Mar 11, 2009, 11:41 PM
Personal Sales Rating: ( 0)
Drives: 2008 EVO X GSR
Road Race Engineering Project Evo X
Finally finished the Road Race Engineering Project Evo X and wanted to get some of the pics and information up for all to see the progress and amazing job that Road Race Engineering does.
The project started with a stock Evo X and became an amazing 379 AWHP beast.
I want to thank the sponsors of the project and what they did to make the project possible.
We started the project with the AEM intake, which produced a solid 20WHP. With the simple change of the intake and the power that was received, we saw that there was great potential for the project and the car.
Road Race Engineering than made a custom fabricated exhaust system for the Evo. The Exhaust system started with the Ultimate Racing Downpipe and Art at RRE fabricated the rest. With the Faux catalytic converter and the rear Dual exhaust Art at RRE did an amazing job
All of the performance parts came together once Mike at Road Race plugged into the car with Ecutek and started to Tune. He spent countless hours making sure that it was perfect. If you want your car tuned correctly bring it to Mike at RRE. He spends the time necessary with each vehicle and each customer to make sure that you get the attention you deserve. It is amazing to see what he can do to pull out the maximum power available with each Evo. Mike was able to pull out 379 AWP on pump gas, he did a great job on making the entire project come together and making all of the sponsors parts look good. If you have spent the money on the parts make sure that they are utilized correctly and get the car tuned by Mike at Road Race Engineering.
Forced Performance came on board with the FP Red Turbo, which was a really difficult install but well worth it. For those not aware Forced Performance takes the stock Evo X turbo housing and swaps out all of the internalls to create a mean turbo. This turbo can sustain well over 35psi of boost pressure and still keep turbine back pressure in check due to the proprietary advanced turbine aero and massive turbine blades. Due to the advanced design of the blades the spool up is retained near that of the stock turbocharger. These are the same size internals as used in the popular FP RED™ for the Mitsubishi Evolution 9 which has already propelled cars to mid 9 second quarter mile passes.
Once the turbo was installed there was solid power gains and very little lag. The turbo has been solid with day to day use on the street and will be sure to perform at the upcoming Redline Time attack race. RRE installed a fuel pump to ensure proper fuel distribution. DeatschWerks contributed their 800 CC injectors, which made the entire swap flawless.
The Mishimoto radiator was installed with their nice silicone hosing. The car has run cooler than the stock radiator.
The AGP Intercooler and intercooler piping was used to keep everything cooler and we decided to run the black piping to keep the car stealth. The Synapse Engineering Blow off valve integrated right onto the AGP Piping. Even though everyone hates on the BOV we did notice a better throttle response with the Synapse BOV installed, plus you get the Fast and Furious Whoosh, which everyone loves deep down.
Suspension was next on the list now that we had power taken care of. KW Suspension contributed to the project by offering a brand new set of Variant 3 coilovers. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the highspeed set-up, so decisive for driving comfort, has been preset by the KW engineers.
We wanted the Evo to be able to handle the power to the wheels and knew that the best place to take it was RobiSpec. After a short trip to RobiSpec out in the desert with the KW V3’s in the trunk we were able to get on the lift and start getting rid of the stock suspension and on with the amazing KW V3’s. RobiSpec then installed the rear sway bar and did an amazing job with the install and got everything installed in a relatively short amount of time. After the new KW V3’s were installed the Evo was then set up on the laser guidance system. The car was corner balanced and laser aligned.
The KW V3’s with the RobiSpec Tune is truly amazing. With the setup you get a better ride than stock with exponentially better handling. RobiSpec knows what they are doing and have come to be able to almost perfectly tune the KW setup on the Evo X. With the perfect full race setup from RobiSpec the car was then ready for Rubber.
Nitto Tires has the Nitto NT05.he NT05 is a maximum performance tire that was developed using advanced computer simulation and extensive on-track testing. These development methods along with rigorous quality standards helped produce a street tire that provides precise and responsive handling and performance. The tire is perfect for track and street use. We went with 275/35/18 to fit the Enkei GTC-01 18x10.5 wheels.
The next step was in weight loss. Everything in the trunk was removed and VoltPhreaks offered the VPX 700 Lightweight race battery. The battery comes in at 5.25 pounds compared to almost 35 from the stock. The battery has worked flawlessly in hot and cold conditions. The weight was noticed with acceleration when everything in the trunk was removed and the stock battery was replaced with the VoltPhreaks battery.
