Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
need help with bc coilovers
Old Dec 6, 2008, 05:26 PM
raz
raz's Avatar
hi i recently installed bc coilovers on my evo x , i got it done at a performance shop now the rear makes a cluncking sound every time i go over bumps, little ones, over the big bumps its fine no problem at all, the shop cannot figure out what it is, they installed my original suspension and the car continue to make that noise,so now its not the coilovers, i have no idea what it could be, and the shop is scratching their heads as well, it sounds like metal on metal like something is loose, any help would be apperiaciated thankyou
Old Dec 6, 2008, 10:24 PM
EvolvedVIII's Avatar
Are there rubber bushings in the rear? If not its just the spring hitting the perch. Metal on metal contact= noise.
It's not a big deal, my Zeals make some noise too.
Old Dec 7, 2008, 03:05 PM
raz
raz's Avatar
do you mean the rubber bushing on the coilovers or the rubber bushing you put in from the original shocks thankyou for any help
Old Dec 7, 2008, 03:36 PM
Rubber between the spring and perch.
Old Dec 7, 2008, 06:34 PM
raz
raz's Avatar
no there is no rubber there, where can i buy it
Old Dec 7, 2008, 06:55 PM
joyce1bro's Avatar
thats why you dont buy BC.
Old Dec 7, 2008, 08:17 PM
ZK
ZK's Avatar
It's pretty normal with coilovers that have pillowball upper mounts. I had a rear clunking on all the 6 coilover sets I've owned on various cars - everything from megans to ohlins. Rubber upper mounts = no clunking.
Old Dec 7, 2008, 08:27 PM
jd888jd's Avatar
Its bcoz its pillowmount...i had BC before same thing happened to me...its normal ..now i got
kW's v3.............all smiles
Old Dec 7, 2008, 11:58 PM
tomatoEVO's Avatar
^ jeez dude, do you have to have such a long sig? size it down at least, damn
Old Dec 8, 2008, 11:53 AM
wongck's Avatar
I don't see how this issue is related to BC coilovers. The problem was still there after turning the car back to stock suspension. Seems like a bad job to me by the shop.
Old Dec 8, 2008, 08:57 PM
raz
raz's Avatar
it came to my attention that they only changed one side of the car to original and then tested it so the noise was still there, so i guessing it was the coilovers, i contacted bc and they make a rubber option so i will be getting a set of these hopefull this fixes the problem
Old Dec 11, 2008, 04:54 PM
ZK
ZK's Avatar
What is the rubber option? It has rubber upper mounts instead of pillowballs?
Mad_SB
58
Oct 6, 2015 06:20 AM
ggevoIX
Apr 23, 2009 07:19 AM
prj.evo
Jan 15, 2008 10:30 AM
Evo8
47
Feb 18, 2007 04:53 PM
jkim2001
Jan 12, 2007 11:50 AM
Quick Reply: need help with bc coilovers
