Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X How Tos / Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 6, 2009, 06:02 PM   #1
Personal Sales Rating: (0)
Drives: 09 EVO X, 10 Q7 4.2L
Send a message via MSN to woshi6mang
help!!! how do I take off the o2 sensor
So I was trying to install a testpipe, the o2 sensor on the cat seems not coming off no matter what I do. I have even used WD-40 spray. So how did you guys take if off, or I just don't have enough strength?
Offline
Old Oct 6, 2009, 06:14 PM   #2
Personal Sales Rating: (1)
wiretap's Avatar
Drives: Evo X GSR
It's probably a good idea to work out in the weeks/months beforehand so you have enough strength to undo a bolt.
jk.
Get some Kroil or another good quality thread penetrating lubricant, then put it on and let it seep in for a few hours and do it's magic. Come back and give it another shot. It does take quite a bit of force sometimes.
Also make sure you're turning it the right way.
__________________
Quote:
Originally Posted by Ronald Reagan - Inaugural Address - 1/20/1981
We are a nation that has a government -- not the other way around. And this makes us special among the nations of the Earth. Our government has no power except that granted it by the people. It is time to check and reverse the growth of government, which shows signs of having grown beyond the consent of the governed.
Offline
Old Oct 6, 2009, 08:00 PM   #3
philamthebest's Avatar
Drives: Phantom Black Evo X MR
Heat that *****... that what i had to do. i got some map gas and heated it until it was glowing...
__________________
PB Evo X MR
AMS Intake
AMS Catback Exhaust
AMS FMIC
AMS LICP
AMS UIP
AMS Custom Tune
AMS Widemouth Downpipe
AMS Prototype Trans Cooler (SST)
Ultimate Racing Resonated Test Pipe
Blitz SBC iColor Boost Controller
AEM A/F Gauge
AEM Boost Gauge
Custom Build Pillar Gauge Pod (AMI)
Swift Lowering Springs
OEM Mudflaps
6K Fog Lights
Voltex Front Lip Spoiler
SSP Trans Upgrade (On The Way)
Offline
Old Oct 6, 2009, 08:15 PM   #4
Drives: WW Evo X
Penetrating oil and leverage. Put a pipe over the end of the wrench. Make sure it has a good grip on the O2 nut before you apply force.
Offline
Old Oct 6, 2009, 09:04 PM   #5
Drives: 08 AS Evo X
Also it helps to use a slotted deep-well socket instead of just trying to wrench it from the sides. You will get better contact on all sides. Slotted on the side so the wire can hang out of the side while you're turning it. Expect the threads to be morphed from the heat. I've taken mine out a few times and I swear I don't know what it's still grabbing on lol. It looks like a mess of distorted threads! Good luck.
Oh and remember, lefty loosey!
__________________
Quote:
Originally Posted by Gideon201
OMG people are not getting it.
I am going with OZ rims since I LIKE THE LOOK, i dont care if they lower my time by .01 sec like it matters.
"The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt."
-Bertrand Russell
Offline
Old Oct 6, 2009, 09:19 PM   #6
Is it possible the sensor and the cat has been melted together from the heat, so by applying brutal force it's going to cause damage to the sensor?
Offline
Old Oct 6, 2009, 09:47 PM   #7
Ltdanish07's Avatar
Drives: 2008 Apex Silver Evo x
i just sprayed some kroil on it. Put on the wrench and went at it with the hammer.
No they are not melted together. You would need an extremely high heat source. Just make sure you have a good bite with the wrench. You dont want to strip it.
__________________
Dane
PSU'11
2008 Evolution X
Apex Silver
Speed Circuit Wicked edition exhaust
Speed Circuit Test Pipe
HKS Drop In
Offline
Old Oct 6, 2009, 11:15 PM   #8
Drives: GRAPHITE EVO X MR
use this kind of wrench => http://cdn3.ioffer.com/img/item/120/745/041/fvfB.jpg
use this spray (pb blaster) => http://blasterchemical.com/display.cfm?p=50003&pid=4
Steps:
1. heat car up
2. spray PB Blaster on bolt
3. let spray sit for 30 mins
4 spray pb blaster
5 loosen bolt with wrench
You may need to let the spray sit longer and repeat heating and spraying. Eventually it will come off.
