Apr 25, 2009, 05:37 AM
Personal Sales Rating: ( 1)
Drives: 08 EVO X GSR
Front:
Toe-in: 0.07* (per side, 0.14 total)
Camber: -1* (per side, non-adjustable per the manual)
Caster: 4* (non-adjustable).
So does this mean that front caster can never be changed. It will always remain at 4? Until you get aftermarket suspension I suppose.
__________________
mods:
ETS 3.5" FMIC, ETS Upper & Lower IC pipes, ETS intake, Buschur Racing dual CBE, Ultimate Racing test pipe, Perrin oil catch can, Agency Power V2 shorty antenna, Greddy 52mm boost gage, HKS Type 0 turbo timer
Offline
May 1, 2009, 10:32 PM
Personal Sales Rating: ( 0)
Drives: 2008 EVO X GSR
EDIT: Posted question in the main forum.
__________________
2008 Evo X GSR GG, HKS Drop-in, AMS Underhood Shifter Bushings, Tint (18% Ceramic)
Offline
May 6, 2009, 11:24 AM
Drives: evo mr
would these specs work on the evo 9 as well?
Offline
Jun 6, 2009, 09:47 PM
Drives: 2008 Evo X GSR
Can we throw the stock Advans' Rolling Diameter in the OP? Calculated from the 245/40R18 spec it comes to 25.72 in. Can someone confirm what the *actual* size is?
Offline
Jun 8, 2009, 02:31 AM
Drives: WW 2008 X MR
so what is the widest tire you can run on a stock MR rim?
__________________
"For the Tenacious no road is impassable."
"Add Lightness" - Colin Chapman
2008 WW EVO MR
2006 SGM STI -(Sold)
1968 Ford Mustang
!!! BOILER UP !!!
Offline
Jun 16, 2009, 02:37 PM
Just completed a DIY aggressive X alignment. Here's the procedure and results:
Front:
Off with the wheel (13/16 deep six-point).
Pre-adjusted toe, 1-turn out (7/8 & 13mm opens)
Loosened both strut bolts and reversed top cam (19mm deep)
Jacked under the studs (wood block) to remove slop and tightened.
Result: -2.6deg left -2.8deg right 1/8" toe out. Good enough for now.
Rear:
Put a match mark at 12 o'clock on all four cam bolts. (Sharpie)
Loosened and rotated each cam 45 degrees in. (17mm deep & 17 open)
(rotating cam in pushes control arm out for more neg camber)
Result: -1.95 deg each side, 1/16" toe in. Good enough for now.
Got lucky with the toe results based on guessing. Where I used SAE tools it's because they fit better than the metrics. Measured camber with a 24" carpenter square, machinists rule and trigonometry. Measured total toe with a home-built trammel bar and machinists rule. Took me an hour.
FWIW -- Bill
__________________
'08 Evo X MR, silver
Offline
Aug 3, 2009, 03:22 PM
Drives: 350z TT, X MR
__________________
Cheston & MotoIQ.com Evo X's Sponsors: TechnoSquare|StopTech|Whiteline Automotive|Defi/TEIN USA|AEM|Mackin Industries|Rays Engineering|KW Suspension|Finishline Autocraft. Special Thanks: Z1auto|VIP Status|Evasive Motorsports.
2008 Evo X MR (Follow the build @ www.MotoIQ.com)
2003 350z Twin Turbo (built & tuned by www.TechnoSquareInc.com)
All your trunks, belong to us. Join the Salad Bar Club.
Offline
Sep 27, 2009, 10:21 PM
Personal Sales Rating: ( 3)
Drives: X RS
My local shop has camber, toe & caster.
Any specs for the caster?
Offline
Sep 27, 2009, 10:52 PM
NTEC Club Forum Leader
Personal Sales Rating: ( 4)
Drives: RR EvoX
It's non adjustable on the Evo unless you have caster plates... so what you've got is what you get... unless you bend something.
Basically around 4.5 or so is stock.
__________________
Are you in the North Texas area? Check out NTEC!
mmmm corn
Offline
Nov 10, 2009, 03:01 AM
Drives: Evo X MR
What are the advantages/disadvantages of putting on wider tires than the stock ones?
For example, what are the advantages/disadvantages of replacing my stock 245/40/18s with 265/35/18s.
Offline
Tags
2006, 8, adjusted, aggressive, alignment, caster, evo, evolution, lancer, mitsubishi, spec, specs, street, toe, wheel  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
