0.06* (per side, 0.12 total)
Camber: -1* (per side)
You can get a "free" -1*+ of camber in the front by removing the wheel, removing the top strut bolt, and flipping it such that the white dot of paint on it points away from the strut (this is the same on the 8 and 9). You will need an alignment after you do this since it will make the toe change.
"Aggressive Street" Alignment
The general consensus is:
Front:
Toe: 0*
Camber: -1.5* to -2* each side
Rear:
Toe: 0* (or the stock 0.06* toe in)
Camber: -1*
Autocross Alignment
This will require camber plates. These are just base guidelines.
Front:
Toe: 1/4 to 3/8" total toe out
Camber: -3*+ camber per side
Rear:
Toe: 0*
Camber: -1* to -2*
Track Alignment
This will require camber plates. These are, again, just base guidelines.
Front:
Toe: 0*
Rear:
Toe: 0*
Camber: -1* to -2*
Alignment Gotchas
  • Unlike Subarus, Evos are "rear steer" meaning that the steering components are behind the center of the wheel. What this means is that when you increase negative camber, you increase toe in. This makes it more difficult to change from a street friendly camber setup to a more aggressive track camber setup because you have to adjust the toe back out.
  • When the car is turned on, the front toe tends to drift. Be sure to have the alignment tech start your car before calling it finished. Mine drifts 0.07* out (equally on both sides).
  • The driver's weight will affect the toe and camber. My weight, on my suspension, changes the camber 0.2* and the toe slightly. If you are a "person of size" then it might be beneficial to either be in the car or put weights in the driver's seat to compensate.
  • Setting the rear toe on a lowered Evo can be difficult. Normally the camber is set and locked and the toe is then adjusted. By changing the rear suspension geometry by lowering the car, the tech might be forced to work both toe and camber at the same time to get the alignment correct.
__________________
Are you in the North Texas area? Check out NTEC!
mmmm corn
Offline
Old Mar 19, 2009, 02:23 PM   #2
Personal Sales Rating: (0)
Drives: EVO X GSR
Hey Goofy, nice job! Good info here.
Later, Ken
__________________
AMS Intake and Exhaust
AGP FMIC&U-L pipes
Iveytune
Robispec K&W
Offline
Old Mar 19, 2009, 03:11 PM   #3
EvoM Super Moderator
Personal Sales Rating: (3)
2002 Ford Focus
SmikeEvo's Avatar
Drives: 2002 SVTF, 2006 Honda Aero, 2008 Lancer GTS, 2006 Galant GTS
Send a message via AIM to SmikeEvo
Great job!
__________________
***New Points System and Forum Rules***
Problem with a post or thread? Use the report post button - triangle sign on the bottom left.
SmikeEvo Racing Blog
Sponsored by:
Swift Springs
GTWorx
Offline
Old Mar 19, 2009, 03:29 PM   #4
2008 Mitsubishi Lancer Evolution
MrBonus's Avatar
Drives: 2008 Evolution X GSR, 2009 Mini Cooper JCW
Send a message via AIM to MrBonus
Great post. Always appreciate the information.
Offline
Old Mar 19, 2009, 03:45 PM   #5
EvoM Moderator
macPSU's Avatar
Drives: RR Evo X GSR
Send a message via AIM to macPSU
Awesome post, great information.
Thanks!
__________________
2008 Rally Red Evo X GSR
AMS Intake | AMS UICP | AMS FMIC | AMS LICP | AMS O2/Downpipe | AMS HFC | Buschur Catback (modified) | Ivey Tune 340whp 338wtq
Eibach springs | Advan RS 18x10 +25
We Are Penn State!
Live it. Learn it. Love it.
Offline
Old Mar 19, 2009, 07:15 PM   #6
amrock88's Avatar
Drives: Evo X GSR Apex Silver/ 99 Silverado 2500
Send a message via AIM to amrock88
this is good stuff, thanks man
__________________
EVO X GSR Apex Silver SSS
Modifications-
Cobb Accessport Stage II
Cobb SF Intake
Cobb Turbo Inlet Hose
Buschur Racing Quiet Muffler CB
Greddy Downpipe
Ultimate Racing Straight Test Pipe
HKS Drop-in (laying around)
OEM Front Brake Air Guides
Falken Azenis ST115 Tires
Escort Passport 9500i
Offline
Old Mar 19, 2009, 11:20 PM   #7
Personal Sales Rating: (1)
Drives: Evo X MR
Front:
Toe: 0*
Rear:
Toe: 0* (or the stock -0.06*)
Camber: -1*
[/quote]
I think you meant to say "0.06" toe in, not -0.06 toe out here.
Offline
Old Mar 20, 2009, 07:28 AM   #8
goofygrin's Avatar
Drives: RR EvoX
^updated.
__________________
mmmm corn
Offline
Old Mar 20, 2009, 10:44 AM   #9
Personal Sales Rating: (2)
sylnraul_evox's Avatar
Drives: OB Evo X & S2k
Send a message via MSN to sylnraul_evox
When you say "Aggressive", what you specifically mean?......Just want to clarify before I try these specs on my car....can you please explain, sort of a newb here
Thanks.
Offline
Old Mar 20, 2009, 12:08 PM   #10
goofygrin's Avatar
Drives: RR EvoX
Well... if you're the type that runs all season tires and won't mod the car, then stick with stock. If you are lowered and want more handling performance at the potential for increased tire wear, then go for the aggressive alignment.
__________________
mmmm corn
Offline
Old Apr 15, 2009, 02:14 PM   #11
4wd4me's Avatar
Drives: Subaru Impreza RS Coupe #56 STS
happen to know what the center bore size on these two OE wheels is?
Offline
Old Apr 16, 2009, 10:29 AM   #12
Drives: EVO X MR
anyone know the weight of the stock wheels? i'm most concerned with the MR wheels.
Offline
Old Apr 16, 2009, 10:33 AM   #13
4wd4me's Avatar
19lbs,
it's the second line of text in the 1st post
and, the center bore on the GSR wheel is 67.1mm
Offline
Old Apr 16, 2009, 10:36 AM   #14
Drives: EVO X MR
Oh snap... Totally skipped over it. My bad.
Thanks for the awesome info then.
Offline
Old Apr 16, 2009, 10:42 AM   #15
NMX
Drives: Evo X
Edit: Others beat me to it...
Offline
Tags
2006, 8, adjusted, aggressive, alignment, caster, evo, evolution, lancer, mitsubishi, spec, specs, street, toe, wheel
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