Offline
Old Oct 7, 2009, 07:49 AM   #9
Personal Sales Rating: (5)
Clipse3GT's Avatar
Drives: 00 Eclipse GT SDS Stg. 3 & 08 RR EVO X GSR
Send a message via AIM to Clipse3GT
Many rear O2 sensors have been crossthreaded from the factory, which is probably the case. I would not advise heating up the area with a torch otherwise you might damage a 300 dollar sensor, which has to be replaced with a OEM one.
Using something like PB Blaster etc... will work well probably to help loosen thing up.
I suggest getting a $5 dollar O2 socket from the auto parts store and then using a large breaker bar to remove it.
Once you get the O2 sensor out, put some anti-seize on the sensor so if in the future you have to remove it, it will not be seized in there.
__________________
List:
-CBRD Tune -COBB AP -COBB UICP, LICP, BOV HP -COBB SFI -COBB Turbo Inlet Pipe -COBB Sway Bars -ETS 4" FMIC -AMS DP -T1R Exhaust -MXP TP -FORGE WGA -xMR Catch Cans -AMS Front Rollerstop -AMS Fuel Rail -evoDynamics 3 Port -Deatschwerks 800cc -Techna-Fit SS Lines -TWM Short Shifter -WORKS Bushings -SWIFT Sport-Mach's -Whiteline Kit -AEM UEGO -STRI PSI Gauge -Rally Armor Mudflaps -PERRIN 3" Ant.
Future:
ROTA Torque
CBRD BBK Turbo
Kelford Stg.2 w Springs
SteepSpeed Exhaust Manifold
Online
Old Oct 7, 2009, 11:54 AM   #10
Brsox10288's Avatar
Drives: 2006 Evo SE-SSL, 2001 Eclipse, 05 Mustang GT
1.) Spray around the socket part of the o2 sensor with PB blaster then go do step 2.
2.) If you dont already have one, go to your nearest autoparts store and get a o2 sensor socket. Make sure ou get a 1/2" drive o2 sensor socket.(Wait for the PB blaster to do its work)
3.) After waiting about 30 minutes or so, get under there and try to break it lose with the o2 sensor socket. It should work pretty easy.
BINGO
Offline
Old Oct 7, 2009, 12:06 PM   #11
Personal Sales Rating: (28)
Silver05Bullet's Avatar
Drives: 05 Lancer Evo VIII, 03 Volvo S-40,97 VW Jetta
Send a message via AIM to Silver05Bullet
i have one for sale if anyone is interested
back on topic
spray with some penetrant let it work for a while and then unscrew it
Offline
Old Oct 7, 2009, 12:55 PM   #12
Thanks for all the ideals. I have been running without the o2 sensor for 1 week. The ecu gave me a CEL right away. I am probably gonna try the PB Blaster spray and o2 sensor socket one this weekend. Hoping it works....
__________________
2009 EVO X MR
Agency Power turbo inlet
ARC IC,UICP
Amuse Ti cat-back
AMS downpipe
Custom testpipe
Gruppe-M intake
HKS SSQV,ssqv recirculation kit
HKS Kansai spark plug cover
JUN exhaust manifold
Mishimoto rad hose
Swift spring
Varis spoiler,canards,front bumper cover
Offline
Old Oct 7, 2009, 01:13 PM   #13
Ltdanish07's Avatar
didnt know they made a special wrench of a 02 sensor. learn something new everyday.
__________________
Dane
PSU'11
2008 Evolution X
Apex Silver
HKS Drop In
Offline
Old Oct 7, 2009, 01:24 PM   #14
Brsox10288's Avatar
Quote:
Yup, its a cheap socket that works great!
Offline
Old Oct 7, 2009, 01:47 PM   #15
►EvolutionX◄'s Avatar
Drives: 08' GG Evolution X GSR
Quote:
back on topic
Very interested, Threads Took a fall on mine,
Pm me
__________________
Engine Modifications
AEM CAI
AMS FMIC
AMS UICP
AMS 02 Downpipe
AMS Test Pipe
ETS V2 Cat-back
-Visual Modifications-
AEM Analog Boost
AEM Analog Wideband
V1 Hardwired
Ralliart Tailights
Powdercoated Wheels
Offline
Tags
02, blaster, cat, coming, downpipe, evo, kroil, lancer, o2, o2 sensor, oxygen, pb, removal, sensor, spray, testpipe, wont
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
