Oct 15, 2009, 12:08 AM
Personal Sales Rating: ( 4)
2008 Mitsubishi Lancer Evolution
Drives: 2008 Lancer Evo GSR
PROBLEM: Installing Seibon OEM CF Front Lip
Heyy guys!! For those that have installed the Seibon CF OEM aero front lip, can you guys tell me if you kept the factory front lip on the car? I tried to put the lip on the car originally with the factory little under bumper lip but it was soo tight when it came time to hook the other end of the lip around the corner of the bumper. I didnt want to force it and crack the end of the lip so i stopped and took off the factory lip and the seibon lip slipped on the bumper sooooo easy. But the problem now is that there is a 3" gap under the bumper between the lip and the factory plastic undertray. I DD my evo x and it would suck to get snow/salt in my undertray in PA weather..
The factory Aero front lip comes with a plastic hanger to put in place where the factory lip use to be to connect the lip to the undertray. I tried to get just the hanger from the stealership but its not possible to get just the hanger =(
Aero Front Lip Hanger:
Here's the pics:
Front Lip On:
The GAP:
__________________
2008 Graphite Gray SSS Evolution X
[ACT][Artisan][BBS][HKS][Injen][Ivey Tuned][Mitsubishi][Seibon][TEIN]
Online
Oct 15, 2009, 12:13 AM
heres the factory front lip i took off
__________________
Online
Oct 15, 2009, 12:15 AM
Personal Sales Rating: ( 6)
Drives: Evo X GSR
i had it before...what i did was just zip tie the open holes together, and left it as is. it held up, but then i only had it for a short time.
yes you're supposed to take the oem one off.
__________________
SEIBON skirts + diffuser + rear ext + ralliart tails + CW hood ✔
Rexpeed vents + gurney flap + grill ✔
Nisei UICP + UR LICP + AGP FMIC ✔
WORKS .9" springs + AMS bushings ✔
Defi boost gauge ✔
moleskin ✔
AMS O2 dp + cat pipe ✔
Ralliart front strut bar ✔
Magnaflow Cat-back ✔
HKS Kansai rear bar ✔
Vibrant resonators ✔
HKS WGA + HBSpeed ✔ (338.1ft/lbs, 350whp)
Volk TE37 + Toyo T1R ✔
Whiteline sway bars ✔
Blacktop Aero lip ✔
Titek carbon panel ✔
Girodisc Stage 4 ✔
Offline
Oct 15, 2009, 12:27 AM
it doesnt make sense to just leave that gap there.. The bottom center of the seibon front lip has a thing to attach the lip onto the undertray to hold it kinda together but it serves no purpose because the bottom of the undertray is still exposed.. AHHH im pretty disappointed at SEIBON!!! I guess nothing beats OEM POS SH**
__________________
Online
Oct 15, 2009, 02:14 AM
Drives: Evo X GSR
actually, looking at it again, you mounted it wrong. the fiberglass bracket go on the bottom. you're supposed to cut up the undertray a bit to allow the bracket to slide through. when that's done, the tray will sit much closer. look at russellm's oem front aero lip install pictures to get an idea of what you need to cut for the undertray.
__________________
Defi boost gauge ✔
moleskin ✔
Blacktop Aero lip ✔
Girodisc Stage 4 ✔
Offline
Oct 15, 2009, 06:40 AM
Personal Sales Rating: ( 0)
Drives: evo x
seibon fits one every 5 times,
2 sets of doors both didn't fit my client had to remake the housing for the locks.
i am not suprised it didn't fit.
__________________
Q: What is a Three Letter Word For FAST??
A: EVO
Offline
Oct 15, 2009, 01:08 PM
i think i might just end up modding the crap outta the lip so it'll fit over the factory lip
__________________
Online
Oct 15, 2009, 03:06 PM
Quote:
im still confused where do i cut the undertray? it doesnt block anything. Its short. There are three little fiberglass brackets that are attached to the lip. I attached the brackets from the lip to the undertray with no problems. In between each bracket theres a gap. maybe i should take another picture.. ughh its so frustrating thanks for the help endGameXIII but are you saying i can somehow extend the undertray so it meets with the lip? SOOOOO CONFUSED. i think i just got a crappy fitment lip and i just have to modify the lip someway to make it work with the factory lip
__________________
Online
Oct 16, 2009, 08:57 PM
bump for some help
__________________
Online
Oct 16, 2009, 11:11 PM
Drives: 2006 evo IX mr
here is what you can do. get some cardboard or thick construction paper and trace out a ful size template of the shape needed.( go under the car with the paper and tape it into place and then trace out the shape) . cut the shape out and duble check that it looks right, include al holes needed to mount. then take your template to a plastics supply shop and get them to cut you a piece of 1/8th thick black ABS plastic to the shape of your template. then just fasten it into place with screws or clips.
keep the template incase anyone else on here needs the same part made up. i just did this on my evo 9 and the abs has a good factory textured look to it.
hope this helps.
Offline
Oct 17, 2009, 06:52 AM
Drives: Evo X GSR
Quote:
well...here's an easy way for you to understand what you're doing wrong.
mount the fiberglass bracket UNDER the tray, not ABOVE like you have in the picture. meaning the bracket is supposed to show, not hidden, when you look under the car. you'll find that the plastic undertray has a slight extension on the edge that prevents it from sitting flush. you were supposed to cut the part that blocks the bracket from sitting properly.
__________________
Defi boost gauge ✔
moleskin ✔
Blacktop Aero lip ✔
Girodisc Stage 4 ✔
Offline
Oct 17, 2009, 07:06 AM
Personal Sales Rating: ( 68)
Drives: 06 IX MR Race Car (under construction), 06 Porsche Cayenne S
The only way that I found that the lip will fit without "modification" is to leave the stock plastic lip on the car.
The Siebon lip will fit over the stock set up, but it's a tight squeeze.
I tried the same exact thing as you did by taking the OEM plastic lip off and had the same gap.
I don't think that Siebon designed the lip to require the OEM plastic lip to come off and have such an obvious gap.
If you use the OEM lip, you will find that everything lines up in terms of the attachment points (although the Siebon lip will bulge down slightly in the front of the lip at that particular attachment point.)
Bottom line, the fitment is a PIA, you will likely have some small cracks in the CF when you put it on and you will have to shave down some areas around the curved areas of the front bumper to get it to fit flush.
Offline
Oct 17, 2009, 09:09 AM
FML thanks..
__________________
Online
Oct 17, 2009, 10:33 AM
Drives: 2008 Evo GSR
Seibon sucks, fades and **** hardly fits...
Offline
Oct 17, 2009, 05:56 PM
Drives: Evo X GSR
FML thanks..
 and you're supposed to transfer the metal clips from the oem lip to the undertray, so you can secure it. it should sit pretty flush after that.
and just to clarify for you, you're supposed to take off the oem lip. since this is a replica of the original aero lip, and the aero kit requires you take off the original lip, it's only sensible you have to do the same here.
Quote:
seibon stuff is a hit or miss at times, sure, but at least it's better than, say, ViS. their stuff truly sucks.
__________________
Defi boost gauge ✔
moleskin ✔
Blacktop Aero lip ✔
Girodisc Stage 4 ✔
Offline
Tags
aero, bumper, bys, car, cf, cw, evo, front, install, installing, ix, lip, oem, put, seibon  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
