Fluid help
Fluid help
2010 mrt with the auto sst trans.
bought it with 85k miles with no service history so*
just correct me if I'm wrong please bear in mind I have not even removed the underpan yet.
From what I researched so far this is what I come up with.
Oil change completed
Buying new plugs soon ( research not done )
bought 2 gallons of SST fluid and a filter
I need 1 quart of 90w lsd and 1 quart of mitsu Atf to service the rear end ?
Front t-case and diff and integrated into the tranny (share the sst fluid)
Flushing coolant/brake fluid
Am I on the right track here ? Did I forget something?
The read diff is ATF on one side, and gear oil on the other. I would also just have the dealership do it. Not worth the minimal money saved for the risk of a massive, massive repair bill. If you do it yourself, make sure the car is perfectly level as well.
BeyondLimitsEvo
17
Jun 5, 2015 03:18 PM
