Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Ulitmate DIY Transfer case, TC-SST Transmission and Rear Differential fuild change.
Old Jan 28, 2011, 08:26 PM
Logitech80's Avatar
Rear Differential drain bolt. Labeled gear oil with arrow. "Big Bolt"
Rear Differentiall Fill up hole. Labeled Gear oil with arrow.
" Bolt is facing toward front of vehicle"
[/quote]
what about ATF SP3 Fluid??.. dont need to drain that??
Old Jan 29, 2011, 04:44 AM
Logitech80's Avatar
Does ATF needs changing or just checking?
Old Jan 29, 2011, 07:46 AM
bradze's Avatar
yeah how often should you change that? i track my car about 10 times a year
Old Feb 1, 2011, 03:15 PM
bradze's Avatar
changing the diff fluid tomorrow, am i going to have to come back and for the ATF?
Old Feb 2, 2011, 08:47 AM
LaXGSR's Avatar
ATF SP3 is used for two components:
1) ASC (with reservoir in truck)
2) part of the rear-differential
The ASC component does NOT need to be drained or refilled (this part holds over 7 quarts I believe).
However, the rear-differential component that takes ATF fluid should be drained/refilled. That component uses less than 1 quart. You will see fill and drain bolts with arrows pointing to them with "ATF" labeled.
Old Feb 2, 2011, 02:16 PM
Logitech80's Avatar
Thanks... I see the draining area but is there a fill plug for ATF ?
Old Feb 2, 2011, 02:20 PM
LaXGSR's Avatar
Originally Posted by Logitech80
Thanks... I see the draining area but is there a fill plug?
Yes, make sure you find the correct fill plug and can loosen it before draining. Loosening the fill plug first is always a good idea in case you have problems (that way you don't drain the fluid and make the car undriveable if the fill plug is stuck for some reason).
Check the thread below for the fill plug location...
PDF page 00-79 (scroll down quite a bit in the first post):
Rear differential (torque transfer mechanism)
https://www.evolutionm.net/forums/mi...ml#post6750417
Old Feb 2, 2011, 05:56 PM
bradze's Avatar
ok thanks so can i use a different kind of ATF other than the diamond stuff. the stealership is so far away.
Old Feb 4, 2011, 06:41 PM
N118GT's Avatar
so what is the plug facing the back that says gear oil that I accidentally tried to pour my diaqueen LSD oil into and got pissed when it wouldn't fit?
Old Feb 4, 2011, 06:48 PM
bradze's Avatar
do i just fill up until it overflows at fill plug?
Old Feb 5, 2011, 01:25 PM
LaXGSR's Avatar
Not sure if you can use just any ATF. I would use mitsu ATF SP3 as specified. Just fill it until it starts to come pouring out. I usually will let it spill out for at least 10 minutes before tightening the fill plug. It's important that the car is level though.
N118GT, I think there are other bolts that are labeled to help you know if you're on the LSD gear oil side or the ATF SP3 side of the rear diff, but they are not all for filling. Look at the link I posted to see the service manual guide to where to drain/fill from.
Old Feb 23, 2011, 06:37 PM
bradze's Avatar
i changed front today. where would you put can of fluid to pump into rear diff? never used a fluid transfer pump before so it took me a while
Old May 5, 2011, 07:41 AM
oftheheavens's Avatar
alright going to try this soon, but just to understand i can put the same amsoil 75-90 that i use in the transmission into the trans case and rear diff?
Old May 5, 2011, 09:16 AM
07outty's Avatar
no......the 5 speed gets manual transmission oil (i use red-line)
the front and rear diffs get LSD oil ( i use mobil one)
Old May 5, 2011, 10:04 AM
thuoght that amsoil GL4 was used (sorry i said just 75-90)
so is the amsoil GL4 good to use on all three?
Quick Reply: Ulitmate DIY Transfer case, TC-SST Transmission and Rear Differential fuild change.
