Quote:
Originally Posted by abu
I just used double sided tape and its holding on fine. You will have to drill the holes for the clips. just line it up with the hole on the fog cover. The clips need to clip the bumper and duct. you need to remove the factory mesh wire and fog light.
The clips have a threaded piece, do you know if that should be on the side that I've drilled in the bumper, or on the side of the ducts? Where did you place the double sided tape, on the areas where the holes were in the ducts or somewhere else? That sounds like a good option but man would it suck to see my hard earned $$$ disappear in my rear view
