Aug 28, 2009, 01:00 PM
#31
Personal Sales Rating: ( 0)
Drives: X
^ Hehe, no problem pare... it's an easy setup. Like I said, only hard part is installing that netbook stand. (at least for me) =)
__________________
What does the RA forum "guru" think of the Evo's build?
Quote:
Originally Posted by ambystom01
"The build quality of the Evo is really no better than the average Civic, you could logically argue it is actually worse."
"it'll blow their mind that a hater, troll, slowbaru driver like myself would actually defend(?) an Evo."
100% Stock
Ghetto "Carputer" w/ Evoscan:
Nighttime Video
Daytime Video (carmount setup shown)
Car-webcam added
Custom Gauge Layout I
Offline
Aug 28, 2009, 01:06 PM
#32
Personal Sales Rating: ( 14)
2008 Mitsubishi Lancer Evolution My Garage
Drives: PB Evo X ; 1973 VW Super Beetle
pota sigurado aabutin ako ng siyam siyam bago ko magawa yan  did you get my email?
__________________
2008 PB Evo X GSR, SSS, OEM AW Mats, OEM Navigation, OEM MR Recaro Leather Seats, OEM Splash Guards, OEM Rear Wing Extension, OEM Door Visors, OEM UK F&R Scuff Plates, OEM UK CF Vortex, 2010 Cupholders, OEM BT and Volume Control.
BlackTop CF V-Style Lip, K&N Air Filter, Nisei Red UICP, Rxpd Rear Bumper Extension, Work Emotion XC8 19x10 +35; Kumho Ecsta 265/30
http://www.cardomain.com/ride/3059755
_The Lord will Provide_
Offline
Aug 28, 2009, 01:12 PM
#33
Drives: X
I don't think I did... try it again. BTW, nice loaded X! :-) Gotta love those MR Recaro seats.
__________________
100% Stock
Nighttime Video
Car-webcam added
Offline
Aug 30, 2009, 12:51 AM
#34
Drives: X
Today I stumbled on a Logitech Webcam while cleaning the house, so I immediately thought... hmmm, maybe this will be of some use :-)
So, after a couple of mins, I got it hooked up to the passenger side sunvisor, and then downloaded a free software that does hotkeyed recordings. Here's a sample:
http://www.youtube.com/watch?v=XHzHpNI0DU4
Oh, the Evoscan gauges aren't synced with the recorded vid, since I'm just using a screencapture recorder to publish it.
- ack wrong youtube audioswap track LOL, gotta fix that -
__________________
100% Stock
Nighttime Video
Car-webcam added
Offline
Sep 5, 2009, 08:11 PM
#35
Personal Sales Rating: ( 2)
Drives: 2003 SRT-4 2006 Evo SE
Pretty sick, even though I'm not too sure I would want it in my car.
Online
Sep 6, 2009, 09:51 PM
#36
Drives: X
^ Thanks, this setup is not for everyone :-). Others have posted much better ones, hence why I call this ghetto.
Anyway, got nothing else to do today... so I played around with a new custom gauge layout:
http://forums.evolutionm.net/7478668-post13.html
__________________
100% Stock
Nighttime Video
Car-webcam added
Offline
Sep 7, 2009, 08:29 PM
#37
Personal Sales Rating: ( 1)
Drives: 08 Evo X, 08 Harley soft tail
why does it seem the logger is lagging alot/ the inputs are choppy
__________________
91 306ci 76mm turbo c4 tranny Ford Mustang Hatchback
08 Harley soft tail Night Train
08 Evo x Octane Blue Pearl
Offline
Sep 8, 2009, 02:11 PM
#38
Drives: X
^ It seems laggy cuz the screen capture utilty I used is also laggy... also on those videos, I was logging a lot of stuff that is not actually needed to be on the virtual gauge layout. The more things you log and display on each virtual gauge, the more laggy the gauges will be. Also it depends on what netbook/laptop you use... the one I have mounted is an older model AcerOne w/ the Atom processor (which is decent, but lacking in performance). Running extra stuff on the background also affects performance (ie. my USB in-car webcam).
When I really want to log and get better resolution plus realtime-like performance on the gauges, I only log important stuff (ie. boost level, RPM, Load, TPS, knocksum, speed)... and the virtual gauge layout only displays knocksum & boost. It's very smooth when you only want a couple of gauges functioning on the screen.
__________________
100% Stock
Nighttime Video
Car-webcam added
Offline
Sep 8, 2009, 02:53 PM
#39
2009 Mitsubishi Lancer
Drives: 2009 Rally Red Ralliart
How accurate is the AFR using Evoscan?
__________________
[x] EvoX FMIC
[x] T1R IC Pipes
[x] HKS Drop-in Filter
[x] Rally Armor UR Flaps
[x] Blacked-out Trim
Offline
Sep 8, 2009, 03:30 PM
#40
Personal Sales Rating: ( 28)
Drives: 2005 Electric Blue Evo 8
AFR is as accurate as the input from the Wideband. If you are talking about the AFRMAP that is a calculated field by the ECU.
Offline
Sep 8, 2009, 04:28 PM
#41
Drives: X
Quote:
Evoscan enables you to log both AFR MAP (based on your ECU's tune) and actual AFRs (based on a wideband, if you install one). The AFR MAP is not a necessary thing to log cuz it won't give you the real AFR anyway... but the wideband is a must if you can get one installed.
Everything that is logged on Evoscan (and what you see on the virtual gauges) gives you the ability to see what's going on from the ECU's perspective. For example, if the virtual guage reads boost at 20psi... that is how much boost the ECU is reading from its own sensors (someone correct me if I'm wrong). If you have a real boost gauge hooked up with its own sensor, then it maybe reading a different value (which maybe more accurate than the ECU's reading)... but it could also be the other way around. Important thing is you are seeing info based on the ECU's perspective (as the ECU controls your engine, and reacts to problems based on its programming), and to me that's a better tool to have.
__________________
100% Stock
Nighttime Video
Car-webcam added
Offline
Oct 5, 2009, 09:55 PM
#42
fast and furious...
Offline
Oct 6, 2009, 08:17 AM
#43
Drives: 2008 evo x
Where did the videos go? Why did you take them down?
Offline
Oct 6, 2009, 08:58 AM
#44
Drives: GSR EVO X
Quote:
Originally Posted by WTFchuck
listening to that music u should not be owning an evo
really lol nice
__________________
ams cold air, ams intercooler piping,hks ssqv blow-off, burcshur true-catback loud, tenzo rc-6 18-8.5, nitto gen 235/40/18, lambo doors, shortie anteana, tanabe springs, 35% tint, AEM IN-CAR Boost Control, Cobb AP,Apline head unit and 2apline type X'sSeibon Carbon Parts, hood, trunk, wing, front lip, front bumper,gauge dash cover, rear diffuser
Parts next on the copping block
Carbon Fiber Roof, , Carbon Fiber side skirts and rear bumper sides, 2.3 stroker kit, gt35r turbo kit, clutch&flywheel
Offline
Oct 6, 2009, 02:56 PM
#45
Drives: Evolution X GSR Graphite Gray
Quote:
+1
Offline
Tags
acerone, bt, car, carputer, evolution, evoscan, gauges, make, netbook, show, speed, stand  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