We then installed the TWM performance short shifter. TWM does a great job and producing a great product. They also offer an amazing shifter with their short shifter kit. These shift knobs are CNC machined stainless steel and feel great. Redlinegoods.com sent in their high quality leather shift boot with red double stitching. The whole package is way better that the wack stock setup with the pleather shift boot and massive shifter. TWM FTW.
Brake pads were swapped with the EBC YellowStuff and offer superior stopping power over the stock brembo pads.
The AEM Water/methanol injection kit was later installed to give the new FP Red turbo that extra punch. Once installed, the Water / Methanol Injection Kit uses a boost-dependent, variable-flow progressive controller to determine the amount of water / methanol mixture (up to 50%) to feed into the inlet stream from the included one gallon reservoir. The controller commands a progressive 150-PSI pump that delivers the mixture, and flow adjustments at the inlet are made via three included jets designed to match most engine power requirements. The result is significant horsepower gains using pump gas—at about half the cost of Racing Fuel. A pretty difficult install but well worth it in the end.
The project started back in September 2008 and we are now finished. Road Race Engineering and all of our sponsors for the project did a phenomenal job at creating an amazing Evo X. The Evo X will be racing in the Redline Time Attack series as well as other events. If there are any questions on parts or install send a message and I will be sure to answer for you as soon as possible. After all of the work that was done on the car it is amazing to see the potential that the Evo X has. With basic bolt-on’s the Evo X becomes even more incredible.
__________________
Road Race Engineering/ StealthArmor|Forced Performance RED Turbo|DBA Slotted Rotors| Hawk Brake Pads|Exedy Multiplate Clutch Kit|RobiSpec Setup KW V3 Coilovers|AEM Intake|AEM Meth Kit| RRE Custom Exhaust|AGP Intercooler & Piping|AMS DownPipe| Full Race Turbo Manifold| VoltPhreaks Lightweight Race Battery||Nitto NT05 Tires|Enkei GTC-01 Wheels|TWM Short Shifter|DeatschWerks 1000cc injectors|Mishimoto Radiator|AMS Brake Duct Cooling Kit|MOMO Race Gear|Zeitronix Gauge|Mother’s Polishes|
Offline
Mar 11, 2009, 11:52 PM
Personal Sales Rating: ( 1)
Drives: 06' Evo SE
Very nice #s and ride. Which area in Irvine are you from? I live 15minutes away.
Offline
Mar 12, 2009, 01:00 AM
Drives: Blue 08 Evo X
Nice  congrats on the finished project!
Offline
Mar 12, 2009, 01:48 AM
Your the first person ive seen with the synapse bov..379 with fp and meth ? is it me or does that seem a little low?
i didnt see CA so i assume your on 91
Offline
Mar 12, 2009, 05:35 AM
Personal Sales Rating: ( 28)
Drives: 06 SSL and now WW X
can you post some decent pics of different parts in context of the build?
Offline
Mar 12, 2009, 08:29 AM
Drives: 2003 mitsubishi lancer evolution VIII, 2000 toyota corolla, 1994 honda accord coupe
Rre ftw!
Offline
Mar 12, 2009, 08:30 AM
Drives: wicked
tl;dr
cliff notes?
Offline
Mar 12, 2009, 08:37 AM
Personal Sales Rating: ( 25)
2011 Mitsubishi Lancer My Garage
Drives: Evo X
Quote:
Originally Posted by Alexander
tl;dr
cliff notes?
They built an Evo X for T/A.
Good luck out there guys! Glad to see more Evo X's coming out to compete
Offline
Mar 12, 2009, 11:57 AM
Personal Sales Rating: ( 5)
Drives: 2008 evo 10 gsr, 2000 chevy venture L0L ex cars 2006 evo Se
nice number now all the power id from a intake custom exhaust downpipe intercooler with pipes and fp red turbo its thats it that is great bang for buck power
Offline
Mar 12, 2009, 05:19 PM
Nice build. Good luck w/ the Redline T/A.
Offline
Tags
agp, batteries, blow, brakes, catalytic, coming, converter, cooler, engineering, evo, faux, install, mr, roadrace, robispec, sponsorship, valve  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
