Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X How Tos / Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 3, 2009, 11:42 PM   #1
Personal Sales Rating: (2)
Guru's Avatar
Drives: 08 EVO X WW GSR SSS Aero Navi
Installing DG Motors EVO 9 Converted Master Cylinder/pedal
Holy crap this install is a pain! Be prepared to have very very sore hands and scratches on your arms. Some tips for install. I made a stainless line from the MC all the way to the slave. It is standard 10mm banjo on both ends. 48 inches long. I would recommend a new banjo bolt on the slave side or you can do what I did which is to use washers as the factory banjo is much thicker and the factory bolt won't seat all the way otherwise. Now removing slave isn't the rough part, it's the clutch pedal which is the hard part. To install you will need to unbolt the fusebox, it will make removing the old one much easier and you'll never get new one in without doing so. It is only 3 10mm bolts. You also have to unbolt and remove the AYC ECY it is tiny and just in front of the fusebox by the pedal. It is only 1 10mm bolt that holds the bracket on. Now you should be able to access the 6 nuts hoding the pedal on BUT there are 2 plugs but also 3 clips holding 3 harnesses. I couldn't get one off so I simply cut the electrical tape holding it onto clip and called it a day. On the other side there is one clip the hold the line on and then a circlip which then allows you to disconnect the hose portion of the line from the metal piece that goes to slave. You simply pull off clip and pull hose off. Take a second. You should now be able to pull off pedal out. If you want you can pop off the master from the pedal and pull out the engine bay I believe. I didn't do it this way since didn't know you could do that. Now comes the tricky installation part! You have to cut quite a bit of firewall. Now don't forget you not only need to trim it to fit the master (which is oval and not round like the stock piece) but also a bit more on the driver side of the hole since you need to feed that master through there and the nipple for the feed needs some room to clear the hole. Now squeezing that new pedal and master through there is a BIATCH! I couldn't do it with the new feed line and banjo on it unfortunately but I recommend you do. I also recommend you remove hose and install on the master BEFORE you install. Getting that hose on the barb when in the car is also NOT fun. I installed banjo and line once in the car but it's tricky and too easy to lose the washers. I hope this helps people with the install. The pedal feels great with short travel between on and off. So far so good. Only drawback is a bit of dead travel when you just press on it initially but I'm sure I'll get used to it. I think maybe due to the joint installed on it? I am very glad I did it after seeing the factory plastic POS. No wonder they break. Overall took my friend and I many hours to install. WAY longer than we thought initially. Plan ahead on this one.
__________________
Dan
Thinking of a Blouch Turbo? Read this first:
http://forums.evolutionm.net/service-parts-tuning-review/375268-stay-away-blouch-turbo.html
Offline
Old Oct 3, 2009, 11:53 PM   #2
Personal Sales Rating: (1)
SpeedI2acerX's Avatar
Drives: 2008 Evolution X!!!!
and no pics?
__________________
2008 WW Evo X
Mods: AEM intake, Works stealth exhaust, Works re-flash and tune
Hp: 307@7k
Tq: 308
on a dynopack
Special thanks to Edo Performance and Works
recently ichiba tp and uicp...Hp/Tq=326tq/313.2hp thx to
jon, ronny, matt@
HB speed! DynoMite!
Offline
Old Oct 4, 2009, 12:17 AM   #3
Guru's Avatar
I'll let someone else take the pics. I was busy working and don't have a camera.
__________________
Dan
http://forums.evolutionm.net/showthread.php?t=375268
Offline
Old Oct 5, 2009, 08:17 PM   #4
Personal Sales Rating: (0)
shomesomesho's Avatar
Thank you for writing this. I hope to be putting this in in the next few weeks.
__________________
Current mods:
AMS FMIC|Forge MBC|CPE Catback|Meth Injection|ECUFlash Tuned|TWM Short Shifter|AMS Shifter Bushings|Rally Armor Mud Flaps|Speed Circuit Cat Delete|AMS Intercooler Hot Pipe|AMS Performance Intake|AMS Shifter Base Bushings
To Come: AMS Fuel Rail, Injectors, Fuel pump, and more....
Offline
Old Oct 5, 2009, 09:32 PM   #5
Silver Sponsor
Personal Sales Rating: (6)
DG Motors's Avatar
Drives: Drag Evo 8, DG built Evo X, 05 Cadillac Escalade, 07 Ninja zx6r
Thanks for the write up Dan! Now you understand why we charge what we charge. This by far is the most annoying install on evo x but will save you $$$ over time due to not breaking a master cyl.
__________________
DG Motors
In-house DYNO DYNAMICS
Tuning specials for evo 8's 9's and X's
Ecuflash Specialists/Aem Certified Tuners
WWW.DGMotorsNY.COM
1-631-957-8464 -Ask for Pete
Internet Flash Packages!
Tuner Of Worlds Highest Whp "Stock Ecu"Stock Block Evo X 629whp!
Tuner Of Worlds Highest Whp Evo X On 93 Octane 629whp!
DG Drag Evo 8: 9.06 @ 164mph!
DG Drag Evo 8 In Action: http://www.youtube.com/watch?v=ASZIiklA0Ow
Offline
Old Oct 6, 2009, 12:18 PM   #6
Personal Sales Rating: (3)
2008 Mitsubishi Lancer Evolution
evofan_08's Avatar
Drives: 05 acura TL (sold) / 08 ww evolution x gsr
HA HA HA, OK GURU NOW APOLOGIZE TO DGMOTORS for all the sniveling comments you made to them on the initial 9 master cyl. thread. Now, you can understand how valuable dgmotors is to the evo x community.
__________________
Check out my car Blog
Tuned by Kreionic 297.7awp/ 340 awtq on Dyno Dynamics Dyno = to like 360awp on a dynojet
mods: DG Motors Evo 9 clutch master cylinder conversion/ Ecuflash tune / Greddy Ti-c / Exedy stage 2 clutch / TurboTrix intake / K&N Cone Air Filter / AMS Small battery kit / AMS Upper ic pipe / AMS test pipe / AMS o2 Simulator / Defi White racer boost gauge / ARC titanium shift knob / T1R suede shift boot white stitching / Tein Mono Flex Coilover
Offline
Old Oct 6, 2009, 12:39 PM   #7
Guru's Avatar
They have been great. Got me the pedal exactly when they said they would. I think they are just WAY too busy at the shop. It's tough to have a shop AND do online sales but glad they have been contributing to the community with this great mod. I will send all EVO X people their way for this. Oh and Pete sending back the OEM pedal today for ya! Should have Thursday. May have to order another one for a friend soon.
__________________
Dan
Offline
Old Nov 9, 2009, 06:47 AM   #8
Silver Sponsor
DG Motors's Avatar
Quote:
sounds good, just let us know!
__________________
DG Motors
WWW.DGMotorsNY.COM
Offline
Tags
clutch, cylinder, dg, dgmotors, evo, evolution, flaps, forum, install, master, motors, mud, navi, ny, queens
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
