Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 21, 2009, 11:36 AM   #31
Personal Sales Rating: (0)
Drives: 2008 Evo gsr
Quote:
Originally Posted by Dimon_OD View Post
Did anyone istall 17" on EVO X? I think of using 17" for winter.
I tried TE37 17*8.5 with offset 30 - it doesn't fit, but seems like with offset 20-22 it should fit.
ADVAN GR-II 17*9.5 with offset 22 fits the caliper, but will probably contact with outside fender, so probably 17*8.5 should fit.
Anyone know if 17" Enkeis would clear the front brale calipers on an Evo X? Thinking of getting track wheels, I'd be happier with what would be a taller tire sidewall if you get tires with the same overall diameter.
Thanks
Offline
Old Oct 25, 2009, 03:48 PM   #32
Drives: 2008 Evo X MR
Are these offsets and fitments for the gsr, or mr, because if I remember correctly, the suspension is different if only by a little. I know it is weird, but I was considering using 275/40r18 (for traction and longevity, since I am planning on bf goodrich super sport a/s), and I noticed the 13mm clearance on the inside is approximately 2mm short of the 15mm necessary with stock offset. I am still unsure if when the wheels turn lock to lock they come closer to the suspension or not. Also, I wanted to check out how the wheel liners could be moved to make space for the wider tires, since it seems as if, with the right offset, the fender is not an issue. I am, as it says under my name, a noob, so feel free to ream me for dumbness.
Offline
Old Nov 5, 2009, 04:49 PM   #33
Personal Sales Rating: (2)
jerrym's Avatar
i love this thread
Offline
Old Nov 6, 2009, 08:03 PM   #34
Phantom X Evo's Avatar
Drives: 2010 PB Evo X GSR sss
Just what I was looking for.
Online
Tags
0, 18x9, 40, 95, chart, eclipse, et15, et38, evo, fit, gst, offset, offsets, stock, suspension, wheel, wheels
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
