Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Mar 25, 2009, 01:13 PM   #16
Personal Sales Rating: (6)
Hiboost's Avatar
Drives: 2008 Evolution X & 1996 Eclipse GSX
My wheels were +35 offset and they do have that slightly sunken look. On the plus side I still had 4-5mm clearance to the inner suspension and when driving in rain, the wheels don't send as much debris down the side of the car. This is with 275/30-19 tires and similar to stock overall tire diamters. I did test some 5mm spacers up front and I got some rubbing at full lock on the plastic fenders.
The 38mm offset wheels with 15mm spacers would likely put you in that 23mm offset area that seems about the best compromise without having to do major fender work. You may get no rubbing initially but load the car up and the rear tires may touch occasionally if you don't. One tricky thing with camber is it allows the top part of the tire to tuck under the fender obviously sends the lower half further out. Kind of makes it hard to make it flush no matter what you do.
__________________
Chris Wirth
RochesterDSM.org
2008 GG Evolution X (New numbers soon!)
- Garrett GT3076R
- Full-Race Tubular Exhaust Manifold - 800 CC Inj - Walbro FP
- ETS 4" FMIC - ETS 2.5" IC Pipes - AMS Intake
- ETS 3" Dual CB - ATP O2 Downpipe w/ 44mm Tial
- MBC 25/27 psi - Works BOV - EcuFlash Tune
- ACT-ME1-HDG6 Clutch - ACT Streetlite Flywheel
- Selling Forge WGA, ETS Headers, & UR O2 DP
Offline
Old Mar 26, 2009, 11:16 PM   #17
Personal Sales Rating: (0)
Drives: Evo X GSR
I run 19X9.5 +20 offset with no problem with rubbing or anything (stock tire size). The wheel could honestly use a bit more rubber than stock with 9.5's I think. You will get more debris thrown against the car with the +20 (flush with fender).
However, more importantly (or of concern I should say) is the steering feel impact of the lower offset than stock. I think the steering feel (especially around center) feels a bit dead. I would like to hear some comments about handling / steering feel from going from stock wheel/offset to various configs which to me is more important than looks. Honestly, I liked the stock feel better.
Offline
Old Mar 27, 2009, 10:27 AM   #18
CatalystGod's Avatar
Drives: Evolution X GSR Graphite Gray
Hey Toro, I responded to your other post in the following link:
work cr kai's 18X9.5 20MM
I do not think the offset is what is causing the handling issue.
__________________
Keep yourself informed:
http://www.zeitgeistmovie.com
Offline
Old Nov 6, 2009, 12:48 AM   #19
Drives: 2010 Gray Evo X
Has anybody tried 18x9.5 ET38 RPF1 and and not clear the brembos? or are you guys just assuming it won't clear because of the offset?
Just wondering thats all...If nobody has ever tried it, I was thinking of giving it a shot
Offline
Old Nov 6, 2009, 03:08 PM   #20
Personal Sales Rating: (5)
ScottSpeed21's Avatar
Drives: Evo X GSR
18x9.5 +15 RPF1s with stock size 245's will fit just fine without rolling any fenders and without rubbing. A friend of mine (rallyredx on these forums) runs them on Swift springs with no problems.
__________________
2008 Octane Blue Evo X GSR SSS / Navi / Aero
Engine • Cobb AP • AMS Intake • Nisei UICP & LICP • ETS 4" Intercooler • Tial 50mm BOV • T1R O2 Downpipe • Custom 3" high flow cat • Custom 3" dual catback exhaust
Chassis • Gram Lights 57 Maximum 18x9.5 +22 • BFG g-Force Sport 245/40-18 • Eibach springs • Whiteline rear swaybar
Exterior • APR Front splitter • AMS/Gates gurney flap • Ralliart taillights
Interior • TWM Short throw shifter • AMS shifter bushings • AEM Analog boost gauge
Offline
Old Nov 6, 2009, 08:05 PM   #21
TK40's Avatar
Drives: 05 Apex VIII
Send a message via AIM to TK40
Quote:
Originally Posted by Touge Factory View Post
We're running 18x10.5 +15 with Z1 Star Specs - 265/35/18
Rear fenders are rolled...that's it. no other fender mods.
Isn't 265 a bit skimpy of a tire for a 10.5 wheel? Why not run 9.5's with 265?
Offline
Old Nov 6, 2009, 08:27 PM   #22
Personal Sales Rating: (2)
flyguycfi's Avatar
So can you run the 18x9.5" +15 with 265 tires and NOT roll the fenders? I'm not getting Falken 615's or star specs that are supposedly wider. Think it will be ok?
__________________
2008 Lancer Evolution X GSR
Baseline - 259whp @ 21PSI *stock turbo*
Tuned - 358whp @ 25PSI *stock turbo*
Tuned by TTP Engineering - Orlando, FL
Offline
Tags
15, 18x95, 2005, black, california, enkei, evo, evolution, factory, fenders, pull, roll, rpf1, southern, sti, touge
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
